Old 03-17-2017, 06:51 PM   #1826
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Danny Boy is BAACK! w/ '55 Big Window
The brake lines are nearly all bent and mounted. I'm very pleased with how clean Mike works. Here's the master cylinder lines in:
These little stand offs will be TIG'd and minor touch up done:
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-17-2017, 08:00 PM   #1827
oldman3
oldman3's Avatar
Dan, love the color, line work is outstanding...Jim
oldman3 is offline   Reply With Quote
Old 03-17-2017, 08:11 PM   #1828
Dan in Pasadena
Thanks Jim. I know nothing about bending brake lines but I know neat and a "thought-out" appearance. These pass my uneducated eye test.
I noticed one line appears to touch the rearend vent but the stand off isn't welded yet so I assume it'll be moved over a bit.
Old 03-17-2017, 09:18 PM   #1829
Kim57
Kim57's Avatar
Beautiful color.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-20-2017, 10:08 AM   #1830
MBrown
Looking really nice!! Can i ask a question? Did your builder "clock" the rack and pinion so the fittings point forward or is that a different rack than you started with?
Thanks,
Mark
MBrown is offline   Reply With Quote
Old 03-20-2017, 12:59 PM   #1831
Dan in Pasadena
Mark,
I'm not sure what your, "is that a different rack than what you started with" question means?
The rack was purchased from Flat Out Engineering along with their crossmember. Mike buys rebuilt racks from them because theirs have been reliable and are priced competitively. As for the clocking of the rack, I assume it's clocked the way it is on a C4 Corvette, but I don't know Vettes so I'll ask and get back to you. Sorry I couldn't tell you more right away. -Dan
EDIT: I just texted Mike and he says the rack is modified by Flat Out.
Old 03-20-2017, 01:12 PM   #1832
58CameoAZ
Thanks,
Mark
Hey Mark, I believe Flat Out's Rack&Pinion have been re-clocked
I have their Front kit on my 58 with the Stock Rack from the 85 vette
and i had to re-clock mine.
Pretty easy, pulled the two pins in the center and was able to move the outer casing putting
the line's from their Vertical position to Horizontal position, Now i just need to address the need for new lines.
Allen
58CameoAZ is offline   Reply With Quote
Old 03-20-2017, 02:33 PM   #1833
MBrown
Thanks guys, mine fits the way it is, but i wondered if i should re-clock? Do HAVE to change the lines or can you reconfigure the stock ones?
Mark
Old 03-20-2017, 02:44 PM   #1834
58CameoAZ
Mark
You can re-clock the stock Corvette Rack, Yes,
You will probably need to make new lines to fit, i am finding their is no way to re-use Or Bend mine to the shape in were they need to go.
The lines on mine wont fit to were they need to go and i am afraid if i bent them they are going to leak, so with that i am in search of making a new set that will fit.
Allen
Old 03-20-2017, 05:11 PM   #1835
Dan in Pasadena
Allen
^^interesting^^
Just as an aside I will mention that one of a couple things that held up all my plumbing getting completed last week was Mike needs to order some metric O rings for the lines. In hindsight I can't recall for certain but I THINK it was for the lines exiting the rack.
Old 03-22-2017, 03:17 PM   #1836
bowt1ed
Hey Dan, couldn't remember if you were running rear discs also - but if so, why run your lines on the rear end in lieu of up and out of the way on the frame crossmember? I know drums are, due to hard lines running all the way to wheel, where discs allow the flex line at the wheel. Running mine soon and thinking of the layout a bit.
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 03-22-2017, 04:21 PM   #1837
Dan in Pasadena
Hmmm, I don't know the answer. Preference I suppose.
Obviously, you have to have flexible lines to deal with the motion of the suspension and that will happen whether the hardliners are mounted on the rear end or on the cross member as long the flex lines connect the parts that move with the parts that don't!
MAYBE it's that Mike is more used to plumbing a chassis with rear drums than discs - I don't know. I'll see him later this week and can ask him if you'd like.
Old 03-23-2017, 07:19 PM   #1838
Dan in Pasadena
Thursday, March 23, 2017
Exterior color.....FINALLY! This has 3x base coats and 3x clear coats. Was sprayed Saturday and has been drying since. Will be sanded and 3x additional clear coats sprayed, then final cut and polish.
The cab is dusty as hell but I wiped off the corner where the gas filler used to be. Remember this has NOT been cut/polished yet. It's right out of the gun. I'm really really happy with it.
Mike and Marcos will coordinate to return the chassis to the paint shop for the cab to be remounted. If it won't be ready right away, I'll pick up the chassis to get it out of Mike's way. He has his own '58 Corvette to work on and customer's cars.
After the cab, doors, front fenders and hood are remounted and gapped it can go back to Mike's for wiring and to get the engine running/tuned/debugged. Then once the bed is done it'll be mounted and the exhaust finished all the way to the rear bumper.
Stopped by Mike's shop and the final hydroboost plumbing was being done. Here are some progress pictures. The driveshaft has been ordered. The exhaust manifolds still need some minor tig welding before sending for coating. That's it for the chassis.
Old 03-23-2017, 07:35 PM   #1839
Dan in Pasadena
Cheers, Jim
Jim,
Mike said every car with live rear axle he's ever done has had the hardline mounted to the rearend housing. The flex lines from rear axle housing to calipers is jut for ease of servicing later.
Old 03-23-2017, 09:02 PM   #1840
Advanced Design
Advanced Design's Avatar
Wow, that paint is nice! You gotta be pretty pumped. Looking like you might be driving it this year?
Advanced Design is offline   Reply With Quote
Old 03-23-2017, 11:17 PM   #1841
oldman3
oldman3's Avatar
Beautiful color, I know your ready for more now...Jim
Old 03-24-2017, 08:03 AM   #1842
Kim57
Kim57's Avatar
Looks great.
Kim
My build thread
Old 03-24-2017, 10:14 AM   #1843
G&R's57GMC
G&R's57GMC's Avatar
Getting closer !
Looking great !
Yea ! Whoopie ! Hooray ! tra la la whoop de yea !
And the band plays on along with the parade marching down the street .....
Opps to soon , save the last part for the finish
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 03-24-2017, 11:32 AM   #1844
Dan in Pasadena
Just got a text from Mike last night that Marcos won't be ready for the chassis for 2 weeks (that makes me think it'll slip to 3weeks).
So I'll bring the chassis home for those weeks to make room in Mike's shop for other work - which is mostly ok. I'll be able to clean it up, stare at it, make vroom, vroom noises!
Old 03-24-2017, 02:55 PM   #1845
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Looks great Dan!
ChuckDriver is offline   Reply With Quote
Old 03-24-2017, 03:06 PM   #1846
Flysocal
The paint is looking awesome.
Flysocal is offline   Reply With Quote
Old 03-24-2017, 03:23 PM   #1847
oldman3
oldman3's Avatar
If there's no video, it didn't happen ...Jim
Old 03-24-2017, 07:32 PM   #1848
Dan in Pasadena
Friday, March 24, 2017
A few miscellaneous shots. The doors were inside and even though I used a flash they still look burgundy and they're really not. But I think the truck WILL look burgundy after dark and maybe on cloudy days too.
Old 03-24-2017, 08:58 PM   #1849
mongocanfly
Post Whore
mongocanfly's Avatar
That color looks great...
Old 03-24-2017, 10:25 PM   #1850
Dan in Pasadena
Thanks Mongo!
It really DOESN'T look like burgundy in person but on photos it does. So much so that I'm searching Google Images and Pinterest for burgundy cars to see the wheels that will look best on it.
All opinions appreciated.
