12-15-2015, 12:22 PM | #1876 |
Re: What did you do to your truck today part III
Finished rebuilding my carb...installed. Rebuilt my headlight buckets, tried to figure out why my front end was sagging. Turned out it was the radiator support bracket mounts are completely shot. So...I ended up with this. I guess this is how one starts the "frame-off" process. Lol. Here we go folks!
12-15-2015, 12:49 PM | #1877 |
12-15-2015, 01:19 PM | #1878 |
Started doing the gas door on the blazer [oATTACH]1477377[/ATTACH]
My Name is Rusty Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=570083 |
12-15-2015, 01:22 PM | #1879 |
This is how it looks shut
12-15-2015, 01:26 PM | #1880 |
That's funny. I haven't seen leaded gasoline in years.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
12-15-2015, 02:02 PM | #1881 |
That will have to go as it now has a 5.9 cummins
12-15-2015, 02:29 PM | #1882 | |
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" Last edited by goatless; 12-15-2015 at 02:44 PM. |
12-15-2015, 05:31 PM | #1883 |
Not all that hard... I'm looking around for a 1985 and older Mercedes 300 turbo diesel to put in the 55 to replace this 350 and go from 10 miles per gallon to about 30
12-15-2015, 07:02 PM | #1884 |
Done a little blasting on the cab. Top and most of back done. Long way to go.
12-15-2015, 08:44 PM | #1885 | |
im building a 65 long fleetside for a friend black with the red stripe with chrome 8 and 10 inch rallys . I picked up his 65 parts truck to build a cool ratty beater with the leftovers. the one in my picture is what I did with the parts truck so far since I got it . |
12-16-2015, 04:35 PM | #1886 |
12-16-2015, 06:58 PM | #1887 |
Got the windshield out and a little more blasting done.
12-16-2015, 07:07 PM | #1888 |
Been a while.
Did I mention that this truck is fighting me every step of the way....?? I decided that because the truck is getting so much new stuff, the $24.00 for a pair of trailing arm bushes was another thing that needed doing. Replace the 50 year old units while the truck is in bits. Getting the old ones out meant unbolting the trailing arms from the chassis, and then one needs to burn the old ones out. Thankfully I have a butane burner that I use for the branding on my woodwork stuff when I turn or build items. Once burned out, petrol cleaned the channels and made sure they were ready to receive the new bushes. New ones fitted..... Next problem, getting the trailing arms back up and threading the bolts through. I decided to kick Martin out by 8.30 as he had more people to see and more stuff to do. I will use the Jack later in the week to lift both arms up and hopefully get the bolts seated, or else I will have to unbolt the rear of the trailing arms and then refit the front, followed by the rear. Felt good to be back under the truck.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. Last edited by Grizz1963; 12-16-2015 at 07:23 PM. |
12-16-2015, 09:02 PM | #1889 |
12-16-2015, 10:31 PM | #1890 | |
12-16-2015, 11:15 PM | #1891 |
12-17-2015, 01:17 AM | #1892 |
New windshield and rear glass installed today
12-17-2015, 02:09 PM | #1893 |
nothing big just replaced heater switch
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-17-2015, 10:38 PM | #1894 |
12-17-2015, 11:04 PM | #1895 |
Good lumbar support
http://s1299.photobucket.com/user/jb...23904108567829 |
12-17-2015, 11:42 PM | #1896 |
Awesome seat for $100, fits perfectly the 2 front bolt holes line up so I just had to drill 2 for the back. Easy 20 minute install.
12-18-2015, 01:03 AM | #1897 |
12-18-2015, 02:39 PM | #1898 |
What seat is that?
12-18-2015, 04:18 PM | #1899 |
12-18-2015, 07:04 PM | #1900 |
Moderator
Early 90s Chev/GMC pickup.
