Old 07-29-2014, 04:06 PM   #1951
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
You may be wondering what the heck I did with that week in the shop..?
I literally spent so much time in the shop that I didn't have time to update the thread. But the camera was snappin away as always. So here it is...
Trans tunnel/shifter cover flushification:
Bolt on cover
Now a flush mounted cover
Add S2000 boor flange
With shifter (small holes in tunnel fixed later)
Tunnel will be body-worked and painted
Frizzle Fry is offline   Reply With Quote
Old 07-29-2014, 04:16 PM   #1952
Frizzle Fry
More lead work. This consumed a lot of time both in the actual process and in researching and buying tools and materials. In the end I had some success and some failure, but it was worth figuring out.
Prep:
Tinning flux
Tinned
Radius form:
Worked radius
This area needed more added around the edges. The problem with adding more lead later is that the area is no longer tinned if it's been filed/sculpted. Here was my attempt at re-tinning around the edges. After this I ended up removing the lead from the fender.
Old 07-29-2014, 04:27 PM   #1953
Frizzle Fry
Passenger side patch:
Not going for perfection here since it will be leaded.
Just like the other side:
Lead(free)
How to deal with this area (can't use this on regular if you like your sanity)
I guess the only finished shots I got were inverted, but you get the idea...
It will need a little glaze.
Old 07-29-2014, 04:36 PM   #1954
Frizzle Fry
Trans Mount-
I had mocked this up by drilling/tapping the "frame rails," but knew it would need to be reinforced. Here's how that went:
Cut open rail
Make plates (note broken tap )
Plasma out broken tap (haha I win )
First piece in
Align 2nd piece and cover
Trans mount in place (other side already mod'ed for exhaust clearance)
Old 07-29-2014, 04:38 PM   #1955
Frizzle Fry
While I had the tap set out I made some shoulder belt mounts for the rear:
Old 07-29-2014, 04:46 PM   #1956
Frizzle Fry
Made blood happen while prepping this patch (previously mentioned front inner fender spot)
It was actually just a tiny puncture in a large vessel (squirter)
Luckily my apprentice and future successor was there to save my life before getting back to work.
He's prep'ing old engine tag mount holes for welding.
Old 07-29-2014, 04:54 PM   #1957
Frizzle Fry
Lot's of other minor details including pin holes and thin spots are now fixed. Spent some time tuning the fender arches into shape.
Last item worth showing is the rear wheel arch to rocker seam filling. Couldn't leave the seams in the rear when the fronts are gone
Trim inner edge for continuity:
No lead this time. Just a smear of glazing will do it up.
Old 07-29-2014, 08:02 PM   #1958
El Campo
El Campo's Avatar
Freaking beautiful. Always love seeing great metal working and welding happening as it seems to be lost on so many people. You really ARE going old school with the leading! Curious to see how that works with todays paint products.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-29-2014, 10:16 PM   #1959
y5mgisi
Second Chance Program
y5mgisi's Avatar
Great work as always!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 07-30-2014, 01:28 AM   #1960
Frizzle Fry
Thanks EC. The lead free body solder should be no different than clean metal as long as it's prep'ed properly. If not, yeh the acid in the flux/tinning would be a concern.
'Preciate it brother. Being in Portland there's a good chance you could see this anomaly on the road or at a cruise some day. It will be at PIR Beaches the first chance I get in 2015.
Old 07-30-2014, 01:38 AM   #1961
Frizzle Fry
In the spirit of 'git er dun' I plug welded these covers over the factory ebarake holes rather than my standard flush install (it will be under the carpet for God's sake)
Given the above, it was time to call it...
Rotisserie dropped down to transport mode:
Chariot awaits (again)
Driftbeam is now at the paint shop!!!
Next update will show the new color (yes I said new )
Old 07-30-2014, 02:25 AM   #1962
watahyahknow
watahyahknow's Avatar
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-30-2014, 05:29 AM   #1963
Old 07-30-2014, 06:37 AM   #1964
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
What ever will you do with your time while it is in the paint shop... TAHOE!!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 07-30-2014, 10:13 PM   #1965
trixter99
I have no time for this
trixter99's Avatar
The Tahoe or the 61 I'm dying to see them done.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 08-08-2014, 12:53 PM   #1966
knomadd
knomadd's Avatar
Hoping to see some paint pics soon! All the work you've done is amazing! I want to see it finished!!!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-08-2014, 01:15 PM   #1967
Low Elco
Can't wait to see!
Low Elco is offline   Reply With Quote
Old 08-08-2014, 05:56 PM   #1968
Me3
Old 08-08-2014, 06:03 PM   #1969
NONHOG
NONHOG's Avatar
Something timeless I hope, like this?
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 08-08-2014, 06:27 PM   #1970
watahyahknow
kindah liked the pastel colour that was on it , th not so bright / faded colour fits the year of the car
Old 08-08-2014, 08:22 PM   #1971
76C10Stepside
76C10Stepside's Avatar
FF, what kind of welder do you use for those button welds? They look great!
I used a stud puller and bondo for the first time on this one. Only had to weld 3 tiny patches.
76C10Stepside is offline   Reply With Quote
Old 08-09-2014, 12:13 PM   #1972
Frizzle Fry
this?
Attachment 1287331
[/QUOTE]
[QUOTE=76C10Stepside;6794134]FF, what kind of welder do you use for those button welds? They look great!
/QUOTE]
Thanks. I plug weld with the same mig I use for everything else; my Miller 211.
Old 08-09-2014, 12:21 PM   #1973
Frizzle Fry
Just a quick update to show the color as promised. This is Raptor Liner tinted with the blue that will be used for the body. More detailed pics later (have to prep for a BBQ now).
Old 08-10-2014, 02:29 AM   #1974
ajgriffin
ajgriffin's Avatar
Looks amazing! Good luck with the paint!
All the original trim going back on it? Anything special in store for it?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 08-10-2014, 12:09 PM   #1975
Frizzle Fry
Thanks. I'm still planning to use all the trim with red between and a black top as original. I've been considering using the red from the audi RS badges.
