Old 08-22-2019, 02:58 AM   #1
Gregski
Gregski's Avatar
HP Tuners Tutorials
with your permission I would like to post some HP Tuners Tutorials for absolute beginners while this stuff is fresh in my mind following my swap. (2001 GMC Sierra donor 4.8L / 4L60e into a 1974 GMC / C10 2WD aka "Rusty...lives")
I have originally posted these on the LS Swapped Square Body GM Trucks ('73-'86 C/K & '87-'91 R/V) Facebook Group receiving positive feedback and a suggestion was made that unfortunately it is difficult to find all prior older posts there and that I may want to find an alternative home for these resources.
so hope you don't mind, feedback and corrections welcomed, may take me a while to reformat them to fit this forum format
================== TABLE OF CONTENTS =======================
--- SERIES 1 - Housekeeping ---
Part I - VATS Delete
Part II - Change the Tachometer RPM output to an 8 cylinder V8.
Part III - Change Tire Size and Gear Ratio
Part IV - Turn Off Exhaust Gas Recirculation EGR. (1999-2001 donor engines only)
Part V - Turn Off the Air Pump.
Part VI - Turn Off Speed Limiter
Part VII - Set Fuel Tank Capacity
Part VIII - Turn Off Catalyst Startup Correction & Over Temp Protection
Part IX - Enable Power Enrichment aka Accelerator Pump / Secondaries
Part X - Customize Torque Management (TBD)
Part XI - Turn Off Traction Control (TBD)
--- SERIES 2 - Codes ---
Section A - Disable the Oxygen Sensors (O2s) Codes
Section B - Disable the Evaporative Emission System (EVAP) Codes
Section C - Disable the Exhaust Gas Recirculation (EGR) Codes
Section D - Disable the Secondary Air Injection Codes
Section E - Disable the Fuel Level Sensor Codes
Section F - Disable the Catalyst System Codes
--- SERIES 3 - Tuning ---
Chapter 0 - To Tune Or Not To Tune
Chapter 1 - Logging (aka the VCM Scanner)
- Channels
- Histograms (Graphs)
- Charts
- Gauges
Chapter 2 - Fueling
Part 0 - Fuel Trims Explained
Part 1 - MAF Calibration
Part 2 - VE Calibration
Chapter 3 - Timing
- High Octane & Low Octane Tables
- Timing Advance vs Base Advance
- Knock Retard
Chapter 4 - Idle
- Idle Desired RPM
- Idle Advance
- Idle Desired Airflow
Chapter 5 - Cruise (TBD)
Chapter 6 - WOT (TBD)
--- NOT COVERED IN THIS TUTORIAL ---
OS Upgrades (1 BAR => 2 BAR, etc.)
Cam Swaps
Injector Upgrades
Electric Fan Upgrades
Turbo Installs
Nitrous Setups
Flex Fuel and Alternative Fuels
A/C Air Conditioning
Segment Swaps (4L60e => 4L80e)
Manual Transmissions
Gregski is offline   Reply With Quote
