#151 |
Re: Parting out 71 Cheyenne C20
I have a 1967 C10 with the power assist steering... works decent slight leak but I want to swap over to the more common power steering setup... I have 1972 spindles/brakes currently, I really just need the power steering box, pitman arm, drag (center) link, idler arm, idler arm bracket, inner/outer tie rods and adjuster sleeves.
Is there any of this you could help me out with? mainly I am looking for the center link. Most everything else I can buy a new part for. Also, if you have some use for an original power assist steering from a 1967 C10, maybe we can figure out a trade? Thanks!! |
#152 |
I am in need of the power steering pump, brackets, hoses and bolts. Do you still have this
#153 |
Hood Hindges? Available? Conditio? Price?
#154 |
do you still have the accelerator pedal assembly, and the headliner trim for so how much shipped to 74801 thanks
A Rod |
#155 |
Is the ho72 limited slip?
Need the rear 18"-2' of a c20 coil spring frame! Don't need crossmembers to save shipping. |
#156 |
Do you still have the front frame horns where the bumper attaches? Would you be willing to cut them off behind the core support mounts and ship to Ohio 43064?
#157 |
Active Member
![]() Join Date: Jun 2013
I know it has been awhile for this post,but was wondering if you still had trailing arms and if so do you have any pictures?
Thanks Joe |
#158 |
Do you by chance still have the engine compartment heater box cover (Non-A/C)? If so, how much for it...shipped to 61571?
Thanks! |
#159 |
I am in need of all the transmission linkage even the price on the trans. All except for the long rod off the column. Also looking for a heater box for under the hood non a.c. shipped to 53140 thanks adam
#160 |
Is the ho72 an anti spin?
