Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-27-2012, 07:18 PM   #1751
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Trying to assemble theses parts next
Seems that both jaws are not the same, will have to determine which goes where. Does not say anything about it in the service manual
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-27-2012, 08:10 PM   #1752
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: PO has me PO'd
Not sure it matters. All it does is provide the indent for where the pin goes for each position of the tilt. Thats why it's staggered like that. Should move and stop in each position regardless of which way you install them. I was trying to see if I had pics from when I assembled mine, but couldn't find them. But I really don't think it matters.
hgs_notes is offline   Reply With Quote
Old 01-28-2012, 12:54 AM   #1753
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for your reply, ill check it out. Maybe, ill pull the springs out, and see how it works
SAFETY FIRST
AS usual, off topic
Jim
Old 01-30-2012, 09:08 PM   #1754
keanevann
Re: PO has me PO'd
here ya go bud...they've never been out.....
keanevann is offline   Reply With Quote
Old 01-30-2012, 09:47 PM   #1755
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thank you for your time...saves me. Service manual says to use a soap based grease, think it matters
SAFETY FIRST
AS usual, off topic
Jim
Old 01-31-2012, 02:02 AM   #1756
keanevann
Re: PO has me PO'd
You're welcome..... glad to help. I pulled this off of Wikipedia .... "In the context of lubrication, grease typically applies to a material consisting of a soap emulsified with mineral or vegetable oil." So personally I don't think it matters.... I always use the same grease I use on my ball joints haha
Old 02-13-2012, 08:50 PM   #1757
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Found it was easiest to clamp the bowl to a work surface, gave you two hands to start the retaining pin
Not much to put the turnsignal switch in...
Waiting on the bearings to come in from Wes, Classic Heart Beats. Thanks kean for getting me back on track with those photos
SAFETY FIRST
AS usual, off topic
Jim
Old 02-13-2012, 09:03 PM   #1758
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Finally got the brush guard ive been looking for
SAFETY FIRST
AS usual, off topic
Jim
Old 02-13-2012, 09:22 PM   #1759
rsavage
rsavage's Avatar
Re: PO has me PO'd
Nice guard there!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-13-2012, 09:48 PM   #1760
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Found out that if you push in the two side tangs from the front, you can use the channel locks to press out the connecter. Luckily the tangs are not spring steel, so once you push them in, they stay in, so it makes it easier to extract them. Dont forget to bend them out when you are ready to install them
You can just make out the two side tangs
SAFETY FIRST
AS usual, off topic
Jim
Old 02-13-2012, 11:24 PM   #1761
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Trying to figure out how to fix my heater control, seems that a number 4 screw would fit, so i can drill and tap. Used my dremel cutoff wheel to get rid of the burr on the rivet, now it will act as a alignment dowel. Just have to drill the center
SAFETY FIRST
AS usual, off topic
Jim
Old 02-14-2012, 01:27 PM   #1762
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: PO has me PO'd
J, why are you running two cruise switches? Just trying to see which one you like better? Is that a vacuum setup or newer?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 02-14-2012, 04:36 PM   #1763
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ding ding ding, we have a winner you get to choose one of the following great prizes from my pile of parts....list to follow, come on down Red
Actually, the master cruise switch looks like a dealer installted option, so i will be opting for the turn stalk switch....thought i could use both, but M&H says i cant
Vacuum, that is another story. Was goning to use a air pressure gauge, for my compressor, but decided a vacuum gauge would be more usefull in keeping my foot outta the throttle....WOT
Found it on the classifieds, so im guessing its stock
SAFETY FIRST
AS usual, off topic
Jim
Old 02-14-2012, 06:10 PM   #1764
red71cheyenne
Back in the sticks
Re: PO has me PO'd
hehe, I think I may have mixed my metaphors or something. I meant was your cruise system a vacuum operated one...Do you have a vacuum guage too? I put one in my Blazer too, but still haven't figured out what it is telling me.
That stalk kind of looks like the one I have on my 71 pickup. Its a 73 and up aftermarket system that Sears used to sell. It ran off of vacuum and a magnet on the driveshaft for speed input. Mine has a slide on off switch too, though.
2011 K1500 Suburban
2014 K1500 Pickup
Old 02-14-2012, 11:15 PM   #1765
keanevann
Re: PO has me PO'd
[QUOTE=jaros44sr;5186429]Found it was easiest to clamp the bowl to a work surface, gave you two hands to start the retaining pin
You are welcome sir....I try to give back what little I can to a forum who has helped me SOOOOOOO much....
Old 02-15-2012, 12:17 AM   #1766
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK! Now i see what your asking....it is operated by vacuum, brake pedal cuts out vacuum and electrical
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2012, 12:19 AM   #1767
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[quote=keanevann;5189038]
Cracked me up when i read your reason for editing
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2012, 12:30 AM   #1768
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Think ill paint it black
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2012, 09:28 AM   #1769
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: PO has me PO'd
Not black, I'd have it powder coated a chrome or bright silver.
Old 02-15-2012, 04:42 PM   #1770
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
How about if we split it half way...mixed transtar gravel guard (white), with eastwood sprayable undercoating(black) and came up with a grey.
Finish has to be brush/roll on, durable. Powdercoating is out right now, dont have access to a large oven, yet!
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2012, 05:38 PM   #1771
VA72C10
VA72C10
VA72C10's Avatar
Re: PO has me PO'd
How close is it to the rings/buckets? I'd think it would look better if it matches spot on or is black or bright silver like the trim.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-15-2012, 06:34 PM   #1772
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: PO has me PO'd
I vote for black.
ETsC10 is offline   Reply With Quote
Old 02-15-2012, 07:22 PM   #1773
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by ETsC10 View Post
I vote for black.
Grille rings are graphite, headlite buckets are argent silver, polished aluminum trim, chrome bumper, body color is flat white.....so, thats why i thought black
SAFETY FIRST
AS usual, off topic
Jim
Old 02-17-2012, 01:15 AM   #1774
low'n slow
low'n slow's Avatar
Re: PO has me PO'd
Nice guard. Do you want it to stand out or blend in? Black for the first and white for the second. I vote black.
low'n slow is offline   Reply With Quote
Old 02-17-2012, 01:26 AM   #1775
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
That is a good question, and one that i do not know the answer too.....now you got me thinking
Maybe i should run a poll and let that answer my situation, dunno
SAFETY FIRST
AS usual, off topic
Jim
