08-27-2016, 03:59 PM | #151 | |
Re: No Limit Trailing Arm Rear Suspension
So no welding required just bolt it in? What do you guys carry as far as the 3rd members and what would you recommend for autox? |
08-27-2016, 05:08 PM | #152 |
Yes, no welding to the housing needed. For our FatBar, there would still be some welding needed for the Panhard mount, - but, we are going to change C10 FatBar kits to use the new C10 Panhard from the Trailing Arm kit, so those will be bolt on as well after Oct-1. (maybe sooner.)
As far as gears, a lot depends on the trans and tire diameter. For highway, we like to see about 2400 rpm at 70 to 75 mph. So the O.D. ratio comes into play. For most autocross, GoodGuys and USCA are mostly 'first gear' coarses, so as a rule, in first gear you want about 9.5" of tire roll per 1 RPM. So tir diameter can play big into the gear ratio here. 3.5 or 3.73 is usually pretty close.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
08-27-2016, 07:40 PM | #153 | |
09-03-2016, 07:30 PM | #154 |
09-03-2016, 10:13 PM | #155 |
Is that a shallow notch compared to CPP or is the center section just longer?
1968 LWB C20 / AC / Wood Bed |
09-10-2016, 10:54 PM | #156 |
Is Hotchkis the only rear anti roll bar that works with the No Limit trailing arm setup? I thought I read before that the No Limit rear anti roll bar setup won't work?
-1998 Formula WS6 1LE- LSX 427 4.58 @ 162 mph, 1.12 60' 2017 Silverado 3500 High Country DRW DMAX, 20" Fuel Wheels 1972 Chevrolet C10 Cheyenne - SOLD RaceWire Solutions |
09-11-2016, 12:08 AM | #157 | |
A guy with a truck
Curious on this, too. Hotchkis is nice, but spendy. I don't think the standard NL bar will fit with the coilovers.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-12-2016, 10:34 AM | #158 |
OK, YES, the No Limit notch is 'shallower' or - not as deep - as some others. This is on purpose. With this depth, and a 1/2" bump stop, when the axle tube hits the bump, the top of the diff housing will be 1/4" from the bed floor. So, any more notch would A) needlessly weaken the frame rail, and/or B) require a bubble or tunnel in the bed floor to clear the diff housing. Since this notch was developed with "stock rails" in mind, we decided to match that idea with a "stock bed floor" concept.
As for the rear bar on our Trailing Arm kit, we are still set up to use the Hotchkis bar, if desired. Now, Autocross testing has yielded faster laps with-out the bar. The normal street driving, even on the Dragon, is more comfortable with-out the bar. But, high speed open-track laps are faster with the bar. **Factor in here 200 TW tires and some Aero to get them to stick, otherwise, no bar is a better choice.
09-12-2016, 11:54 AM | #159 |
I like the shallow notch in that it gives people another unique option.
Re: sway bar, that's not what I expected! Any idea why autox is faster with no rear bar?
09-13-2016, 09:20 AM | #160 |
Auto-X (OK, Fast Auto-X) is probably the hardest challenge for your suspension/tires than anything else (ON-road competition) we see higher shock and spring rate changes than anything else. Honestly, many Auto-X'ers have surpassed the G force loads of a lot of road racers, it's just that on an Auto-X coarse, the 'time' of the G event is much shorter. The 'violence' of the tire loading is much harsher. So, allowing the body to roll a bit more (still with the rate controlled by the shock) slows down the rate of tire loading and allows the tire to get a grip for a bit longer.
