#1801 |
Re: Kabwe's aka Bam's build
Glad to see you back at it. Cant wait to see this one done.
#1802 | |
Grand PooBaa Member
LMAO!!!!! But BajaBob is right, you do set the bar high. Its all good, just makes the rest of us strive to build our trucks by following your lead. Brothers 2020, heck I think I might be ready by then also. ![]() ![]() |
#1803 |
Frame work looks awesome!
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
#1804 |
Damn Bam ! That is a really sweet setup! Def worth redoing a few things. Good meeting you on Saturday and Choppin it up.
#1805 |
That's cool, but now i have to make sure that I keep telling myself "I will not cut mine up again and follow BAM"
#1806 |
Certified Car Nut
Thanks guys.
Hopped up it was great to finally meet you. Vdog finally made things right.lol |
#1807 |
Grand PooBaa Member
#1808 |
![]() Join Date: Mar 2005
Nice work, Bam! I know exactly what you mean about doing something and then tearing it all out later. I've doing it for years!
Don't tell anyone, but I've been working on my '55 for the last few days. The Old Girl needed some love, and I spent the last couple of days going through all my parts and doing an inventory. I've got a game plan, and want to have it at a certain point before Father's Day. Gotta set some goals!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#1809 |
Certified Car Nut
Thanks guys,
The set back of installing the x member means I can no longer use the factory brake assembly. So here is my brake bracket I fabricated. As you can see I also had to notch the frame to have clearance for the Hydroboost unit. ![]() ![]() ![]() ![]() ![]() I already modified the panel assembly, all that is required is a push rod extension but I think I better wait until the cab is back on to mock it up so that I know the brake is in the right spot. |
#1810 |
56 - autocross
Bam is back in business!!!
#1811 |
Tight fit in there!
Looks great!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1812 |
Nice job on that stuff Bam.
Kim |
#1813 |
![]() ![]() Join Date: Nov 2008
"HE'S ALIVE!, HE'S ALIVE!"
![]() Nice restart. I like it, very nicely done. What's next?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#1814 |
Great looking truck project. I'm building a 56 stepside shortbox to mount above a newer Yukon or Tahoe 4x4 chassis. I've got a lot of patch panel and dolly work behind me, but still need cab corners, steps, rails, etc.
I just found a 56 car dash and was wondering if ya had any tips or tricks for the swap? I dont have the dash out of the car yet, so Im starting fresh. thanks, appreciate any advice, Dave |
#1815 |
Certified Car Nut
Here is the piece I fabricated for the pedal assembly.
![]() After a lot of measuring here it is tacked in place. I'm going to leave it tacked until the cab is back on the frame, because I may have to move it a little bit. ![]() Here is the pedal installed. Yes the push rod connection clears the bottom tube by about 1/2 inch. As you can see I need to make or purchase a longer push rod extension. ![]() |
#1816 |
Nice fab work Bam.
Kim |
#1817 |
A320 Pilot/USAF Retired
Very nice!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#1818 |
![]() Join Date: Mar 2011
Looking good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1819 | |
I think Im gonna clevis the Booster end, then tap one side LH thread and one side RH thread on the rod. With RH and LH rod ends this will make it adjustable in place. lookin good!
My Build: 57 Chevy Pro-Street |
#1820 | |
#1821 |
Grand PooBaa Member
Some impressive work Bam.
#1822 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice work Bam!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1823 |
Looking good Bam!
I finally got my chassis sorted out. Mounted the m/c just under front of bed. Need to make and extension too. . |
#1824 |
Mr. Bam you're the man. Your creativity is exceptional. What Hydro-boost are you going to use? New? salvage? Dodge? Chev? I sure hope that truckin gods smile down upon you and you're blessed with time, health, and fundage to keep on truckin. Be safe Chase
Been there, wrecked that ![]() |
#1825 |
Certified Car Nut
