#1 | |
Re: What did you do to your truck today!
As far as your upper arm hitting your steering shaft, you can do several things. Are you running stock arms? If so you can notch it with some tubing cut in half (like a "C") so it will clear the steering shaft. You can also swap out to a D shaft and some universal steering joints and an idler shaft, raising the shaft to clear the upper A arm yet still mak it all the way to the steerign box. Your third option would be some custom A arms, which would clear. Obviously the first thing is the cheapest, just depends on your skill. Good luck with it. |
I just got done tearing apart my drive shaft in order to replace the support bearing and u-joints.
set idle and tuned the carb . ( ithink lol) just waiting for my barke booster and mc an pc to come so i can put them on
1971 LWB C10 - 5.3/350 1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet 1964 malibu ss - ls1/4l60 http://67-72chevytrucks.com/vboard/s...d.php?t=382403 |
I got my speedo gears in today. I installed the new drive and driven gear, tail shaft with new pinion seals, installed a new rear pinion seal, re-installed the yoke and the drive line. Buttoned up the speedo sleeve and cable. Gotta let the lock tight set up tonight and hopefully I can test out the speedo tomorrow.
I've got an orange (I think #8) drive gear(1.84 OD) and a brown(18 tooth) driven gear if anyone wants it.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
Speedo seems to be reading better. Not jumping around like it was. I need to get a GPS to check my true speed. Fired it up, ran it, found out my temp and volt gauges weren't working since I put in the new dash. I twisted it a bit at the printed circuit when I put it back together. All better now. But a new circuit is in the future I think
The Niner
![]() Join Date: Nov 2010
Ordered a Holley 670cfm Street Avenger carb for my 69'er.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#7 | |
Collector of Projects
yes, i do
picked up a grille, top bar and hood latch from LIVRAT for my 72 so i can replace the grill and go with the 67/68 style front end
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
VERY COOL! I found the app and checked my speedo. Still off. 5 mph too fast. Just ordered another gear so now I will have a blue (20) tooth now too. Brand new, barely used! If anyone's interested. Also plled my front bumper off today cause it was crooked. Fixed it and me and the boy put it back on. Good day.
Replaced my front steering and suspension original ball joints and tie rod ends, control arm bushings. Today, recuperating from 3 days of squating under fender wells. What a ***** it was to get those threaded steel bushings out and new ones in. Shaved twenty pounds of my truckes weight, all in rock and crud scraped out of a-arms and crossmember.
4.11 gears, Eaton posi and A Classic Performance Parts super trac bar! Way AWESOME!!!!!!!!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() Last edited by 70short; 03-26-2011 at 03:06 PM. |
dazed and confused
got exhaust ran on the 70 (thursday actually) it is so much nicer to ride in now. i will try put pictures up later.
members met: redbaron69, billsbowtie,nc67 |
#13 |
Well, last week I dug out some stereo gear from my 97 f 150 that I installed in 98 and pulled when it was totalled in 2000
and desided to install the old junk that isn't worth anything in the truck The doors where already cut front and rear for 6.5" speakers so I opened the rear hole and installed my boston acustic 6 by9s and pioneer 6.5" ![]() I also had some kickpanels and a set of cerwin vaga(remember them) 6.5" two way seperates the woofer is in the kick the tweeter in the dash ![]() next was the really old jbl and kenwood amps ![]() and then cut the crap out of my arms try'n to get this in the dash ![]() and re installed the seat after a little rework ![]() now to fit this blazer tank under the bed ![]() this brace under the bed must be cut ![]() all gone ![]() ![]() there is another brace behind this one so it's not a big deal, if I was to use it like a 3/4 ton truck then,, I'm gonna cut the brace at my cut about 3/8" and fold it in and weld it so it'll have a little added strenth.. after that sand and sand and then some por 15 |
#14 |
Big Red - Now its a SWB!
Nothing.....damn rain!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#15 |
Just got the headers on. Had to go in from the bottom. Only issue looks like the bottom of the pass. side frame rail may touch a little. I didn't tighten 'em down yet. They are full length super comp. hookers for a '73 to '87. They came with the motor when I traded for it.
#16 |
[img][attach]
#17 | |
My Mechanic had to cut a small notch out of the Frame.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#18 |
Got the holes in the crossmember cut and lined with sch40 and then painted. Tried to install my brand new $750 Hooker headers...they don't fit. You would think for all that money they would jump out of the box and onto the truck all on their own!
#19 |
![]() Join Date: Mar 2011
today I spent an hour in the back of my parts store trying to find a rad. hose that would clear my engine driven compressor belt. I had a flexhose with the spring inside and I dont even wanna now how much rust an/or pieces of rotted spring got sucked into my engine. I bought 2 that didnt work and just as I was going back to the store I almost fell over a full built 318 I have sitting in the garage. Wouldnt you know it there was an almost perfect hose right in front of me the whole time. After trimming 3 inches it was perfect! I started pulling my interior apart and took my console out to upgrade air valves and put in my painless kit. Then got sidetracked and wound up remaking the whole front half of my console for a smoother curve. I didnt go too crazy with it since Ill be pulling it out again when I get a radio and speakers someday. The console would be a perfect spot for a sub and some 6x9's.
#20 |
Watched it get snowed on....
anyone know where to get a CHEAP yet GOOD truck cover
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
#21 |
high-Tech Red Neck
Been making a punch list to wrap up my 4x4 conversion/Cummins install.
![]() ![]() Also took the old fiberglass visor pos off. ![]() Still a lot to do, but right now its looking like a truck again. Until I blow it all back apart to finish boxing the frame. Then it will go back togeather after each piece is painted with POR-15
"He used to be a pretty nice feller, now he's a welder!" |
#22 |
drove it to church, had a few people looking at it and asking a few questions, than looked at it myself and said....... i have the lowest vehicle in the parking lot
#23 |
Gearhead
Project: That is awesome.
![]() Over the weekend, I installed an ECE hidden hitch on my 72', installed the trailer wiring, remounted my compressor (interfered w/the hitch) and recalibrated my govenor in the 700R4 (what a pita!)
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#24 |
Hellasick
![]() Join Date: Jul 2006
Took longer that "Today", thanks to the wonderful roller-coaster weather we've been having and a minor bout with the flu, but I got my new exhaust manifolds installed.
Engine was replaced in '97 and around 40,000 miles since then. Bolts came out nice and easy. The doughnut gasket between the manifold and pipe on the pass. side was pretty much blown out. Now I can hear my exhaust tone and not the exhaust leak Before---there is also an "R" on the passenger side that you cant see. Guess the guys that put in the engine couldn't tell the difference. The pass. one also has a big crack that you can't see in the pic. Thought I would give the Rust-oleum 2000* paint a try on the new ones.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#25 |
Sofa King Crazy!!
I cursed at mine today. Then went to the engine builder and cursed him.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
