Closed Thread
Old 12-06-2015, 04:30 PM   #1851
Atbyrne
Atbyrne's Avatar
Re: What did you do to your truck today part III
Installed 5 lug rear axles and new brakes.
1966 Chevy C10 2WD SB
Atbyrne is offline
Old 12-07-2015, 01:09 AM   #1852
TJ's Chevy
TJ's Chevy's Avatar
Rewired my tach on Crustine. Now it doesn't bounce all the time(loose ground) and when I turn my head lights on the tach light comes on.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 12-07-2015, 11:50 AM   #1853
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Didn't do a ton but I put fluid into the rear end, finished connected the steering shaft to the power box, put the wheels and tires on and installed the new battery tray.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 12-07-2015, 10:05 PM   #1854
PORKY
PORKY's Avatar
After almost 2 years I uncovered it today. I hope to get back at it full tilt. It's been a 4+ year project already. Where does the time go? My sons got there license and all their projects took priority. I have a GM 427 and a Tremec 600 ready to go in it. Just uncovering it sure was a motivator.
PORKY is offline
Old 12-07-2015, 10:29 PM   #1855
Classic v6 GMC's
Classic v6 GMC's's Avatar
WOW nice project!!! Looking forward to updates!!!
Classic v6 GMC's is offline
Old 12-08-2015, 12:20 AM   #1856
chevy2tom
chevy2tom's Avatar
Finally after 3 weeks & 4 haulers cancelling on me(because it's not running) it's on its way to me from California
chevy2tom is offline
Old 12-08-2015, 02:18 AM   #1857
oldies1938
Paint is coming along
oldies1938 is offline
Old 12-10-2015, 11:40 AM   #1858
Turtleman
Turtleman's Avatar
After all this time.. I finally got the 1.25" sway bar on..
Turtleman is offline
Old 12-10-2015, 11:53 AM   #1859
Lugnutz65
Lugnutz65's Avatar
Turtleman,
Where did you get that sway bar? Off a Suburban maybe? Also, is your truck lowered? I'm looking for the same thing. My sway bar has the linkage rod and bracket and I'd rather have the setup you have.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 12-10-2015, 12:32 PM   #1860
Turtleman
Turtleman's Avatar
The Bar I got off e-bay, it was told that it came off a 79 3/4 ton... It had all the brackets so it was just a matter of drilling a couple mounting holes and bolt on.. The truck is Not lowered but I did replace the upper and lower arms and all suspension links off of a 87 C-10.. (I'll never do that again)..
Old 12-10-2015, 01:07 PM   #1861
Lugnutz65
Lugnutz65's Avatar
I guess I'll look for a 3/4 ton bar then. Thanks for the info. The sway bar looks good. I will also be installing a third generation Camaro rear sway bar on my rear. It's a pretty neat swap with the bar sitting over the axle instead of linked to the rear control arms.
Old 12-10-2015, 06:49 PM   #1862
gar187er
Wired in some relays for the headlights. After I put a NEW alternator in, and its charging properly the headlights would flash from too much current through the harness and switch....Hopefully now they wont start flashing after 20-30 minutes!!!
gar187er is offline
Old 12-10-2015, 07:09 PM   #1863
schpeen
schpeen's Avatar
took it back to the alignment shop and replaced the idler arm and he working on my alignment again trying to get it to settle in nicer at highway speeds so now we have this...
schpeen is offline
Old 12-10-2015, 07:19 PM   #1864
schpeen
schpeen's Avatar
now the truck drives perfect at all speeds right up to 80-85 it just settled right in with almost no effort or adjustment needed. I didn't want to push it faster just to be safe but it showed no signs of wobble or shimmy or shake totally rattle free I was so happy almost got misty when i noticed driving along easy at 35-40mph i can feel and hear a rubbing noise from the front end. is that what happens when you adjust it too far? Do i need to adjust it back some lil it stops rubbing not sure what is rubbing yet haven't had time to look deeper into it. I was thing of changing the upper control arms with the tubular ones from brothers
http://www.brotherstrucks.com/prodin...=UCA7200&qty=1
good idea or no?
schpeen is offline
Old 12-10-2015, 07:24 PM   #1865
schpeen
schpeen's Avatar
i have drop spindles and shorter springs with sway bars front and rear
schpeen is offline
Old 12-10-2015, 08:02 PM   #1866
Classic v6 GMC's
Not today but on Tuesday we got some nos parts for our trucks!! Nos 292 manifold, y-pipe for 63-66 automatic, mirror heads and a complete set in box, tailgate chains and covers, ect. Some parts not pictured.
Old 12-11-2015, 09:05 AM   #1867
LDO
LDO's Avatar
I really need to get some wheel dollies like yours!
LDO is offline
Old 12-13-2015, 09:31 PM   #1868
Atbyrne
Atbyrne's Avatar
I got 5 lug disc brakes on the front. Replaced ball joints while doing the 2.5" drop spindle. That was fun. Now will be turning towards engine and transmission.
Started here
[IMG][/IMG]
Did this
[IMG][/IMG]
Now looks like this
[IMG][/IMG]
[IMG][/IMG]
Atbyrne is offline
Old 12-13-2015, 11:54 PM   #1869
DPowers
DPowers's Avatar
Tucked it away for the winter.
DPowers is offline
Old 12-14-2015, 01:18 AM   #1870
nail pounder
nail pounder's Avatar
My girl and I did the vinyl floor, picked up our newly upholstered seat and installed it.
nail pounder is offline
Old 12-14-2015, 04:19 PM   #1871
Northwest Outlaw
Northwest Outlaw's Avatar
Cleaned and partially dismantled the 350 in prep for painting, but cold weather and a non-insulated garage don't lend towards painting...
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 12-14-2015, 04:28 PM   #1872
craiginaustin
craiginaustin's Avatar
The new set of wheels I ordered arrived, so I bought some tires and put them on. The wheels are Cragar Delux 69, 15x7 front and 15x8 rear, with bullet center caps and lug nuts. The tires are Hankook Optimo H274, which seem to be the most affordable white walls I could find. Rears are 235/75R15 and fronts are 215/75R15. I would've liked the whitewalls to be thicker than the inch or so these are, but I didn't want to pay for Coker or Diamondbacks.
Also pictured is the cleaned up and painted swaybar I pulled from a 77 C20, ready to install next weekend.
Not pictured is the solid state external regulator I swapped out for the mechanical one. Voltage meter reads a solid 14 V while running now!
craiginaustin is offline
Old 12-15-2015, 08:27 AM   #1873
chevy2tom
chevy2tom's Avatar
Looking good Craig, now drop in down about a foot lol
Old 12-15-2015, 08:49 AM   #1874
jbgroby
jbgroby's Avatar
Got the last of the parts from the painter. Bed strips and wheel tubs! The painter did such a great job removing the dents out of the tubs and sandblasting them they look new. The semi-gloss black paint looks like EDP coating, he also undercoated them as well. The bed strips were new from Mar-K, he painted both sides.
jbgroby is offline
Old 12-15-2015, 10:29 AM   #1875
jayoldschool
Moderator
Wow, those do look like brand new tubs.
jayoldschool is offline
Closed Thread
