#1776 |
![]() Join Date: Aug 2009
Re: What did you do to your truck today!
Well Sunday morning I installed my new front suspension. I installed new upper and lower control arms, air bags and new 2" dropped spindles all from CPP. I also got the rear end re-installed with new trailing arms and drilled and slotted rotors and new posi unit etc. Also got my new wheels from Race Line with new BFG KDA's. I will post some pictures in the next days or so. Hoping to get the new LS3 installed this next weekend!
Pictures are posted in my album Last edited by nick martorano; 03-01-2011 at 12:27 AM. |
#1777 |
Ok thanks I'll keep an eye on it.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#1778 |
Cleaned and painted the emergency brake pedal assembly and the flat plate that mounts with it under the dash.
#1779 |
put the fuel tank back in and cleaned the hoses should have it started agian since the 7 years its been sitting
#1780 |
I drove it to the body shop thats going to do my rust repair to get my parts list in order and bought a perfect original Fleetside tailgate to go on it when its time. Now I have a spare if something happens later on down the road. Looks like my truck will be rust free very soon.
#1781 |
Got some more of my door rubber installed.
#1782 |
This is lame but I can't help myself, I drove mine to work today. That's always good.
#1783 |
Tore down my tie rod ends and cleaned up the rest of the steering components
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
#1784 |
started the 69 camAro gas tank swap
#1785 |
I installed an OG 69 Guide Right side turn signal lens that I found on eBay. The old one was broken and then patched up with epoxy that yellowed.
I put a cigarette lighter into the socket. I bought a lighter assembly that came from a GMC from tll74 on this here site. I needed a lighter to fill the empty hole in the dash. It matches my Chebby just fine.
#1786 |
worked on the finishing touches to gather a shape to my center console
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#1787 |
kacz81,
Keep us posted on how it goes. I did this a few months back and I love it.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#1788 |
Sofa King Crazy!!
#68608 Hedmann Heders from Summit, $333 shipped.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#1789 |
Bought a Painless wiring harness.
#1790 |
#1791 |
S.D.M.F.
i havent got to touch or dirve my truck for a week...
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() |
#1792 |
![]() Join Date: Jul 2010
Replace a bad exhaust/intake gasket on my 250 L6. There was an exhaust leak that sounded terrible. I repainted my shorty headers since they were off.
#1793 |
You can say that again about the gas, it nuts over here, we are paying $1.18 per litre (there is about 41/2 litre to a gallon here) do the math..it bites.
68 ![]() My other ride ,,, 07 Streetglide.. |
#1794 |
C/10 junkie
Thank you Slick67
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#1795 |
block sanding on doors..(again, seams like i will never get done with block sanding) started working on fenders..and got jeep out of gararge and ran it for a bit..also got a box of goodies from H & H classics today..
#1796 |
Found out my trans filler tube is leaking at the trans....
Now trying to figure out how to fix it... |
#1797 | |
Still plays with trucks
I have made my own from junk yard donor parts when I couldn't get a new one to fit my needs. Cut off the sleeve type seal from the donor part and weld it to the original O-ring type tube. You have to cut some length off of the original tube to seat the seal properly and get the right fluid level reading.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#1798 |
Pulled the tired 350 and 465 trans out of my stepside this afternoon. Also sprayed down the engine bay and un bolted the radiator support. Makin some progress!
#1799 |
Between Trucks...
Fixed my aftermarket wiper washer pump. Simple fix, needed to come apart and a quick lube to the pump mechanism.
Beat it to fit, Paint it to match... ![]() |
#1800 |
Drove it for the last time possibly this year. She is coming apart for rust repair.
