Closed Thread
Old 03-05-2015, 11:19 AM   #1826
globalstarpdr
Re: What did you do to your truck today? Chapter II
Finished my bed wood kit finally
globalstarpdr is offline
Old 03-05-2015, 01:53 PM   #1827
B_town12
Originally Posted by Possmguts View Post
I have those same lights in green... I cant get the beam to not be scattered. Have you fired them up yet?
Bare with me I'm not familiar with reposting and if this is the correct way. I only remotely hooked up the LED's to see how they looked. I haven't started the truck yet but getting close but did notice the headlight bulb was loose and could cause a problem down the road.
B_town12 is offline
Old 03-06-2015, 12:02 AM   #1828
colgad
colgad's Avatar
Worked on Running boards and lower rear fender. Getting better, glad I went all steel for the rear fenders.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 03-06-2015, 12:13 AM   #1829
9teen69
9teen69's Avatar
That truck is awesome!
Should be in the next expendables movie
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 03-06-2015, 09:31 AM   #1830
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Beyond awsome ! .
Movies tend to beat up your vehicles , I've rented some over the years and watched others get screwed .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 03-06-2015, 11:30 AM   #1831
Chuck Burg
Chuck Burg's Avatar
Built the first piece of my flatbed, if everything go's right I might have it ready for powdercoat by the end of next weekend.
Chuck Burg is offline
Old 03-06-2015, 11:33 AM   #1832
Chuck Burg
Chuck Burg's Avatar
I might do alittle more grinding, the radius on my end caps don't match the radius of the 1/4 wall tube.
Old 03-06-2015, 08:28 PM   #1833
Chuck Burg
Chuck Burg's Avatar
Started the headache rack today, I went with a rounded look by making 8 bandsaw cuts about a 1/4" apart to bend the tube, then welded the cuts and ground them out.
Old 03-06-2015, 08:43 PM   #1834
Chuck Burg
Chuck Burg's Avatar
Ground out and sanded smooth, The small pits I'll tig weld with silicon bronze.
Old 03-06-2015, 10:09 PM   #1835
Possmguts
Possmguts's Avatar
You did it right. Yes its true the bulbs are not mounted very well but I didnt have any trouble the couple months I drove with them. The truck is in pieces now. Only issue i really had has not getting a good solid beam... I guess thats a fairly big issue when they dont do what they are supposed to do though. I'll probable go with something else when i get that far in the build.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 03-07-2015, 12:06 AM   #1836
Saclandman
Saclandman's Avatar
Did nothing today on my truck. But as I was cruising through Austin, Nevada, saw a very nice 68 C30 Dumptruck sitting along the freeway for sale. Thought about turning around and checking it out. But, I had 6 hours to go in order to get home and already short on time. Next time, I'll stop.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 03-07-2015, 08:49 AM   #1837
BugzC10
BugzC10's Avatar
What color are you going to paint er? She looks sweet
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 03-07-2015, 09:13 AM   #1838
Lanman1972
Lanman1972's Avatar
Mounted the bed today. Feels good to drive a whole again. Been driving it without the bed for 6 months.
Lanman1972 is offline
Old 03-07-2015, 09:50 AM   #1839
DillonGMC
DillonGMC's Avatar
I put some 110 in the tank and laid some rubber lol
DillonGMC is offline
Old 03-07-2015, 09:51 AM   #1840
DillonGMC
DillonGMC's Avatar
Looks good lanman I love orange and white.