09-13-2016, 03:01 PM | #161 | |
"There are a lot of concepts out there about handling. Here is one thing i see a lot at Auto-x and track events. The problem is that the car (truck) is loose through the corner. The solution is to disconnect the rear sway bar. ?what? I see this all the time. OK, I get it the first time, but this is backwards." "Having a low roll center will produce a good 'bite' in and out of a corner, but it produces more body roll. So, a combo of a low panhard rod and a light sway bar will give you great results." "Try to keep the swaybars close in size. 1 1/4" front with 1 1/8" rear is good for more streetable trucks, 1 1/2" front with 1 1/4" rear for more aggressive handling." "Swaybars. GO BIG, but keep the back within 1/4" of the front." "Lets get back to the main topic, HANDLING. One of the best upgrades you can do is swaybars. Swaybars, or Anti-roll bars, work by adding traction (downforce) to the outside tire. To do this, the swaybar has to take downforce away from the inside tire. So if you think about it, you can go 'too big' on the bars. If you went so stiff that the inside tire lifts off the ground, then that tire isn't helping at all. The balance between the front and rear bars is called "roll couple", and here's where a truck layout changes normal thought. In a normal performance car, with say 52% front weight and a low CG, the roll couple needs to be up around 80% (calc for this is really complex, so think of this as a comparison number), but in a truck, with 58% front weight and a higher CG, you aqctually need to move the roll couple BACK, maybe to 65%. This means that in comparison to a Camaro that would run a 1 1/4" front and a 7/8" rear, the truck would tend to 'need' a more evenly matched bar set. Say 1 1/4" front and 1 1/8" rear. Most retailers/manufacturers are missing this and selling bar sets in 'car' sizing, so be carefull. " "Last weekend in Pleasonton, I was explaining this to a few people and most believed that a smaller rear bar would help the truck turn, do to the added cross weight from the inside rear to the outside front - as the truck leans over. So, I pulled one of the rear swaybar links on our 55, effectively it had no rear bar. The truck pushed like crazy, and on the second lap, I spun out trying to throttle steer it through a corner. Bad outcome, but it was a good demonstration of swaybar tuning." So look, clearly I've been paying attention to what you're saying but I've seen you contradict yourself several times -- this isn't the first. I treated the "make it handle" thread as an introduction to performance handling and I feel like I learned a lot and I appreciate the time you spend to put that knowledge out there.
09-14-2016, 12:12 AM | #162 |
A guy with a truck
Seems this setup is dependent on the type of handling--autocross, tight circuit likes no bar--high speed track needs the stability--and on the street, where ride quality rules, no bar makes sense.
09-15-2016, 01:15 PM | #163 |
Some days I like dark beer, and some days I do not. Usually depends on the location or the season. It's kind of a Blonde vs. Brunette kinda thing.
Chassis design is the same way. While I would stay with the comments made in the M.I.H. thread, those comments are dependent on a chassis design that allows you to do that. Even though the bore size is basically the same, you can't put a .300 Win Mag cartridge in a .300 Black Out AR. IF you do, the result is not good. So, Yes, I said those things, and Yes, they are true. BUT, we are talking about getting the best result from a bolt on trailing arm system on a stock C10 chassis. - Not a performance designed chassis. So we have to be honest and understanding about what we can and can not achieve. BTW, Cory took his C10 (the butternut yellow truck we used here) + with a new Wide-Ride IFS installed just a week before, to LS Fest, and with NO experience on the new front suspension, ran the Auto-Cross and finished third in the truck class. Not bad at all. #2 was Karen Leisinger in the black #9 C10, and first was Jason Brady in his tube chassis blazer. look for more info on his truck to come out soon.
09-15-2016, 05:16 PM | #164 |
A guy with a truck
Sounds like
Haha, just kidding, don't shoot! I just ordered mine--thanks for working with me and for the great deal. I'll be pairing it with a PB front and looking forward to some awesomeness.
09-16-2016, 08:44 AM | #165 |
What, you don't think I like dark beer? Thanks for the order, let us know how it matches up.
09-16-2016, 11:42 AM | #166 |
Rob, assuming a 4500lbs DD single cab late model truck moderately lowered (2/4), with stickier rubber, would going with a 1 1/2" front sway bar and 1 1/4" rear sway bar be a wrong choice?
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
09-16-2016, 06:30 PM | #167 |
I've got a question about the notch, does the notch allow for axle to be centered in the wheel well? I've seen some of these with the axle too far foward, and the notches over the non centered rear end, if that makes sense.
