Old 01-26-2006, 01:49 PM   #176
valleycustom
Re: Custom Chassis with canti setup
Originally Posted by a squarecan
All I have to ask is; Is there anything you can't do?
I think I couldnt be more amazed after each set of pix you post, but everytime I find myself more amazed! Very nice work! Did you bend all your exhaust or are they pre-bent pieces? If you did it your self what gauge steel did you run?
Keith
Thanks! I use pre bent mandrels on all my exhaust systems. I just cut to fit. Maybe some day when I win the lottery I will get my own mandrel bender. All my exhaust tubing is 16ga.
Later
Jr
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 01-26-2006, 01:53 PM   #177
valleycustom
Originally Posted by pharcydekm
LOOKS GOOD! My only question is why not run it straight and go through the frame up ahead rather than make that 90 turn to come through?
I needed to get the two sides together at the X pipe. X pipes I feel work a little better than just an H cross over. It also will look badass when it's finished. If you ride in a car that has a x over and one that doesen't have any x over you can tell the difference in the performance and it makes it a little quieter..
Old 01-27-2006, 01:52 AM   #178
a squarecan
I didn't realize exhaust's were so beefy.
This leaves me with 2 questions, that is if you don't mind.
1. Where do you recommend getting your exhaust parts from if I guy was to try to build him self an exhaust set-up.
2. what kind of mufflers are thoughs? They look like a race style muffler.
Ok I lied I have 1 more question, does it take a brain sergain to build an exhaust system? I can weld just fine, but is there a certain science to specific bends and such?
Keith
a squarecan is offline   Reply With Quote
Old 01-27-2006, 02:03 PM   #179
valleycustom
Keith
I usally get all of my mandrel's from summit. Make sure what you get are 16ga. Hooker sells mandrels but they are 18 or 20 ga. I wouldn't use anything other than 16ga. You can get straight pipe from your local muffler shop. Those mufflers are flowmaster hushpower mufflers. I've never used them before so I'm not sure how they sound. If your just building a system for a daily driver there's no science involved, but if your making a system for a race car that's a different story. I have a box full of bends that I just cut up and weld back together. Making headders is the only thing that is hard. Well not very hard but it takes time. A set of headders can take me a week to build depending on how involved they are.
Later
Jr
Old 01-27-2006, 05:51 PM   #180
XXL
Seņor Member
XXL's Avatar
Originally Posted by valleycustom
Sorry for the delay on responding. I would change the 2x3 rails to 2x4. 2x3 box doesn't look right on a fullsize. It looks to small.
3/16" wall or 1/4" The latter sounds a bit overkill, but I thought I'd ping you first.
Also, do you think the cross tubes will work at 1.5"? Only other thing I am contemplating is to 2x4 box the tail end of the channel runs instead of that round tube. The rest would be round tube.
XXL is offline   Reply With Quote
Old 01-27-2006, 07:06 PM   #181
valleycustom
I'd go with 3/16" wall box. 1.5" .156 wall would be the size tubing I would use on the cross tubes. I would just box the end of the frame with another 2x4 going across. Gives it a clean look and it's stronger. You might want to maybe cross some of those tubes to provide some side to side support for the frame rails. Your going to be cutting one of the factory x members that provides this.
Later
Jr
Old 01-27-2006, 09:21 PM   #182
a squarecan
Thanks again Jr!
You build headers? I am having a hell of a time finding some block huggers headers that will work with the angle plugs on my dart heads. I am not in the market at this exact moment but do you think if the price was right you could possibly build a guy in my situation a set in a month or so?
Keith
Old 01-31-2006, 01:42 AM   #183
valleycustom
Well I almost have the exhaust system finished. Here are some pictures. Next I will be starting on the headders. YaY
Old 01-31-2006, 01:44 AM   #184
valleycustom
A couple more.
Old 01-31-2006, 01:51 AM   #185
cornutz
All Praise RANDY!!
cornutz's Avatar
Hey Jr...
You have been busy, looks sweet! I hope to make it by real soon to check things out! been busy with the boy and all!
Keep on truckin as they say
cornutz is offline   Reply With Quote
Old 01-31-2006, 10:26 AM   #186
XXL
Seņor Member
XXL's Avatar
A couple more.
If, by chance, you lose a rear trans seal, you're going to know it right away thanks to the auto-smoke leak detector you've got under the tail shaft . Ordinarily I wouldn't be too concerned about placement, but with the canti setup, I'm guessing you've got a fair amount of travel. If the owner decides to drive around while playing with the ride height, you might just see a rear seal problem.
</just saying>
Old 01-31-2006, 12:03 PM   #187
bshelton
My disrespectful comments have been removed.
