Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-30-2022, 07:42 PM   #151
JustToxic
JustToxic's Avatar
Re: C20 to K20 Conversion "Simply Toxic"
Well after working on a various other projects and what not. I am finally getting back on this project. Between the last post and now, I got a 2002 Silverado 1500HD with a 6.0 LS, 4L85E, NP246. Just got done striping that out, selling all my SBC stuff and parts I don't need off of the Silverado. Next step on the truck will be fixing issues with the suspension. and then building mounts for the new LS drivetrain. More progress pictures coming soon!
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 10-31-2022, 03:53 PM   #152
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looking forward to the updates.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-23-2023, 09:15 PM   #153
JustToxic
JustToxic's Avatar
So after having a ton of time off from this project. I decided to cut the firewall out to mount the engine back as far as I can. Got the engine roughly mounted in.
Old 01-23-2023, 09:21 PM   #154
JustToxic
JustToxic's Avatar
So the previous post was pictures taken before I bought a parts truck, 2002 Chevy 1500HD, 6.0, 4L80E, NP264. Since I have the LS now to put in the truck, I sold the 383 and all the work that I did to get it mounted and what not I decided to change my idea. I am giving myself more leg room, so I cut the floor at the transition to the firewall and cut it away from the kick panel. Then bent it down to about an inch from the frame. One the passenger side I made up a 2" spacer piece and modified the floor brace to fit the new firewall.
Old 01-23-2023, 09:25 PM   #155
JustToxic
JustToxic's Avatar
Moved to the driver side this past weekend. On this side I made up a 3" spacer and bent the floor down to about an 3/4 of an inch from the frame. The two black bars you see is to keep alignment of the inner cab structure for the steering wheel and brake set up. I broke the welds to make it easier to remove from the old firewall. So now we are up to date on the build.
Old 01-23-2023, 09:29 PM   #156
JustToxic
JustToxic's Avatar
I did sell the seats from the earlier post to my dad, and put those in his 1965 C10. Those turned out pretty good in that truck. I am considering putting the rear seat out of the 2002 Crew Cab Silverado that I have. It is a pretty comfortable seat and is more of a bench style. I'll have to modify the floor to make it work so I am still thinking it over.
Old 02-05-2023, 02:45 PM   #157
JustToxic
JustToxic's Avatar
Started on the driver side this weekend. Got it welded in for the most part. Need to make a extension to the top and bottom of the inner bracket. Still need to cut a section of the floor out and add a filler piece. We also added a lower brace filler to rebuild the strength in the lower brace that was cut out to allow the floor board to bend down.
Old 02-06-2023, 12:51 PM   #158
Ol Blue K20
Impressive work!
Dale
