03-08-2017, 04:22 PM | #1801 | |
Re: Danny Boy is BAACK! w/ '55 Big Window
PS: I went back and looked at the VIN and it looks like its the 20,063rd truck built. That's a LOT of damn trucks built. No wonder they are still all over the place. Also, I assume that's its number from the LA plant, right? They didn't keep running track of them coming out of each factory - no computers to tie the factories together in those days!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 03-08-2017 at 04:34 PM. |
03-08-2017, 05:04 PM | #1802 | |
Yeah, I didn't know if there was anything to be gained from using it. Maybe a little less heat soak coming into the cab?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-08-2017, 10:28 PM | #1803 |
Thanks for the info!! Hoping to set engine and trans this weekend. It appears to have plenty of room.
Mark |
03-09-2017, 09:33 AM | #1804 |
In the top of that link it says: "The second section, all numeric, is the plant production number, with the first truck built at a given plant receiving the number 001001."
So I assume it was #020063 minus 1000 to come out of LA that year. Might be too early for paint, My '59 has a tag on the front driver pillar with a specific "Paint" line item, 704A is Sherwood Green. I think the color you chose looks great! Truck is really coming together nicely! |
03-09-2017, 11:11 AM | #1805 | |
That color is fantastic and never being sanded yet? Wow, it's beautiful.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
03-09-2017, 12:28 PM | #1806 |
Thanks so much. I'm really happy with my choice so far.
I'll check in at both shops today or tomorrow. Nothing had been done on the chassis as of Tuesday. Hopefully some progress has been made by now. In the body shop I expect the underhood and possibly the miscellaneous interior parts I dropped off the other day have been sprayed in color too.
03-09-2017, 07:19 PM | #1807 |
Thursday, March 9, 2017
No invoice this week (Good!) so no progress (Bad!) but the trans crossmember is finally back from powder coating today. I thought you guys might like to see some of the other cars/trucks in the shop. Mike JUST got in this '58 short Fleetside. Apparently the owner has had bad luck with shops. It's been under construction over 5 years(!) and still isn't complete. Mike is to fully complete it so the owner can drive it home. Needs mostly interior reassembly and wiring, debugging. It's a conventional small block and four speed manual: Mike liked the backpacking on the rims and wanted me to see them. 245/45x17 in front and 275/40x18 in the rear. Coddington Junkyard Dog rims, I think. Personally, I prefer the same diameter rim front & rear. Originally, I wanted to use my 15" Torq Thrust wannabe's - they can't fit over the calipers. 16's do but there's no selection in 16's anymore. So on to 17's, BUT the rims I want come in 7's & 8's only & low profile tires don't give enough height a decent RPM at 70 MPH. I want to be in the low 2000's at 70 with 3.73 ratio when I drive up to see my granddaughter (220 miles). So I MAY have to consider 18's (ugh). I can get rear rims in 9's & 10.5's making my tire height over 28". I like more sidewall on older vehicles. I'd use 275 or 295/40's. I'd prefer 50's but only seem to come in winter tires or SUV/Crossover tires. Anyway: I think the lip on these is a bit too deep. Younger guys can't get a wide enough lip. Gotta know when to "lift the brush" - and I may well have (far?) exceeded that already! Ha ha
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 03-09-2017 at 07:40 PM. |
03-09-2017, 07:42 PM | #1808 |
Other cars currently is the shop (this is NOT all of them). There's a Mucielago (sp?) in there too.
1966('67?) SS396 Chevelle. Probably a clone but I didn't ask and don't care. Still a great car: A non-frame off rodstoration '61 or '62 bubbletop with an LS: Same early Mustang fastback has been there awhile. I'm not a Ford guy and wouldn't choosethese rims for it, BUT admit I like early Mustangs. This one is immaculate up close:
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 03-09-2017 at 07:54 PM. |
03-09-2017, 08:02 PM | #1809 |
A couple complimentary photos because i like them!
I think the olive interior with rich cream exterior is very attractive. I'd look for the Fleetside spear chrome for it too. This chrome bead lock AND deluxe cab trim doesnt look as overdone as i tend to think it would. Maybe its because it jazzes up the white body, i don't know.
03-09-2017, 08:41 PM | #1810 |
Speaking of lifting the brush, go with 18s! They are the sweet spot imo. I believe the wheels on the fleetside are Boyd coddington "smoothies". I would seriously consider hitting up Chris Coddington for a genuine set. Just down street...
03-09-2017, 09:24 PM | #1811 |
Who is "just down the street"? Chris Coddington? I wasn't aware.
I don't think I want these rims. I actually kind of like them but not sure they're right for me. My real taste is the old fashioned gray spoke, machine lip 15" original Torq Thrusts. Since I cant use them I'm tending toward the next closest thing which for me is 17" Coy C5's with gray spokes. But if i were going to higher dollar rims they'd probably be Billet Specialties Legacy 2's. As for 18" versus 17" tires there is just more selection in 18's (by far) and in general they're cheaper too. I assume because they sell more of them. I guess I'd be ok with 17x8's in the rear but I'd like 9's or 10.5's but to get those I have to use 18's or POSSIBLY get Coys to custom make wider ones, but again the availability of wide enough tires becomes an issue.
