12-18-2015, 07:43 PM | #1901 |
Re: What did you do to your truck today part III
12-19-2015, 02:24 AM | #1902 |
Thank you.
"Block paving" as it is known here in the UK is popular and reasonably priced. The guys who lay it will do an area like this in under a day. They work like machines. This was that section looking the other way toward the house and where the woodwork shed went.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
12-19-2015, 11:41 AM | #1903 |
Block, primer , block, primer, repeat, sore shoulder, want finished.
12-19-2015, 07:31 PM | #1904 |
Installed the sway bar I cleaned and painted last weekend. Painless install, drilling holes in the frame was a bit nerve-wracking but easy enough in the end. My LCA's already have the holes so no modifications required there.
It handles remarkably better... less feeling like a boat, more actual turning. |
12-19-2015, 10:03 PM | #1905 |
We got the doors back on. It's starting to look like a truck again.
12-20-2015, 12:05 PM | #1906 |
Got the horn button installed, do not quite yet if it will work, but there is always the 'fingwr'.
http://s1299.photobucket.com/user/jb...23904108567829 |
12-20-2015, 12:51 PM | #1907 |
Nice gauge set up
12-20-2015, 02:16 PM | #1908 |
Thanks, I followed the OEM light setup and added the OEM click and tack
12-20-2015, 05:46 PM | #1909 |
I put glove box lock and under dash ashtray knob and snuffer on
12-20-2015, 11:26 PM | #1910 |
Got the cab stripped down to nothing. Just glass to remove and its time to start blasting.
Then I'll be onto what LT1 Burb is doing. Any tips on removing windshield and back glass? |
12-20-2015, 11:26 PM | #1911 |
We got the firewall painted today.
12-21-2015, 07:08 PM | #1912 |
Lowered the front of my truck another inch and the back another 2 inches. 7/9 drop now. found some super short shocks at Mooneyes. Getting those this week.
12-21-2015, 07:40 PM | #1913 |
12-21-2015, 07:44 PM | #1914 |
Well...I was just going to start with the headlight rebuild and ended up here. Guess I'll do a frame off now. Ha!
12-21-2015, 08:07 PM | #1915 |
12-22-2015, 07:29 AM | #1916 |
I feel your pain.
12-22-2015, 09:29 AM | #1917 |
12-22-2015, 07:42 PM | #1918 | |
But we are gaining. Stay with it, a little each day and soon it'll be done. Best of luck! |
12-22-2015, 11:18 PM | #1919 |
12-23-2015, 12:01 AM | #1920 |
Took 7" out of the original '65 12-bolt and installed a pair of Moser 7950 housing ends. These ends retain the stock brake mounting pattern while converting to the big Ford 3.15" axle bearings and retainer plates, thereby eliminating the need for C-clips.
The housing is now 50" end to end. It was 57" originally; already 1-1/2" narrower than the later truck 12-bolts. |
12-23-2015, 12:24 AM | #1921 |
Nice looking bed. What wood did you use? Did the diamond plate come in a kit or did you fab that yourself?
1966 GMC LWB Fleetside |
12-23-2015, 11:16 PM | #1922 |
Fired up my GMC after 2 weeks sitting and ran her for awhile. She was happy I paid some attention to her.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-24-2015, 02:14 PM | #1923 |
-15C (5F) so I just plugged it in and came in for a coffee. Today it gets to drop a stove off at the recyclers. It will be interesting to learn how she handles the fresh snow without the aid of positrac.
12-24-2015, 02:49 PM | #1924 |
looks just like my replacement cab going on my 60 chevy.. Only thing is its a GMC cab and I will change out dashes..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
12-24-2015, 05:59 PM | #1925 |
Its cold out here and my GMC didn't have a working heater, so I took the blower motor out to find it was seized up solid. Put one in that I got from my 66...well...now I have freezing ice cold air. lol But hardly a touch of heat. Took the top off and the core had pine needles and crap on top of it...vacuumed that off...sill no heat. Thinking my core is plugged up or something. Will be taking the core out Saturday to see if the fins are still plugged. If they are I'll blow them out and if that doesn't help I'm throwing a new core in. Probably not a bad idea considering this one is 50 years old anyhow.
EDIT: One of the vents was open letting cold air in. lol Closed that and problem solved. Time for some driving in the snow! Oh yeah...I did a burn out to while I drove it earlier today. haha
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw Last edited by TJ's Chevy; 12-24-2015 at 06:36 PM. |
