Closed Thread
Old 02-07-2015, 06:39 PM   #1726
outdoorsman310
outdoorsman310's Avatar
Re: What did you do to your truck today? Chapter II
I ordered a bunch of parts to convert it back to a standard trans. I believe I still need a mount for the z bar pivot ball to mount it on the block? also I took a picture of my new engine.
outdoorsman310 is offline
Old 02-07-2015, 06:58 PM   #1727
CST10
CST10's Avatar
Drove one to the biscuit run with the louisiana Classic truck club. Then changed the oil in both the 68 & 70 trucks. Been a great day.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 02-07-2015, 07:41 PM   #1728
Possmguts
Possmguts's Avatar
I got the Master Coatings Primer on the frame and Fed-X brought the new drop spindles and coils. Tomorrow Ill be getting the rest of the front end parts cleaned and maybe get them primed and jump to the top coat on everything.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 02-07-2015, 07:51 PM   #1729
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I did it yesterday actually. I installed my old stock rechromed front and rear bumpers and my newly acquired P01's.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 02-07-2015, 11:28 PM   #1730
Chucks72Longbed
Chucks72Longbed's Avatar
Got the heater high speed fan working today thanks to this group. Turned out to be the relay. Ripped out some trailer brake wiring that one of the po's did. Really, old extension cords? I could, see it if it was only temporary but someone went to a lot of trouble and then did a lousy job. Fixed broken lever on the heater controls for defrost. Finish putting back together tomorrow. Changed the steering wheel to a 13 inch Grant. Wow, is that ever better. 6'5" in this truck is pretty uncomfortable with the stock wheel. Try it for a while. May cut a couple inches out of the column later. Really enjoyed working on the old 72. When I look around at it I sure would like to do a frame off restoration. One of these days
Chucks72Longbed is offline
Old 02-07-2015, 11:49 PM   #1731
ole dollor
ole dollor's Avatar
what was the location of the fan relay that you replaced , thanks Don
ole dollor is offline
Old 02-08-2015, 12:01 AM   #1732
Chucks72Longbed
Ole Dollar, It's located on the passenger side of the heater box. If you remove the glove box you should be able to see it pretty clearly.
Old 02-08-2015, 12:03 AM   #1733
ole dollor
ole dollor's Avatar
thank you for the info, yours is heater only right .
Old 02-08-2015, 12:05 AM   #1734
Chucks72Longbed
No, it's a factory AC truck.
Old 02-08-2015, 12:07 AM   #1735
ole dollor
ole dollor's Avatar
ok ,thanks for the info....
Old 02-08-2015, 12:44 AM   #1736
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
My '69 C/10 doesn't have any relay , it's a heater only rig . (for now)
I spent 2/3 of to - day in the back yard beginning re attaching engine accessories , mostly sorting out the buckets of hardware I have collected because the DPM who swapped out the engine used a mis - mash of who knows what hardware , every bit of it Chinese carp , I prefer not only American made hardware but the right stuff from GM , it's scattered all over any Junk Yard in America , you just have to look for it ~ I've been cleaning , sorting , de rusting etc. .
I need to re paint the power steering pump before I do anything else because I'm seeing slight alternator pulley mis alignment ~ it's slightly too far back and before i remove the pulley and shim it , I want to make sure the P.S. pulley lines up with the crank pulley........
I did take some pix but this junky 'puter is running XP Pro and is too slow to download them ~ it always crashes .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 02-08-2015, 07:57 AM   #1737
cooperhw
cooperhw's Avatar
Removed 60 inches of length out of the frame.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline
Old 02-08-2015, 04:22 PM   #1738
hamjet
hamjet's Avatar
Installed pistons on rods, and put them in the block. Found me a 3x2 set up for the go juice. Can't do much outside, its starting to snow. Expecting 8-14 inches
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 02-08-2015, 04:32 PM   #1739
Elliot949
Elliot949's Avatar
Yeah buddy... join the 3x 2 club... LOL
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 02-08-2015, 04:58 PM   #1740
Fakeshemp73
Fakeshemp73's Avatar
Lots of cleaning with a little paint on the frame.
1970 C10
4.5/6 drop from ECE
Body off restomod that seems to be never ending.
Mama Tried...
Fakeshemp73 is offline
Old 02-08-2015, 05:15 PM   #1741
72CampSpecial
This bulging hose..
Is leading to me pulling the intake manifold and fixing that pesky oil leak.. plus new radiator hoses..
Any tips/tricks are appreciated..
72CampSpecial is offline
Old 02-08-2015, 09:31 PM   #1742
texjake
texjake's Avatar
The new bed wood is done!!!
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 02-08-2015, 09:46 PM   #1743
Possmguts
Possmguts's Avatar
Mastercoat is on the frame. It wasnt rusted before, but hey... it will be good for a million zillion years now...