Last edited by N2TRUX; 02-01-2006 at 12:57 AM. Reason: Please keep your comments respectful of other forum members!
bshelton is offline   Reply With Quote
Old 01-31-2006, 12:39 PM   #188
low4life1
low4life1's Avatar
Somebody correct me if I'm wrong, but there shouldnt be a problem with the rear seal because the carrier bearing takes all the stress off of that joint. The driveshaft near the tranny shouldnt move in or out or anything. it just rotates so there shouldnt be any excessive wear no matter what height or how much playing is done.
low4life1 is offline   Reply With Quote
Old 01-31-2006, 12:45 PM   #189
valleycustom
Your right. We shouldn't have a issue with the rear seal. Even so if the seal did go out the system is going to be ceramic coated. This will cut the temp of the sytem down so much I'll be able to hold the pipes while the truck is driving down the street if I really wanted to, but that wouldn't be a good idea. LOL I thought the same thing but I really didn't have any another options. Once we decided to get the system jet coated I felt that there would be an issue with heat.
Old 01-31-2006, 12:55 PM   #190
valleycustom
</just saying>
Why are you trying to pee on my fire or exhaust? J/K Leaks are the #1 thing I hate the most. If it becomes an issue I will fix it.
Old 01-31-2006, 01:09 PM   #191
low4life1
low4life1's Avatar
Hey, I was just looking back at the beginning of this thread, where you were talking about the 22's having 1/4" clearance on the hood when its down all the way. What size rubber were you using to get this measurement? I'm trying to decide if im gonna cut the rockers off my '69 and if I can fit 22's or of i need to stick with 20's. The roads here suck and I need a decent tire size on this thing, so if you have a tire size that's be sweet. Nice work by the way.
Old 01-31-2006, 01:20 PM   #192
valleycustom
Thanks. I'm using a 285/35/22. You could get away with it if you get a 7.25 bs on a 10" rim. Your going to also have to make new hood hinges. But I also narrowed the front end so that would also make a difference. Your going to have issues with the tire sticking out above the bed if you shave the rockers with a 285. You can run 265/35/22 and fix that issue.
Old 01-31-2006, 01:37 PM   #193
low4life1
low4life1's Avatar
The more I think about it I think im not gonna cut the rockers. I'm gonna use the factory front xmember off of an '85. I sectioned 2 inches out of the center of that width wise, so im hoping that will take care of the width problem. I dont want to deal with figuring out the geometry of the front suspension, so im just gonna bolt the xmember to the frame I'm goinna build. Oh, and I thinkim gonna try to use the reverse tilt hood hinges off of one of these late eighties, early nineties oldmobiles
Old 01-31-2006, 09:21 PM   #194
XXL
Seņor Member
XXL's Avatar
As for valleycustoms, it's obvious you do great work, and I'm guessing you didn't go ape over my question (or if you did, you managed to calm down before posting ). If you consider that there's a LOT of yolk movement in a vehicle with adjustable suspension, and your canti setup looks like you'll have mucho adjustment, my question/concern isn't at all unreasonable. One thing you might consider is simply moving the X back a few inches. In the event of a leak, you won't be completely in the clear, but at least it won't be directly below the seal. Or, as you mentioned... you can leave it as is and deal with it if you actually have a problem.
Last edited by N2TRUX; 02-01-2006 at 01:03 AM. Reason: Please keep your comments respectful of other forum members!
Old 01-31-2006, 11:01 PM   #195
valleycustom
LOL.. I'm cool... Now with the yolk issue. There isn't going to be any back and forth movement at the tailshaft because it's running a two piece driveline. All the movement will be located at the slip shaft before the center support bearing. I would never run a one piece driveline on something with that much lift. You would pull the driveline right out, and become a flying object while your driving down the road.
Old 01-31-2006, 11:33 PM   #196
bshelton
Last edited by N2TRUX; 02-01-2006 at 01:00 AM. Reason: Please keep your comments respectful of other forum members!
Old 01-31-2006, 11:46 PM   #197
valleycustom
They sure do.
Old 02-01-2006, 12:50 AM   #198
72MARIO
72MARIO's Avatar
Hey I dont think if you did loose a seal you would even have a problem back that far from the headders. Guys give him a break with that level of fab skills I am sure he would have though of that issue.
My tranny exploded and sprayed hot tranny fluid on my exhaust. Still Thanking God it did not catch fire as the headders were soaked with burnt fluid. Along with the 05 stang that got all the left over's that did not go up in smoke.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-01-2006, 01:06 AM   #199
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, now that I cleaned all that up we can go back to having some rational discussion about a really awesome suspension. valleycustom please keep the updates coming...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-01-2006, 01:08 AM   #200
valleycustom
Oh trust me I did think about that. The big issue is I have no more room to bring the x pipe down. I've build tons of exhausts and I haven't had one issue yet. The system is also going to be ceramic coated so the temp will be so low you can hold the pipe while the motor is running.
