Old 11-01-2011, 11:51 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Looking good.....although you really need to clean your bed
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-01-2011, 11:55 PM   #2
71Sleeper
71Sleeper's Avatar
I got the same advice on mine to.
71Sleeper is offline   Reply With Quote
Old 11-02-2011, 12:01 AM   #3
VA72C10
VA72C10
VA72C10's Avatar
BTW....you're nearing #1 on the views.....231K+ as of tonight!
Old 11-02-2011, 09:28 AM   #4
67cheby
67cheby
67cheby's Avatar
i know it is a little petty thing but with the work you have put in , i think those bolts through the bed floor need to have a round head instead of the hex head to blend in better, maybe a round allen headed bolt ?
67cheby is offline   Reply With Quote
Old 11-02-2011, 09:45 AM   #5
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
I agree completely, but since the bed floor is so rough I am rhino-lining and covering the whole thing up with a rubber mat. Since it has to be covered up anyway, bolt heads don't really matter.
Since I am planning on using the truck, I figured it was insane to spend $1000 on a bed floor and then worry about denting or scratching it. Yes, I hope the truck is magazine worthy, but that is a secondary consideration to my using it everyday.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 11-02-2011, 11:36 AM   #6
jb1016
"Oh well, it's a driver."
jb1016's Avatar
The fact that you plan to use it is the best part of the build. I hope you get to put as many miles on it as the build has had views!
Old 11-03-2011, 01:32 AM   #7
drewskiren
drewskiren's Avatar
Tonight's episode begins with painting the radiator support and new radiator mount satin black. A few more coats tomorrow and it will be ready to assemble.
Then I moved on to the shift linkage. I welded and extension on the shift ear I cut off to clear the brake booster, then assembled the Kugal stainless steel shift linkage. http://www.kugelkomponents.com/zenca...&products_id=6
I very carefully fit and adjusted, then shortened the rod twice so as not to cut too much off at once. The throw is now perfect and I get all gears to click nicely, it even lines up on the column indicator right.
Then I read the wiring diagram and ended up only needing one wire on the right electrical block -green temp sensor wire for gauge. I may want the switched brown wire for something, so I left it for now.
Drew
Old 11-03-2011, 01:50 AM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Little by little.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-03-2011, 01:58 AM   #9
drewskiren
drewskiren's Avatar
Originally Posted by Dieselwrencher View Post
Little by little.
Exactly.
Drew
Old 11-03-2011, 02:51 AM   #10
71Sleeper
71Sleeper's Avatar
Little by little.
And soon there will be little to do.
Old 11-03-2011, 04:34 AM   #11
72shortstep
lovin' the lowcountry
72shortstep's Avatar
Are you keeping the mechanical fan or going with an electric set-up? sorry if you already answered this but that chip in the fan blade made me think about it, haha.
Chris
29461
72 SWB stepside
71 SWB stepside
DRIVE IT LIKE YOU STOLE IT!
72shortstep is offline   Reply With Quote
Old 11-03-2011, 09:07 AM   #12
drewskiren
drewskiren's Avatar
Mechanical, because it is free and installed!
Drew
Old 11-03-2011, 04:26 PM   #13
drewskiren
drewskiren's Avatar
These pics are more fun to look at.
Where do these little square rubber blocks go? They came with my tailgate bumpers kit.
Drew
Old 11-03-2011, 02:36 AM   #14
VA72C10
VA72C10
VA72C10's Avatar
More good progress. Shift linkage looks good as does the rad support!
Old 11-03-2011, 04:58 PM   #15
67cheby
67cheby
67cheby's Avatar
SWEET they are bumpers for the tailgate !!
Old 11-03-2011, 05:00 PM   #16
drewskiren
drewskiren's Avatar
Where?? got a picture?
Drew
Old 11-03-2011, 05:14 PM   #17
notsolo
notsolo's Avatar
This 1 is on a Blazer not mine. Focus was on the weather strip. hope that helps. DREWCAB is AWESOME.
notsolo is offline   Reply With Quote
Old 11-03-2011, 05:30 PM   #18
drewskiren
drewskiren's Avatar
AHA! They probably keep the straps from rattling.
Drew
Old 11-03-2011, 05:54 PM   #19
7dee2
7dee2's Avatar
Thumbs up Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Wow, I love this project!
I miss my 99 Crew Cab Dually terribly. Great idea's with cab configuration, drive train choice's and even the new factory style wheels. Surely magazine material and reliable daily driver.
Subscribing!
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 11-03-2011, 05:01 PM   #20
Pop's C-10
Pop's C-10's Avatar
Have you thought about doing tha stop light mod that i've seen on here using that factory cargo light..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-03-2011, 06:23 PM   #21
noonzor
still cant believe how fast your moving on this project, makes me feel like a slacker!! excellent work!!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 11-03-2011, 06:54 PM   #22
VA72C10
VA72C10
VA72C10's Avatar
Looking absolutely GREAT!!!
Old 11-03-2011, 07:09 PM   #23
oldman3
oldman3's Avatar
Great job Drew, looking better each update...JIm
oldman3 is offline   Reply With Quote
Old 11-04-2011, 08:36 AM   #24
BluTrukker
BOHICA
BluTrukker's Avatar
WOW! Took me a whole week to get through the entire thread. You do top notch work! I have kicked around the idea of doing something similar. So now I have a step by step guide! I know its a little premature, but I was wondering if you have kept track of total cost? It would be interesting to compare the differance between the cost of buying a new truck, and what you have done. Again, Awesome work!
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 11-05-2011, 01:20 AM   #25
drewskiren
drewskiren's Avatar
Got to have a go pedal!
Call me a weirdie, but being a pack-rat comes in handy when you need to blend vehicles together. I cut the tip of the new pedal off and welded it to the old pedal rod since it had the perfect end hole to mate up with the new truck throttle linkage. Now the rod end and cable are back together once again.
Clean up and paint.
Drew
