Closed Thread
Old 03-22-2011, 09:24 AM   #1951
PLANETGETLOW
Re: What did you do to your truck today!
(My sons truck) Almost finished up the 12" notch, got the truck off of jack-stands and onto air shocks
PLANETGETLOW is offline
Old 03-22-2011, 09:38 PM   #1952
60ratrod
yes, i do
60ratrod's Avatar
made a sketch of my 72 with a 67 front end so i can play with paint schemes
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 03-22-2011, 09:41 PM   #1953
60ratrod
yes, i do
60ratrod's Avatar
lets try this this time
60ratrod is offline
Old 03-22-2011, 09:56 PM   #1954
bucketObolts
bucketObolts's Avatar
Not a whole lot but i did start cutting some stainless interior trim pieces on one of the lasers at work. And I put my new Powermaster XS starter in. Man this thing cranks!
bucketObolts is offline
Old 03-22-2011, 09:58 PM   #1955
67Slider
67Slider's Avatar
Adjusted the glovebox door striker so I can pop it open with one push of the button. Now I don't have to fight with it to get to my stereo.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 03-22-2011, 10:36 PM   #1956
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Flipped the frame over and painted the bottom of everything we couldn't get to on Sunday afternoon. Learned something, too. If I EVER (!) do this again, I'm not going to brush-paint the chassis, regardless of what kind of paint I use. Rattle-cans or bonafide spray gun....that's the ticket.
Once the parts are sand-blasted....the work begins. Looking forward to the chassis reassembly. I want this thing back on 4 wheels. 4 years is too long to go without my truck. I need a fix.....man.
Member Nr. 2770
ChevLoRay is offline
Old 03-23-2011, 05:46 AM   #1957
Pick
Pick's Avatar
I finally changed all of the fluids and filters in the "new" '68......I think the oil filter had been on there awhile 'cause it REALLY didn't want to come off.
This is what happens when a stubborn oil filter meets a determined new owner.........and a Vice Grip chain wrench. (nothing else got it to even consider turning.)
Pick is offline
Old 03-23-2011, 03:12 PM   #1958
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Dropped my 396BB at my local machine/pro shop for evaluation and a complete overhaul. Bought the truck with the engine removed and disassembled. Now I am having the pleasure of having the engine build to my specs.
SO far we are looking at a complete rebuild of the '71 402 heads with new valve guides, valves and seats. The crank will have to go to -.020 and the cylinders will have to go to -.060. The engine and rods will be line bored and balanced. I am also looking to go with a Lunati Voodoo series 60202 mild cam. Not decided wether or not to go with the PO Holley intake and Holley DP (size unknown). I might just go to the Edlebrock mainfold/carb setup for ease of maintanability.
AL
'69 GMC 2500 Custom Camper
'69 Chevy C10 396
That is all so far.
alsriv2 is offline
Old 03-23-2011, 03:33 PM   #1959
cam.man67
cam.man67's Avatar
Broke my motor...actually I guess that was last Friday.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline
Old 03-23-2011, 04:18 PM   #1960
colin_havens
colin_havens's Avatar
Worked on the wheeltubs for the rear (actually this was Sunday, but I havent been able to get on here fince then). Got them trimmed to fit real nice to the factory bedsides and floor, and got them tacked in. Just have to finish welding them in, and decide if I am going to leave the rest of the floor open or make a notch cover for it.
This one of the probably 50 times we put them in to check the fit. The factory bedsides have several complex angles in them, so it took a long time to get them just right. They are almost there in this pic, but not quite.
And this is finally tacked in, adn done for the evening.
colin_havens is offline
Old 03-23-2011, 10:12 PM   #1961
Pont406
I did a brake flush. Found a plate in a garage and the rest was easy.
Pont406 is offline
Old 03-23-2011, 10:29 PM   #1962
bucketObolts
I pulled my front clip off, relocated the proportioning valve, and started pondering how to keep my steering shaft off of my upper arm when I'm aired out. Still a little stumped. Colin Havens--those tubs look great.
Old 03-24-2011, 09:50 AM   #1963
71dreamer
71dreamer's Avatar
I just got done tearing apart my drive shaft in order to replace the support bearing and u-joints.