Old 02-08-2015, 10:51 PM   #1744
ole dollor
ole dollor's Avatar
man that sure looks great, I have the head off of ole dollor going to need some head work.
Old 02-08-2015, 11:27 PM   #1745
cooperhw
cooperhw's Avatar
Yesterday I cut out 60" out of my frame so my dually is now 115" and ready for the step side bed. I actually finished all the welding today and plated inside the frame and outside as well. I am also planning to bolt grade 8 bolts through all three to keep it together. Didn't have any paint other that this bright azz silver but I needed to put something on it as I was going to power wash the entire chassis, motor, trans. while my neighbor had one home for the weekend.
Later,
Wayne
cooperhw is offline
Old 02-09-2015, 02:59 AM   #1746
texjake
texjake's Avatar
Thanks Ole, it's been a long time waiting to get that major project done. For it being a LWB let me tell ya it was a royal pain in the arse and will really test a man's patience's. Over 75 nuts, bolts & washers to deal with. And just getting the old rusted ones out will make you say things you might regret later..lol But with my friends shop & lift made it so much better. What was wrong with the head? You getting it milled to boost compression?
texjake is offline
Old 02-09-2015, 11:46 AM   #1747
ole dollor
ole dollor's Avatar
when I got the head off , I found all the exhaust valve seats were sunk into the head , so it looks like the head will have to be rebuilt with hard seats, only a 118000 miles and 44 years , dang what is chevy thinking ..... now off to the machine shop.
Old 02-09-2015, 11:42 PM   #1748
VWNate1
VWNate1's Avatar
Better you should junk it ~ I'll give you decent $ for it ~ I'm going batshyte without my truck and am seriously thinking of buying another just to have one at hand . (gotta be a 6 Banger shortie)
To - day I got off work and ran home to work more on my 250 engine project ~ I cleaned and painted some more parts , rigged up an old 1950's vintage microphone stand to hold the power steering pump whilst I washed it for painting (I already hand removed all the old paint) ~ just as I finished washing it , it tipped over and BANG ! on the concrete , denting the pulley =8-( .
I set it back up and weighted it with an old brake drum , washed and re painted the poor old pump , it already had dents all over & seeped ATF , now I'm going to have to search out another one somewheres soon .
GRrrrrrrrr.....
I then egan re attaching the various engine accessories , discovered the boob who last worked on it lost/didn't have the correct 7/16" USS motor mount bolts so he stupidly used long 3/8" bolts & nuts , ruining the threads inside the new motor mounts ~ good thing I keep all the old junk parts I collect until the job is finished ! I had two more late typ motor mounts , they're on it now plus I still have two original typ motor mounts to give away....
I'm almost finished picking gaskets out of the three V-8 engine gasket kits I have , looks like Vince is first in line for them , I'll never use V-8 gaskets and I can't toss out new parts , he gave me an old AM radio plus much help .
I'm spending hours cleaning , de rusting and sorting original hardware , the boob used almost all new Chinese crappo hardware and I don't want any of that on my truck ! .
I forgot my iPod thing-a-ma-jig @ work to - day else I'd have a picture , soon , I'll take some very soon , it's beginning to look nice again .
Maybe address the tranny this weekend and get it installed .
-Nate
Geezer
VWNate1 is offline
Old 02-10-2015, 06:25 PM   #1749
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Today it was the third half day on the dash re-install. And, more to the point of the work, the shortening
of the steering column.
I have to say that I've replaced columns before by myself in a "done" truck. It was easier than this.
And, I've installed them *during* a build. That's a snap.
But in the last three days, I've been struggling. With the dash out, I've had to take the column in and
out and in and out and in and out.
Measuring and mis-measuring, the big "tear" column thru the firewall gasket on the wrong side of
the reverse switch, reverse switch in the way of the fire wall, reverse switch outside (engine side)
of the firewall won't "let" the firewall column bracket and clomp install, etc., etc., etc.
I finally figured that my problem with the reverse switch, on this tilt column, would require either that I
don't pick up more than about 1/2" of steering wheel/seat clearance, major metal surgery would
be required at the point the switch comes in contact with the firewall and bracket, or ditch the mother-loving
reverse switch all together.
I chose the "wanting more room" option. I drive about 0.03% of the time in the dark. But, I'll still install a
manual back-up light switch in an existing hole out of sight below the dash.
Problem, too, is that when I'm doing silly s%$t like this, I always think in terms of "do no harm".
Well, frustration, and bad angles and solo wrestling with a part that has pivot "knuckles" and doesn't want
to move anywhere near the way you think it will move, on top of and missing lunch..... all add up to scratches.
Oh, well. At least when I'm done, I'll have the extra room.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-10-2015, 07:27 PM   #1750
85burb
85burb's Avatar
My tires I ordered came in today. Went home and took the wheels off and put them all in the back of my suburban and called around and no one will mount them tonight. Now I have to wait tell the morning. Dang it!
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline
Closed Thread
