#1776 |
![]() Join Date: May 2006
Re: PO has me PO'd
Gravel Guard seems to level everything out, so no need for tedious prep work. Probably paint it spot on, as Jonathon suggested and go with a graphite to match my grille hoops
GONE FISHIN'
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#1777 |
Re: PO has me PO'd
Have fun, good luck, and be safe.
#1778 |
Re: PO has me PO'd
Fun is a definate, luck is debatable, and safe is a thought, practice! Thank you, just nice to be able to hang out with my sons and be away from WORK....
#1780 | |
Re: PO has me PO'd
#1781 |
Re: PO has me PO'd
You're back. How was the trip? Pics? Get the fish smell off your hands yet?
#1782 | |
Re: PO has me PO'd
Balmy 17 degrees in the morning ![]() Still waiting on my bearings, seems Wes's roof fell in, and lost some of my contact info. which caused the delay...never heard that one before ![]() Picked up the last pieces of my speed warning speedo, pretty excited to start that mod.
#1783 |
Re: PO has me PO'd
Thanks Wes, got the bearings and othe r parts in today, even with your roof falling onto your motorhome, you still had time to get my parts out... What a guy!
#1784 |
![]() Join Date: Apr 2010
Re: PO has me PO'd
Where did you Drop the hooks?
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
#1785 |
Re: PO has me PO'd
Salmon river, Pulaski, NY. about an 1/2 hour north of Syracuse
#1786 |
USMC
Re: PO has me PO'd
your skill, patience, and determination is outstanding. You have a work of art on your hands. I let life get in the way of mine and it sits waiting on me.
Nice job. Semper Fi.
Semper Fi |
#1787 | |
Re: PO has me PO'd
I really feel like this year is the one where i get to drive it Semper fi
#1788 |
Re: PO has me PO'd
Bearings in, weird on the wedge, never saw a bearing race installed like that...service manual says to run the nut down until all the space is taken up, then give it a 1/16 - 1/8 turn more. Make sure the streering shaft is straight, when you tighten the retaining nut
Finally, the tilt works....last part of the puzzle was to install the spring to control the return, just a phillips screw driver and alot of pressure ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-05-2012 at 02:55 PM. |
#1789 |
Re: PO has me PO'd
Got the wires fed thru the chase, canceling cam installed as well as the adapter for the wheel...getting close to getting outta this mess. Strip and paint cover, probably black
#1790 |
Re: PO has me PO'd
Yep, you guessed it....turnsignal/cruise stalk, as well as turnsignal switch screws have to be removed to get the cover plate on, if you have the red hazard button...
Thats it, next time ill get the three pieces powder coated grey
#1791 |
GEARHEAD
Re: PO has me PO'd
I bet I took mine apart and back together 3 times before I got it right. What sucks is that afterwards I found the hole where the blinker handle screws in had cracked. PITA to swap out so I left it as is. Mine needs repainted and I'm thinking I might just buy a nice shiny aftermarket one and sell mine.
Yours will be solid though once it's painted. Looks good.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy)HG's Plow Truck '78 K35 DuallyBigass Farm Truck HG's thread of miscellaneous stuff |
#1792 | |
Re: PO has me PO'd
Blinker, havent heard that in awhile ![]() Nice work on the ws frame repair
#1793 |
Re: PO has me PO'd
How you do that Jim.I have a tough time figureing out how to get the Horn cap/retainer working,and It still dont work LOL .Nice work
#1794 | |
Re: PO has me PO'd
spent the last week trying to figure that system outWierd, but back in HS when my father gave me the families '62, the first thing i did was the same type of steering wheel and cragers, had problems then, 40 years later still have the same problems. Youd think they wouldve redesigned it by now
#1795 |
I miss this truck.
Re: PO has me PO'd
Jim, been a while since I stopped by, but I'm caught up. You are definitely in what my wife calls "the fiddly work" of the project. Tedious stuff, but I love when somebody takes the time to do it right.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#1796 |
Re: PO has me PO'd
Thanks for stopping by, tynee. Say hi to the wifey for me...
Trust me, if i do something wrong, ive got a whole bunch of guys on this forum ready to let me know ![]() Had to hold up on my project for some house work, just three weeks! Ordered some parts while i was busy doing electrical Billet hood hinges Electric water pump with port for heater hose Valve covers Speed warning head and tin Every time i think i have the cooling system cured, something changes and i have to rethink, redo the system. This could be the last time. Change the outlet on my rad. to accept 1 3/4" hose, mandatory for the 50 GPH pump. Just got done collecting all the fittings in 1 1/2" aluminum, w/ pipe 70shortfleet did an excellant job punching out my non tach tin, and sandblasting, painting
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-12-2012 at 03:35 PM. |
#1797 |
Re: PO has me PO'd
Out with the old, in with the new....2003Silverado nailed the problem right away, seemes that i dropped my neutral, all the years of the shielding passing thru the wall corroded my shielding on my main cable. I think Edison installed my electrical power, right after the block in Brooklyn
![]() Nice work by Les. quite the drama down in the classified on this purchase, but Mel being the good board member he is, got me thru it S/B the last upgrade on my dash, steering column. Now to move on to other problem areas
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-12-2012 at 12:28 PM. |
#1798 |
Re: PO has me PO'd
Thanks Jim for the That a boy ,29yrs In the trade you see/and deal with all sort of things.Wish I could have helped out more. when you coming for a visit?
#1799 | |
Re: PO has me PO'd
![]() Think the smithsonian might want my panel box for a exhibit ![]() Funny, John and I were just talking about stopping up, but my family just had two deaths in a week, so it might be awhile Sorry for no updates, but parts wont be in till next week
#1800 |
Re: PO has me PO'd
Jim, I'm sorry about the deaths in your family. that has a way of keeping things in perspective.
You're making slow and steady progress, that's a lot better than some of the rest of us. |
| Bookmarks |
