Old 10-05-2020, 11:12 AM   #151
Furno68C20
Re: Let's play name that part, bolt, harness, screw....
How about these?
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Furno68C20 is offline   Reply With Quote
Old 10-05-2020, 12:09 PM   #152
Redneck Rydes
Redneck Rydes's Avatar
Valve cover grommet for the flame arrester that comes from the air cleaner
Redneck Rydes is offline   Reply With Quote
Old 10-05-2020, 02:45 PM   #153
John H.
John H.'s Avatar
Nope, these are almost nylon or plastic, not rubber.
John H. is offline   Reply With Quote
Old 10-05-2020, 04:34 PM   #154
John H.
John H.'s Avatar
Originally Posted by 69-72 View Post
Any idea what these ac brackets fit? Early small block? Aftermarket? Pulley is larger than usual as well. I’m pretty sure it came off a 67-72
Believe those are 69 for sure and maybe older?
Old 10-05-2020, 10:53 PM   #155
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Temperature related?
Originally Posted by Furno68C20 View Post
How about these?
Lower Leaf spring U-bolt plates, window regulators & tracks
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-05-2020, 10:56 PM   #156
Curtb1971
Curtb1971's Avatar
E-brake cable grommets where it passes through the trailing arm cross member?
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 10-05-2020, 11:01 PM   #157
John H.
John H.'s Avatar
Winning! And the winner!
I took the one remaining off my truck in 1997. Found a pair on EBay but can’t find what the part number is. Not easy to find them in the Chevy or GMC parts books.
Old 10-05-2020, 11:10 PM   #158
71CHEVYSHORTBED402
Personally I think you nailed it, though if you ever look for them, they're "bushings". If true, I didn't know they came black. Have some on order, and day now, it's been weeks.
Winning!
Here you go......Another member sent me right to them. I found some NOS somewhat recently, in Brazil Part number is almost meaningless, but it's 3829512
https://www.classicparts.com/1966-72...ctinfo/71-739/
Tony
Old 10-05-2020, 11:24 PM   #159
John H.
John H.'s Avatar
Thanks! I have never really looked for them.
Old 10-06-2020, 12:04 PM   #160
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
I'm stumped on that grommet, looks familiar.
Where might 5/16-18 flange nuts be used?
One of these is 1/4-20, they were used with some heater hose retainers. I have two more someplace, they secure something to the dash
The '69 - '72 parking brake pedal bracket uses 3 of these 5/16" flange nuts. Two on the studs that hold the bracket to the firewall and one on the 5/16" bolt with small integral washer that attaches it to the bottom of the dash.
I think the engine compartment heater box might use a couple of the 1/4 -20 flange nuts.
LockDoc
Leon
Old 10-06-2020, 06:55 PM   #161
71CHEVYSHORTBED402
LockDoc
Nailed it.
My heater box didn't use any, it took speed nuts instead. My LH front hanger had them, not sure if that's factory, doesn't seem right. Same as for the condenser on my other truck, strikes me as wrong, they were only on top.
Tony
Old 10-06-2020, 11:14 PM   #162
71CHEVYSHORTBED402
I give up the double hex "double F" bolt (post 138). So close - that bolt mounts the rag joint assm. to the steering box shaft.
Tony