71dreamer is offline
Old 03-24-2011, 11:05 AM   #1964
Deenice21
Deenice21's Avatar
set idle and tuned the carb . ( ithink lol) just waiting for my barke booster and mc an pc to come so i can put them on
1971 LWB C10 - 5.3/350
1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet
1964 malibu ss - ls1/4l60
http://67-72chevytrucks.com/vboard/s...d.php?t=382403
Deenice21 is offline
Old 03-24-2011, 04:00 PM   #1965
colin_havens
Thanks man, just got to finish welding them up and spray the bed down with a good coat of bedliner. I cant decide to leave the center open or to build a removeable notch cover so I can still access things like bags and lines if I have something fail.
As far as your upper arm hitting your steering shaft, you can do several things. Are you running stock arms? If so you can notch it with some tubing cut in half (like a "C") so it will clear the steering shaft. You can also swap out to a D shaft and some universal steering joints and an idler shaft, raising the shaft to clear the upper A arm yet still mak it all the way to the steerign box. Your third option would be some custom A arms, which would clear. Obviously the first thing is the cheapest, just depends on your skill. Good luck with it.
Old 03-24-2011, 07:43 PM   #1966
67Slider
67Slider's Avatar
I got my speedo gears in today. I installed the new drive and driven gear, tail shaft with new pinion seals, installed a new rear pinion seal, re-installed the yoke and the drive line. Buttoned up the speedo sleeve and cable. Gotta let the lock tight set up tonight and hopefully I can test out the speedo tomorrow.
I've got an orange (I think #8) drive gear(1.84 OD) and a brown(18 tooth) driven gear if anyone wants it.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 03-25-2011, 09:52 PM   #1967
67Slider
67Slider's Avatar
Speedo seems to be reading better. Not jumping around like it was. I need to get a GPS to check my true speed. Fired it up, ran it, found out my temp and volt gauges weren't working since I put in the new dash. I twisted it a bit at the printed circuit when I put it back together. All better now. But a new circuit is in the future I think
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 03-25-2011, 10:19 PM   #1968
Sicklajoie
The Niner
Sicklajoie's Avatar
Ordered a Holley 670cfm Street Avenger carb for my 69'er.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 03-26-2011, 12:09 AM   #1969
mcmlxix
Collector of Projects
mcmlxix's Avatar
there's an app for that .... I found a free speedometer application for my phone... checked it in a coule cars... one is a 9c1 police Impala with "calibrated" speedometer... its right on the money.....
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 03-26-2011, 01:25 AM   #1970
60ratrod
yes, i do
60ratrod's Avatar
picked up a grille, top bar and hood latch from LIVRAT for my 72 so i can replace the grill and go with the 67/68 style front end
60ratrod is offline
Old 03-26-2011, 07:43 AM   #1971
eagleuh1
eagleuh1's Avatar
Replaced my front steering and suspension original ball joints and tie rod ends, control arm bushings. Today, recuperating from 3 days of squating under fender wells. What a ***** it was to get those threaded steel bushings out and new ones in. Shaved twenty pounds of my truckes weight, all in rock and crud scraped out of a-arms and crossmember.
eagleuh1 is offline
Old 03-26-2011, 03:05 PM   #1972
70short
Talking Re: What did you do to your truck today!
4.11 gears, Eaton posi and A Classic Performance Parts super trac bar! Way AWESOME!!!!!!!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline
Old 03-26-2011, 03:46 PM   #1973
67Slider
67Slider's Avatar
VERY COOL! I found the app and checked my speedo. Still off. 5 mph too fast. Just ordered another gear so now I will have a blue (20) tooth now too. Brand new, barely used! If anyone's interested. Also plled my front bumper off today cause it was crooked. Fixed it and me and the boy put it back on. Good day.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 03-26-2011, 04:16 PM   #1974
bigguy69
dazed and confused
bigguy69's Avatar
got exhaust ran on the 70 (thursday actually) it is so much nicer to ride in now. i will try put pictures up later.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline
Old 03-26-2011, 05:03 PM   #1975
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Nothing.....damn rain!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline
Closed Thread
