09-14-2018, 02:04 PM | #1826 |
Re: What did you do with your truck today, Part 3
Nice touch with the peep mirror. I am planning n putting a new repro stock style one on mine. They look pretty swoopy.
09-14-2018, 09:44 PM | #1827 |
Just doing odds and ends tonight, including putting on the hood springs. I'll be ready to start installing the front clip as soon as the windshield is in.
09-14-2018, 11:25 PM | #1828 |
Daaaamn that truck is well detailed. It's one of those cars or trucks that I will look at while at a show and find my self searching for a flaw, looking deeper and deeper where you "aren't suppose to look," that is what that truck looks like, one of those cars or trucks.
Very nice! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-15-2018, 01:07 AM | #1829 | |
09-15-2018, 01:20 AM | #1830 |
The only forward progress I'm making is the one step forward I'm taking after the two steps back ;-(
1951 Chevy Panel Truck |
09-15-2018, 11:37 AM | #1831 |
I spent my "five minutes" working on my truck that I do every day driving to Oakland to get the stuff I had sand blasted. When I dropped it off, it took me an hour to drive there, drop it off and be home, I left at 10 am on a weekday. To get it, leaving at 3 pm, it took over an hour just to get there! So on the way out I took a little break and went over to the San Leandro Marina to see SF across the beautiful bay.
Brian
09-15-2018, 03:05 PM | #1832 |
The glass guy showed up so now all of the glass is in. Working on what I can until I can get some help hanging the fenders.
09-15-2018, 03:21 PM | #1833 |
Removed the U joints from my driveshaft, cleaning for new U joints and yoke. Secured all the brake lines and now ready for bleeding.
Spent additional time and installed the driveshaft, filled and bled the brakes. Missing vacuum hose to booster so I’ll make a trip to the auto parts store.
09-16-2018, 12:27 AM | #1834 |
Well..................had a long day with a walking tour in a historic district in my town, and then a wedding reception of my nephew's, just got home. But before I headed off for the walking tour I got some work done on my sandblasted parts. A weld here and there, a dent hammered out here and there and then found this....one of the hood braces is pretty badly rusted, CRAP.
I have to get this stuff primed tomorrow but then I will have this rust to fix. That was a big surprise, did't see that coming. Brian
09-16-2018, 10:30 AM | #1835 |
Crazy how metal can rust, it looks almost like new on the outside, but it’s paper thin. Hard to see it sometimes.
09-16-2018, 10:35 AM | #1836 |
Yep, I just hope I don't find the same thing on the other side. It looks good on the outside but I have to inspect it better on the inside, I don't want paper thin metal supporting my hood hinges!
Brian
09-16-2018, 05:34 PM | #1837 |
I got some work done on a few parts and then got them primed today. WHOOO HOOOOO! Every time I paint or prime little parts like this I think of the restoration shop I worked in back in 79 where I would have like 50 or 75 pieces in a booth for a few different cars painting them like this. Damn I learned a lot at that shop!
Brian
09-16-2018, 07:41 PM | #1838 |
Worked on making under dash extension panel and radiator closeout/hold down panel.
09-16-2018, 09:37 PM | #1839 |
Whoa. You've done some serious massaging there! Looking great!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
09-16-2018, 10:56 PM | #1840 |
Nice work...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-17-2018, 08:27 PM | #1841 |
I wasn’t really happy with the way the windshield fit and then I figured out that the gasket was installed incorrectly. My brother in law came over and we pulled out the windshield, put the seal on correctly and put it back in (after being YouTube certified). Much better now, I should have put it in myself the first time instead of relying on a “professional”.
09-17-2018, 09:15 PM | #1842 |
Looking SOOOOOOO Good Mark, damn that thing is sweet.
Brian
09-17-2018, 09:37 PM | #1843 |
Thanks Brian, now that the windshield is in I can start putting on the hood and fenders. The goal is to have it all together by the weekend of October 6th so I can detail it out for a show the following weekend.
09-17-2018, 10:15 PM | #1844 |
Only made a little progress, got the shifter cable and cable support welded in an tested. All good.
Used an bolt to hook the cable to the shift column. I'm pretty sure they make a pin to go in that spot, but I have lost it and can't find another to order.
09-17-2018, 10:27 PM | #1845 |
duplicate post, I need to quit hitting the back button on my browser
09-17-2018, 10:34 PM | #1846 |
I slid the upper and lower radiator hose on.. that's it. ive had so much crap going on that I haven't had time to do my own stuff. I hate when life gets in the way of what I want to do.
09-18-2018, 12:04 AM | #1847 | |
Brian
09-18-2018, 12:04 AM | #1848 |
I cut the area out of the brace and made a pattern to patch it. I just couldn't stop tonight, worked a couple of hours because now it's creating something, making the hood fit the sectioned cab, it fires me up. I cut the brace at the hinge mount and started fit that brace on the cab. Now mind you, my brain is about to explode right now after working on this tonight. I am working a very thin line to make this fit without changing the hinge geometry which I do NOT want to do. So keeping the mod below the hinge mounting point at the bottom is the limit have, I think I have it figured out and will proceed tomorrow.
Brian
09-18-2018, 02:23 AM | #1849 |
Not really working on the truck, just doing some 'normal' checkup/maintenance: engine oïl, coolant, battery charge level and... tires pressure and discovered that these tires are missing quite a lot of pressure, almost one bar! I alway forget to check them!
'55, Chevy 3600, 2nd serie, 3/4 ton, 235, 4 speed Muncie SM420, 4.57:1 rear axle |
09-18-2018, 05:43 AM | #1850 | |
As for my progress, I'm wet sanding - mostly on the doors, preparing for the day in the distant future when the humidity is below 75% so I can shoot some paint. Good luck over there in France. Great having you on the forum!
