Re: Brother's keeper - '58 Stepside build
After body working the rear fenders, I got them on for final mock up...
![]() ![]() Join Date: Aug 2013
Looking good.....
The last big hurdle is the doors. They are in great shape and won’t need much bodywork. I spent the evening removing an excessive amount of 3M yellow weatherstrip adhesive, finding and opening up drain holes and cleaning out a ridiculous amount of nuts, bolts, washers and general debris that was inside the doors...
They're in nice shape...
I am pleasantly surprised, the jambs will only need to be scuffed before painting.
Great progress, strong work.
Has anyone ever done door glass without the metal channel attached to the glass? And found a way to put some sort of insert in the door to accommodate door glass with out the metal channel? Don't want to hi-jack the thread, just an unfiltered thought. NC
Been there, wrecked that ![]() |
#7 | |
Getting a little color on some parts...
Coming along good....I'm at the blocking stage with one....close to paint....seems like it never ends...
Finished up the driver's door this weekend, all that's left is the passenger door. Won't be long and everything will get some high build primer and the final blocking can commence...
Getting some of the front end sheetmetal ready, the inner fender walls got a coat of satin black on the back side and some SEM Rock It bed liner for undercoating. I rolled it on to keep the mess to a minimum...
Prepping the core support, inner fenders and filler panel for paint...
#13 |
With some sealer and color. A couple runs on the inner fenders stalled progress, I let them dry overnight so they can be sanded out. I'm hoping to get some more color and matte clear on everything today...
#14 |
That's looking great......
#15 |
I came to the conclusion that my body working skills are not good enough to achieve the final result that I'm looking for. It's a bitter pill to swallow because I take pride in my abilities, but for this build to move forward I had to enlist some professional help. Since the truck is blown apart I'm bringing a couple pieces at a time instead of the whole truck. When the front fenders are done I will bring in the rear fenders and swap. In the meantime, I will keep doing what I can.
#16 |
![]() Join Date: Jan 2015
maybe if you pick up a spare hood or fender and practice body work on those to bring your skills up to par. I personly think you can do it.... it just takes quite a bit of practice .. its the only way you're goin to learn. But you do have the skills
#17 |
I know how you feel Black Sheep, my body skills suck but seem to get better little by little, knowing when to stop sanding has been hard for me to grasp, painting scares hell out of me but I decided its the only way to learn, Be brave "Just Do It", think I'll be happy with a 20 footer I did my self, we'll see.
#18 | |
I finished my GTX almost 20 years ago, I suppose I had more energy and ambition back then... |
#19 |
After sanding out the runs, I repainted the inner fenders and core support. The temperature was a lot better for painting and it laid down nice. The color is Ford HP White with satin clear, it almost has a pearl look to it. As the paint was drying I cleaned up the front of the motor and polished the tanks on the radiator.
I got the core support level with the cab, now to get it centered and square... |
#20 | |
![]() Join Date: Jul 2012
Many of us have been there...do I work on the project or take this Saturday to go to a car show or cruise in? Getting burned out and keeping going. I’ve tried to do a balance (some summer cruise ins or shows, winter project building with no time pressure) and then I enjoy the project build more. Of course the build goes more slowly. Then I’ve also set a goal to make a specific show or event, which helps keep me motivated, then burn the candle at both ends to make it. That has worked for me on several projects. To make it, I selectively hire help or farm out some work. That feels more like work and project management to me, though like I mentioned, it has worked to get one “done”. Enjoying your work and continuing to tag along! |
#21 |
Front fenders are done! I picked up the fronts from the body guy and dropped off the rears. When those are done I will bring him the doors. The truck will be ready for paint soon.
In the meantime, I am taking care of a bunch of loose ends. I finished up the dome and courtesy light wiring, stripped and reprimed the radiator filler panel and blocked out the steps and tailgate so they are ready for another coat of 2K. |
#22 |
![]() Join Date: Mar 2011
Nice...Jim (also posted on the other thread)
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#23 |
A quiet day in the garage after finishing up yardwork...
#24 |
Moving right along...Jim
#25 |
That’s startling to look like a real truck again
My taking way longer than expected 58 build |