Old 03-07-2015, 10:34 AM   #1841
Lanman1972
Lanman1972's Avatar
Thanks Dillon, hope to trim it today and then drive it for awhile. Done for now(NOT)
Old 03-07-2015, 08:40 PM   #1842
85burb
85burb's Avatar
Today I finished off my power disc brake install. It started out ok. The booster and the master cylinder went on and fit like it should. The day took a nose dive from there. The brake line kit I got with the power brake conversion didn't fit at all. I was only able to use one freaking line and had to bend it in to a completely different shape to make it work. Bleed the brakes and then moved to the rear. I was to install 2 inch lowering blocks and they came with new u bolts. Well the idiots at performance online have no idea what they are doing. The u bolts were too short. Who sends 2 inch block with u bolts only 1.5 inches longer then the factory bolts. Then I drove all over trying to find bolts that would work. I was not able to find any. So I went back home and put the short u bolts in and then moved on to the track bar. I removed the old one and measured it. 27 1/8 long. Started to extend the new once again performace online brand track arm. The end falls right out the end and is about 2 inches short still. So then I installed the factory arm and parked the truck again. I am not sure if this is how performance online treats all there customers but every order I have got has been messed up or took for ever. Here is a picture of the truck at its final stance. We may lower the rear one more inch later on but this will due for now.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline
Old 03-07-2015, 09:44 PM   #1843
Possmguts
Possmguts's Avatar
Installed the disks, calipers and wheels to check the fit after doing the drop spindles..... wheels are too close to the area the tie rod goes into.... So much for running these wheels and tire while I save up for for the new ones. I was hoping to buy the new ones last after the rest of the truck was done.
(I left the cotter pins and grease nipples out until I knew everything would work, that's why you don't see any in the pic)
Old 03-07-2015, 10:07 PM   #1844
CST10
CST10's Avatar
Installed a new mechanical fuelu on ol owen.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 03-07-2015, 11:05 PM   #1845
sk8er32283
Wasn't today but I figured that I would post anyways. I installed a seat from a late 60's international into the truck. The original frame would not work so I made one. See thread here.
http://67-72chevytrucks.com/vboard/s...d.php?t=658511
I also fixed a whole lot of wiring issues in the truck. I just want to says one thing to everyone out there. Please make sure you are careful when you are wiring things up especially when it is not like the factory design. I found a lot of things that just scared me today. The scariest was a wire straight to the battery that ran up under the dash to a standalone switch w/ no fuse to power the starter solenoid.
Stay safe and happy wrenching.
1971 Chevrolet C10(78 motor), Longbed, 69 Bed I think
Quadrajet 4 barrel 7043208, Th350 tranny, No A/C
Various components are lightly to highly modified depending on the number of beers consumed prior to modifications performed.
sk8er32283 is offline
Old 03-08-2015, 12:11 AM   #1846
Boog
laying low
Boog's Avatar
And what brand spindles are those? 3" ?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 03-08-2015, 12:15 AM   #1847
Possmguts
Possmguts's Avatar
I went with CPP 2-1/2 inch spindles and 3 " springs..CPP CP4S2 These are the new style that allow me to keep my 67 steering linkage and still use the 71-72 disk brakes.
Old 03-08-2015, 12:31 AM   #1848
CaliCode
Gave my headlight trim a satin black treatment
CaliCode is offline
Old 03-08-2015, 08:22 AM   #1849
BugzC10
BugzC10's Avatar
What's your wheel back spacing? My tie rod ends are that close (maybe even closer) but never rub or hit. I think you'll be fine. Put the tie rod ends in and move your wheels from lock to lock, then check you clearance. Note: If your back spacing is 4" or more on a 15" wheel, the wheels will make contact with the LCA when making a hard turns. Ask me how I know....I use to find aluminum metal shavings in my drive way with my old Centerline wheels. Didn't take me long to figure out what was happening.
BugzC10 is offline
Old 03-08-2015, 09:56 AM   #1850
Boog
laying low
Boog's Avatar
I've never used them but some guys use spacers to gain that "just enough" clearance in cases like this. A 1/4" or so might be enough. Cheaper than a set of new wheels and work in the interim until such time as you are ready to buy new ones. Those look like 7" chrome rims so the back space shouldn't be more than 3 1/2".
Boog
primer is finer
Boog is offline
Closed Thread