03-09-2017, 09:34 PM | #1812 | |
Here's the comparison. The Fleetside has the Junkyard Dogs....i like them. I think I like the Smoothies a bit better though.
03-09-2017, 11:42 PM | #1813 |
Wheel selection is challenging....back when we had fewer choices...sure I will take the Cragar SS. Not many others available then.
Those wheels look very good. Nice looking projects in the shop too. Appreciate the share. |
03-10-2017, 11:05 AM | #1814 |
Hey Dan, can I ask a big favor? If your guy there at the shop painted that bubble top, can you ask him what that color code is for the white? been looking for something specific and seen on a vehicle instead of a color chip. Thanks for the share!
appreciate it. paul
My Build: 57 Chevy Pro-Street |
03-10-2017, 11:12 AM | #1815 |
Paul,
Sure I'll ask. I truly don't know if Mike's paint shop sprayed it or not. He used to use Marcos, the guy doing my truck til he established his own shop. Still uses him occasionally if he gets overbooked or behind.
03-10-2017, 01:06 PM | #1816 |
Paul,
Color is original 1961 Ermine White, 886-93774-L. Mike's shop did not paint it.
03-13-2017, 09:02 PM | #1817 |
Awesome Dan Thank You -
03-13-2017, 11:23 PM | #1818 |
Your build is coming along nice. It's looking good.
03-14-2017, 12:52 PM | #1819 |
A320 Pilot/USAF Retired
Here's a link to a tire size calculator, you can put in different sizes to compare diameter and sidewall heights and it will also show which brand makes them!!
https://tiresize.com/calculator/
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
03-14-2017, 01:26 PM | #1820 |
Thanks very much JJ, super helpful!
I've been hand calculating diameters and then manually looking up tire sizes on Tirerack - tedious, slow and many times there wasn't a size made that I'm searching for. Are the tires referenced on this site current? PS: What do most guys use as a "rule of thumb" on max tire width on a given rim width? For example, an 8" wide rim converts to 201.6mm wide(25.2mm per inch). I assume I would use a tire that is approximately 1" wider than the rim, so 225mm though I know I can go somewhat larger. The question is how much larger? I don't think I'd be too worried about going up to say 245 or even 255, but that's just a guess. I don't want ridiculously pinched sidewalls. I don't think my front rims/tires will be too much a concern. But the rears may. I'm considering a 9" rim and possibly larger.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 03-14-2017 at 01:34 PM. |
03-14-2017, 09:10 PM | #1821 |
A 245 will easily fit on a 8''rim. I have 235 on my front wheels which are 8".
Some tire sites state the min and max rim width per tire size.
03-14-2017, 09:19 PM | #1822 |
Thanks JJ. Yeah, I know the 245's will fit fine on an 8".
I'll most likely use 7's in front but 8's are a possibility. It's the rears I'm having trouble deciding on. I can get 9.5's if I wait 60 days - and I have the time. 9.5's would make the rim just under 240mm wide. So I could use 275's, possibly even 295's but I have to wait til the bed is installed before measuring to see if I have room. I don't want ANY rubbing, no fender rolling, no crawling over speed bumps or entering driveways diagonally. I'm too old for that BS.
03-14-2017, 11:39 PM | #1823 |
these are both really cool but i would agree with you the smoothies are an older look to me, fits the truck better. Just me though.
03-15-2017, 07:18 PM | #1824 |
Wednesday, March 15, 2017
No photos, just an update for my "Log." Stopped by the bodyshop. The exterior of the cab, front fenders & hood will be sprayed this week according to Marcos - we'll see. Another week to dry, sand & the last three clear coats sprayed, etc. The front fenders were guide coated, one had been final blocked prior to color. I'm glad I got to see this. I'd forgotten to ask about seam sealer so he showed me the whole interior of the cab had been sealed and another sealer used in the rain gutters. At Mike's shop the master cylinder & trans crossmember had been mounted. He's reconnecting the fuel lines and bending/mounting the brake lines this week. We also discussed him fabbing the exhaust up to the rear axle. He'll wait to finalize it once the bed is done and mounted. He and Marcos will coordinate directly to deliver the cab/front fenders to be mounted & doors & hood gapped so Mike isn't responsible if anything is chipped. I have to get new body mounts. I'll get out to The Car & Truck Shop for those. That's it for now. It's progress. I'm still pressing for paint completion by April 1 - doesn't quite seem like they'll make it but close. Then the whole thing done by Memorial Day - we'll see!
03-17-2017, 06:35 PM | #1825 |
Friday, March 17, 2017
Marcos decided he should have painted the firewall when he painted the cab interior. He went ahead and sprayed it this morning. Said the cab exterior, front fenders and outside of hood will likely get sprayed Monday. I was hoping they'd be done today...but I'm pleased some got done this week. I keep trying to accurately capture the color. It doesnt photograph well. The Sun makes it look too orange, flash makes it look too bright. But this shot is very close:
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 03-17-2017 at 07:01 PM. |
