Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-22-2023, 01:12 PM   #1
KFF 1
KFF 1's Avatar
Re: New project : 72 Suburban
Originally Posted by LockDoc View Post
That will be great if you can just jump in and drive it when the time comes....
LockDoc
Yes sir Leon ! Burb is all ready just have to wait on the weather for a couple months now
KFF 1 is offline   Reply With Quote
Old 01-29-2023, 11:15 PM   #2
3757chevy
3757chevy's Avatar
They worked well for me. https://67-72chevytrucks.com/vboard/...8&postcount=59
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-30-2023, 01:11 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Good deal! I have not had any trouble with mine and they work good.
LockDoc
Leon
Old 02-04-2023, 12:11 AM   #4
Average Joe
Average Joe's Avatar
The Burb looks great. I may have to copy that LED Jeep conversion in mine.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-02-2023, 07:59 PM   #5
KFF 1
KFF 1's Avatar
This coming winter I plan to make some changes to the Suburban as far as the motor, so I started researching a hydro boost conversion. I also reached out to member LockDoc who was very helpful with tips and info he had acquired during his conversion. For my conversion I used the hydro booster from a 2004 3500 box van. Junkyards are pretty non existent where I live so all i could source was the pump itself from a salvage/used auto parts yard. The lines I purchased at Napa for a 2003 Chevrolet 2500 (info compliments of LockDoc) After some tweaking at the power steering pump and a slight adjustment at the steering box the lines fit very well. I did remove the oring end for the steering box and double flared the end with the standard fitting end. Came out nice and the Suburban has NEVER stopped like it does now. So phase one is now complete and I dont have to worry about vacuum for the brake system.
Old 09-02-2023, 11:09 PM   #6
D.B
D.B's Avatar
That's great. I have a few questions you might be able to answer for me.
Did you change master cylinder or keep the one you originally had.
The firewall mounting. How did you mount the hydro boost.
The brake pedal rod. Did you have to make one or did the one from the 2004 3500 box van work.
D.B is offline   Reply With Quote
Old 09-03-2023, 07:08 AM   #7
KFF 1
KFF 1's Avatar
I used my 3/4 ton MC. You use the mounting plate on the hydro boost to mount it to the firewall. You will have to drill some holes and mb weld some holes up. The brake pedal rod I just modified by cutting the eye off of the hydro boost rod then used the end of the rod off the vacuum booster and welded it together. Some guys weld a piece to the brake pedal itself the redrill the hole as well. Do a search on here and there are a couple threads that go into greater detail than what I did for this conversion.
Old 09-03-2023, 08:55 AM   #8
kev2809
low n' slo
kev2809's Avatar
sounds like a nice upgrade! mine stops a little sluggish too, I figured because I have over sized wheels. I might have too look more into this down the line
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 09-03-2023, 08:40 PM   #9
LockDoc
LockDoc's Avatar
Glad you got it finished up. Looks like a good install.
LockDoc
Leon
Old 09-18-2023, 06:30 PM   #10
KFF 1
KFF 1's Avatar
This past Saturday we went on the Ohio Historical Bridge Cruise with the C-10 Club of Ohio. 70 mile trip 7 covered bridges. Nice ride, great group of people. This was the 5th year for the cruise and this year was the largest group so far with 31 trucks total.
Old 10-03-2023, 02:18 PM   #11
LockDoc
LockDoc's Avatar
Per our conversation here is the steering box re-seal thread I used. It was posted by TX Firefighter.
http://67-72chevytrucks.com/vboard/s...d.php?t=619634
LockDoc
Leon
Old 10-03-2023, 06:02 PM   #12
KFF 1
KFF 1's Avatar
Thank you Leon, I owe you one
Old 11-21-2023, 12:49 AM   #13
3757chevy
3757chevy's Avatar
Thumbs up Re: New project : 72 Suburban
Looking Good.
MIKE
Old 11-23-2023, 12:39 AM   #14
KFF 1
KFF 1's Avatar
Made a little more progress this evening. Grounds all bolted up, oil pump is primed, fuel lines are hooked up, plugs are in, plug wires are on, and coils are mounted and wired. Hope you all have a Happy Thanksgiving !!!!
Old 11-23-2023, 02:21 PM   #15
LockDoc
LockDoc's Avatar
Sounds like you are about ready to fire her up.
You and your family have a great Thanksgiving too.
LockDoc
Leon
Old 11-30-2023, 10:46 PM   #16
KFF 1
KFF 1's Avatar
Fired up the Suburban last Friday, then came 3 or 4 days of delays. Steering gearbox had to be replaced. Installed it yesterday and bled system so all is good there. Today my Dad and I went for a short ride out the road and back, ran really well but the stall converter is going to take some getting use too LOL. Made some tweaks to the shift points in the tune so if the weather isnt to bad tomorrow I will make another trip out the road and back and see how the Burb reacts to it.
Old 12-01-2023, 01:19 AM   #17
LockDoc
LockDoc's Avatar
Good luck on the drive tomorrow. It just takes a little time to get everything where you need it to be....
LockDoc
Leon
Old 12-30-2023, 12:57 PM   #18
kev2809
low n' slo
kev2809's Avatar
dang that's tough, good thing you were turning into a parking lot
-_--_--_ _________
Old 12-30-2023, 09:21 PM   #19
LockDoc
LockDoc's Avatar
He's had his share of bad luck lately that's for sure. I guess that is the good part.
LockDoc
Leon
Old 12-30-2023, 09:44 PM   #20
KFF 1
KFF 1's Avatar
LockDoc
Yes sir I sure have. Crank sensor, wrong torque converter, intake had to go back to be ported correctly, steering box went bad so replaced it and that one went bad in less than a month. Seems like its been never ending but if hot rodding was easy everybody would do it lol. I will have her back together mid week next week. Then its fingers crossed LOL
Old 12-30-2023, 11:06 PM   #21
3drburb
Good to see you and the family is all safe and well and the burb is also for the most part. Soon you will be enjoying this beauty again and will forget about this. Best wishes with the parts and install.
3drburb is offline   Reply With Quote
Old 01-06-2024, 07:28 PM   #22
KFF 1
KFF 1's Avatar
Thank you 3drburb. Well, the bad luck continues. Installed the replacement steering gear box for the one that failed and while bleeding the system it was leaking from the port for the return line. I figured since the steel return line was original I would make a new one. Same result, so I called Napa and talked to them and the box is going back again. To make matters worse today, I figured I would take a break from the Burb and change the oil in the F-150. low and behold the plastic canister that houses the oil filter element broke. So after numerous phone calls I finally tracked one down at a dealer and at least I got that problem solved.
Old 01-06-2024, 11:36 PM   #23
LockDoc
LockDoc's Avatar
Man, I'm not sure I want to read any more of your posts.... .. It's too depressing!
Leon
Old 01-13-2024, 03:24 PM   #24
KFF 1
KFF 1's Avatar
Finally there is light at the end of the tunnel. Yesterday I picked up the replacement steering gearbox from Napa and installed it last night. this morning I bled the system and no leaks so I proceeded to fire it up and no leaks. So now I just have to wait on some cooperation from Mother Nature before I take it out the road and back.
Old 01-13-2024, 04:00 PM   #25
HO455
HO455's Avatar
Mark today down as a WIN!
RIP Bob Parks.