09-21-2016, 11:54 AM | #168 | |
The O.E. has a lot of factors to cover, and their goal is to make $$ for the share holders. I didn't say 'to sell trucks' or 'to make the best product they can'. The big three are beholding to the share holder first. So, they build a vehicle that will suit the largest segment of a particular market, have some cross-over sales, and make a profit. So, they can't build the best handling truck (even if they wanted too) because too many people would be cut from the market group. - harsh ride, too low, to responsive...... So, the aftermarket is there to 'shape' a vehicle in a certain direction. - towing, performance.... ALWAYS keep this in mind. Real swaybars are rated in Lbs force per twist amount. And, they don't all use the same scale. It could be lbs per inch (one side vs. the other) or lbs per degree of twist, some use lbs per 5 degrees. To get a grip on this you need to understand which part of the swar bar twists (like a torsion bar or spring). Three piece bars are easy to understand, that the center bar twists, and the arms are the levers to twist with. So, add this in to the equation. Sway bars with longer 'Arms' are softer than the same bar with a shorter 'arm'. Sway bars with a shorter center 'bar' are stiffer than sway bars with a longer center 'bar'. With this in mind, it is easy to understand that a 1 1/2" dia bar, with a long center and long arms could yield lower "lbs/degree resistance" than a 1 1/4" bar with a shorter center and shorter arms. Or, any combination there of. Next would be mounting points, like how far out on the A arm.
09-21-2016, 11:55 AM | #169 |
Yes is the short answer.
09-21-2016, 01:02 PM | #170 | |
Spit balling, in general I believe (may not be the actual truth) that late model hydroformed frames are generally stiffer than say, old C10 frames. So as a starting point there may be some benefit there. On the other side of the coin I think truck weights have steadily gone up and a newer single cab truck is probably a solid 1000lbs heavier than an older single cab truck. How does this relate to my question? My truck came with a hollow 1 1/4" front sway bar and no rear sway bar, I purchase (from company X-wig) a solid 1 1/2" front sway bar and a solid 1 1/4 rear sway bar along with some lowering springs (company X-tech), along with stickier speed rated rubber (from company X-oyo) in an effort to increase handling and stability. What I've learned is that the front springs are most likely rated at 800lbs, which for spirited driving is probably a little under sprung considering truck weight/aggressive driving............on the other hand the sway bar upgrade may be a little on the aggressive side based on material (solid 4140) and size. With that said, I may get lucky and this large bar/small spring combo may work well together.......maybe not......thoughts? On a side note (my opinion), in our search for better performance, in a lot of ways we are handicapped, even by the aftermarket, in using whats available because that's what sells vs actual engineered performance.........realistically I believe it would be so incredibly cost prohibitive to custom engineer everything in what would probably be 9 times out 10, trial and error engineering because "for example" the lowering springs I bought were sold for the sole purpose of a look with a cultural implied performance benefit vs actual benefit, yet even these springs are only readily available for the most popular trucks.............maybe I'm rambling.......... bottom line, is that it's a lot to wade through when your trying to only spend your money once! Which is why I/we appreciate your help such as it is.
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) Last edited by moregrip; 09-21-2016 at 01:16 PM. |
10-02-2016, 03:02 AM | #171 | |
Do you have any plans on doing a write up on the Wide-Ride IFS kit? I am planing on ordering one for my truck and would like to see one go together. Thanks |
10-04-2016, 07:57 PM | #172 |
Are any crossmembers included or are necessary for this kit? Just trying to get all my ducks in a row before I order parts.
Also, what front drop kit do you recommend to go with it? If i do this (drop this much on my "toy" truck), I only wanna do this once ya know. |
10-05-2016, 09:22 AM | #173 |
Yes, we could do that.
10-05-2016, 09:26 AM | #174 |
This kit is based on using stock crossmembers, so none are included. For the rear, the drop is limited by axle clearance. So, about a 7" drop is the max, with a bolt in notch and stock floor. I would match that with a 5" front drop. Spindles first, then springs. As for front shocks, I like the Porterbuilt raised front shock mount, matched with a stock length shock, like the Doetsch 3000 pre-runner. It just works good.
10-06-2016, 07:46 AM | #175 |
@robnolimit
With that kind of drop, clearance doesn't start becoming an issue? ( Both ground clearance and exhaust routing) I remember seeing a crossmember with the center section hummed and two cutouts for exhaust routing, but im not sure who made it, i wanna say Porterbuilt but im not positive |
