#151 |
Re: Complete build change. Lifted 2wd
I like the stainless units if running the big mirrors.....
#152 |
Thank you. yes i like the stainless a lot just trying to get used to how big they are. I've had the sport mirrors for like 15 years so it is just such a change, im not sure i like it.
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
#153 |
#154 | |
I want to convert to 4x4. it makes it much worse in your opinion?
#155 | |
I have a 402CI gen 5 LT motor (L8T 6.6 liter) with what should be near 600hp. I am frightened to death of driving this thing spiritedly. Steering roams a lot even with the upgraded steering box. Mine has the added benefit of riding like crap. The springs that were installed in front by the previous owner are definitely rough. I come from a lowered truck background though. This is my first solid axle front truck (outside of military service). I am used to decent to great handling IFS front setups. So I am probably never going to really be happy with it. I am stuck between making the decision to fully upgrade the suspension up front or going 2wd. I am about to leave the house to go look into a chassis from a 88-91 tahoe. I want to figure out if I can fabricate a full front crossmember setup that I can bolt the 4x4 clip out of the tahoe into the Blazer. I would love to keep the 4wd but have IFS for the ride quality and stability. My real goal is to have a low-ish AWD/4WD K5 with over 800hp. I am seeking 72 K5 Blazer with Trackhawk capability. Think if Chevy would have made a lowered K5 with AWD and a bunch of power. Yes I may be dreaming but dreaming is where big accomplishments start. This guy in this video of a square body is what I am after. I do not need to be as low but I would pee my pants to be able to make my K5 do what his C10 does. I do not need the same power that he has though. I would also like to do it without cutting my frame in half like he did to add the escalade front clip. C10 racing a Lambo https://www.youtube.com/watch?v=xeF4xWpmifo C10 build https://www.youtube.com/watch?v=h0Xqy5FeINI&t=284s Last edited by NDM; 08-19-2025 at 03:28 PM. |
#156 | |
#157 |
PROJECT 7DEUCE
Nice build you have going on...
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#158 | |
I love my Blazer but I did not put all this motor in it to NOT use it. I am going 2wd. I am just very torn as I really like the ride up high. With all the power of this cammed 6.6liter, my Blazer is kind of scary though. I would never be able to take a quick evasive manuver because it steers terrible. |
| Bookmarks |
| Tags |
| 2wd lift, 67-72 chevy, lifted, lifted 2wd, ls swap |
