Old 09-18-2009, 01:51 PM   #176
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Little Body Work on the Blazer/Tub
Before to long she will be a completely restored ride, looking good.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-18-2009, 05:33 PM   #177
71jimmy
71jimmy's Avatar
VT, I found the answer after reading posts on here for about 4hrs. The flow rate seems to be 25-30 cuft. I had tried 20 but it sounded like my 50cf tank would only last 5 minutes with that flow. Dialed it down to 5 and got the snap crackle pop syndrome I new was not correct. Also, apparently, using gas requires a hotter setting than with flux core.
Still interested to hear your experience though.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 09-18-2009, 07:24 PM   #178
litebulblsc
litebulblsc's Avatar
Originally Posted by 71jimmy View Post
VT, I found the answer after reading posts on here for about 4hrs. The flow rate seems to be 25-30 cu ft. I had tried 20 but it sounded like my 50cf tank would only last 5 minutes with that flow. Dialed it down to 5 and got the snap crackle pop syndrome I new was not correct. Also, apparently, using gas requires a hotter setting than with flux core.
What gas mix did you get? What wire?
The gas should make it burn hotter.
I think 25-30 cf/hr seems right.
litebulblsc is offline   Reply With Quote
Old 09-18-2009, 11:13 PM   #179
71jimmy
71jimmy's Avatar
.023 with 75%Argon/25%CO2. It does burn cooler than flux, Verified by the other posts I read.
Sorry VT, didn't mean to hijack your thread.
Old 09-19-2009, 12:10 AM   #180
litebulblsc
Did you reverse your polarity when you made the switch?
Old 09-19-2009, 06:07 AM   #181
vtblazer
vtblazer's Avatar
Just getting around to adressing your question's, sorry.
I'm run what you posted last, .025 wire with a 75/25 mix @ 20CFH for sheet metal.
Anything larger gets the .030 wire.
vtblazer is offline   Reply With Quote
Old 09-19-2009, 06:10 AM   #182
vtblazer
vtblazer's Avatar
Hope not...this one needs to go down the road to make room for my 69 build.
Old 09-20-2009, 01:45 PM   #183
71jimmy
71jimmy's Avatar
I sure did!
I'm finally getting the hang of it. After a little practice it's all good.
Old 09-21-2009, 08:01 AM   #184
vtblazer
vtblazer's Avatar
I sure did!
Whatcha welding on...?
Old 09-21-2009, 04:10 PM   #185
71jimmy
71jimmy's Avatar
Doing my pass. quarter. Had to replace the taillight section and the bottom corner behind the door. I've done my pass. floor section, inner/outer rockers, lower A pillar, lower kickpanel and the support inside the torsion box (the usual) using flux core. It turned out OK, but for something viewable from the outside I wanted to try and get the best welds I could so I stepped up to gas finally. After the pass. side it's on to the driver side and another two years Well maybe only one year, the driver side isn't as bad.
Old 09-21-2009, 06:28 PM   #186
vtblazer
vtblazer's Avatar
Got the firewall in epoxy primer.
Kick panel should be in soon, need to finish the pass. 'a' pillar and go onto priming the dash & interior.
If it dosen't sell soon, it's going outside for the winter.
Old 09-21-2009, 08:32 PM   #187
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Looks awesome Kurt...wish I had the cash!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 09-22-2009, 06:17 AM   #188
vtblazer
vtblazer's Avatar
Maybe just bring your tub up here.
Old 09-22-2009, 06:23 AM   #189
Chevyman63
Chevyman63's Avatar
That's a thought, but an awfully long commute to the body shop for me.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 09-22-2009, 06:29 AM   #190
vtblazer
vtblazer's Avatar
True enough but quit being so picky.
Old 09-22-2009, 06:52 AM   #191
Chevyman63
Chevyman63's Avatar
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 09-24-2009, 10:51 AM   #192
vtblazer
vtblazer's Avatar
Still pounding away...
This morning's work got the pass. inner kick panel cut, shaped & tacked into place.
With luck, I can stay in the shop for the whole day and finish the lower pillar area making the tub one complete piece.
Sheet metal from Tri-Pro fit excellent.
Old 09-24-2009, 02:21 PM   #193
vtblazer
vtblazer's Avatar
Last piece to this 5+ year old puzzle.
Old 09-24-2009, 02:48 PM   #194
jaros44sr
jaros44sr's Avatar
Congrats!!! job well done, glad it all came together for you
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-24-2009, 11:34 PM   #195
TonyJohnson
TonyJohnson's Avatar
Cool...
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 10-04-2009, 07:22 PM   #196
vtblazer
vtblazer's Avatar
Pass. rocker installed, blazer is now 100%.
Little more masking (masking sux) to do.
Will be throwing on primer to the dash & floor areas next.
Old 10-11-2009, 06:00 PM   #197
vtblazer
vtblazer's Avatar
Tore it down a little bit further than I really wanted to but after looking at the small amount of stuff left under the dash, I deceded it was going to be a lot easier to spray in the Lizard Skin with it gone than with it there.
Turns out that there's also some surface rust under the upper-most dash anyway, so I'll put the POR to it prior to spraying on the bedliner.
In case you guys are wondering...this is the tub that will be built as my driver, the one tons will be swapped over soon and the TPI'd/700r/241 drive train is soon to follow.
Tub will be receiving both sound deadener & heat protection on the entire interior, under-side, firewall, under the hood & even inside of the front fenders.
* The Lizard Skin product is 'paintable', and by using an additive that makes the paint 20% flexable, you can use whatever you want to paint it with.
I'll be applying the same base/clear as the exterior to the interior.
The nekked dash:
Old 10-11-2009, 11:04 PM   #198
Big J
Its lookin' like a Blazer!
Big J's Avatar
Ya gotta hurry up and get the lizard stuff on. That CRAP I used from Smart Shoppers is beyond crap. Its shrinking and flaking off....... I can't knock'em to bad because everything else has been great but that liner stuff they sell is total ........, well you know. BTW, lookin' good.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 10-12-2009, 01:01 AM   #199
TonyJohnson
Sounds like it's going to be solid. Should be nice and quiet.
Tony Johnson
Old 10-12-2009, 06:01 AM   #200
vtblazer
vtblazer's Avatar
...and heavier too, kinda wondering about that part.
Up top, under the dash has surface rust, gotta bruch on some more POR.
Can't wait to try & do it upside-down.
