#1851 | |
Re: What did you do to your truck today?
As to what I did today.... spent most of the day finishing the mockup of running duals on my 65, then tack welding and finish welding all the joints. I need to add hangars, then disassemble and paint all the weld joints with high temp. paint. I will update my build thread then. I must be getting old, two days in a row out in the shop kicked my butt... I am one tired dude! Last edited by lakeroadster; 09-21-2010 at 09:59 PM. |
#1852 | |
Thanks..thats my next project..
Rick ================================== Quote:
#1853 |
Exhaust is done, except for hangars... here is a video clip.
Old School: Long tube headers, 28" Cherry Bomb's and full length 2-1/2" diameter duals (no crossover pipe) More specifics in my build thread Last edited by lakeroadster; 09-24-2010 at 08:42 AM. |
#1854 |
Who Me?
Sounds good John!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#1855 |
Pulled the speedometer gear housing out and dropped ATF all over the driveway. Ooooops...
And that truck sounds ridiculously awesome with Cherry Bombs on it. :drool: Last edited by firefighter736; 09-22-2010 at 05:36 PM. |
#1856 |
Redneck Hillbilly
Finally got my Olds 350 put up on an engine stand. Also went by Summit and picked myself up a tranny jack.
#1857 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Por15 my hands and got some on some pieces too.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#1858 |
I tried to polish the scratches out of the windshield. I'll never understand why people will ruin a $400.00 whindshield insted of buying $10.00 worth of new wiper blades. it still looks terable but I can see better. by the way this is a 64 I bought for parts for my wife's truck but it was in sutch good shape we desided to drive it insted. now it's my dayly driver other than my harley.
#1859 |
Tuesday I finally finished rebuilding my front suspension and got it back on its wheels.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#1860 |
It's Better With Nitro
I finally got around to painting my frame...
#1861 |
mounted my fron wheels. sanded, primed and am painting the grill as we speak.
Build Thread - Papa's truck build up |
#1862 |
Got the cab loaded on a trailer to take to Lukes house later this week for a drip rail shave!
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#1863 |
Redneck Hillbilly
...been thinking about her a lot more than usual lately...I think the sickness is taking hold...
#1864 |
Senior Enthusiast
A few weeks ago we installed Gabriel gas shocks on all four corners. The rears (60-62) worked great, but the fronts (63-85) Gas Ryder Truck shocks were dreadful, like having no shocks at all. The truck wallowed around like a 48 Pontiac, wandered on the road and took 3 or 4 cycles to stop bouncing after easing over a speed bump. Went back to the super duty gas shocks up front and got them installed today after repainting them black. Now the truck again feels confident like it can handle anything. With the standard shocks it took a lot of work just to keep going straight and not get sick! Another learning experience.
#1865 | |
Could you post up the p/n's of the shocks you used? Would be a good point of reference. Thanks! |
#1866 |
Senior Enthusiast
Yes indeed. The big shocks are Monroe part number 76817 currently titled Gas Grande, and are almost excessively stiff and take a great deal of effort to compress by hand. Here’s a link to a Napa posting:
http://www.napaonline.com/Search/Det...817_0117561992 The ineffective shocks are Gabriel part number 61525. I'm pretty sure mine were labeled Gas Ryder. The ones on the link are labeled Sport Ryder. The Gabriel site lists them as Pro Guard (all under the same p/n). They can be compressed rather easily, and I've got a bad hand/arm. Here’s a link to where I bought them: http://cgi.ebay.com/ebaymotors/Shock...Q5fAccessories Perhaps because they were old stock they weren’t up to snuff, but I also bought a matching pair of rear 60-62 shocks from the same source and they are tip top. To me the 61525's just seem too soggy for the application. |
#1867 |
to hot to go out side went over 100 today,I was out early morning and put the gas tank back in.
big old burb in primer.lot of work to do. |
#1868 |
Today I shaved my drip rail and set Lukes garage on fire
#1869 |
Sparks hit sumtin'
http://s1299.photobucket.com/user/jb...23904108567829 |
#1870 |
Pulled the front clip off the 65 this morning.I may go back out and yank the engine and trans later.
#1871 |
ha nah I was just kiddin. He layed it out and lit em up!
#1872 |
Never Ending Projects
Well did it yesterday but on the '65, swapped out the 3" dropped springs for CPP dropped modular spindles and half coil cut off stock springs. Put new KYB shocks and CPP upper shock mount reinforcing brackets and new sway bar bushings. Also pressed in two new wheel studs. It was a long day in 90+ heat but in the end all worth it. Truck drives like a completely different truck... in a good way!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#1873 |
Started installing the pressure treated plywood floor in the bed. More data in my build thread.
#1874 |
![]() Join Date: Sep 2008
Well new here, and today did a complete tuneup on my 66 shortbed stepside, plans for the week are to change all the hoses on the 76 350 engine that is in it.
#1875 |
Hauled about a cord of firewood in three separate loads sense I lowered it....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
