#176 | |
Re: Ackattack's Pro touring restoration thread
I have no doubt that this guy would do a great job, but like you said, I plan on driving it. Rather than lets say a "show quality" paint job, I want what I'm calling a "cruise in/race" paint job. Nice from 3 feet, but oh god there might be a 1/16" too much body gap or a slight bit of overspray where it isn't supposed to be, or no overspray where it is supposed to be. |
#177 | |
I also got some references from the guy I had fix my corvette, so I have to call them. The only thing I have left to do before the cab is ready to come back off to start on the firewall is install the high hump tranny cover....unless whoever I have do the paint/body work has other suggestions. |
#178 |
Progress has temporarily slowed. A few little things I've been working on:
Cut the holes in the dash for the stock style A/C outlets. However the templates I got from old air weren't the best, so the first one I cut, I cut too big. So I had to weld some pieces back in, and that area is a little tight, so I'm going to have to get some different sanding/grinding discs to get back there to clean up the welds. I've been trying to get my power steering hose fixed up. I have a stock high pressure line for the truck, and a stock power steering side for the corvette power steering pump....so all i need is a shop to do for me is to splice them together. Napa (who does hydraulic lines) said they couldn't do it, so they sent me to another shop. That shop said they can't do it either and told me of another shop, but I haven't made it there yet. I filled in some holes on the top/front of the door that normally holds in the vent window....but since I don't have vent windows....no need for holes. While I was welding on the door, I also filled some holes for a mirror (not the sport style that I'm going to use) So now I need to measure and drill new holes. On the other door I noticed some rust behind the hinge. So I took off the hinge to "investigate". The rust is worse than expected, but repairable. I also called one of the references of the body shop that I may have paint my truck. He had very high praise for this shop. I left a message for the body guy to call me, but he hasn't called back (not a good thing in my book....but...) I guess I'll call back tomorrow. On the home front, I spent last weekend de-moding my corvette so hopefully it will be easier to sell. I also started working out again so that is taking upabout an hour and a half each day, but that's life. This weekend me and the wife are taking a "mini-vacation" to go down to Portland just to kinda get away for the weekend....so no work on the truck this weekend (However I do have veteran's day off ![]() |
#179 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Hey man, hows this thing coming? Awesome work so far.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#180 |
I some how missed this build...I am a memeber over at pro-touring.com also.I go by 796spdbu. I like your build! Those wheels look great!
#181 |
well i've gotten a little done since my last update, though the holidays have really slowed progress.
I had two other people come and give me quotes for body/paint. They ranged from $8 - $15k. I can't really afford that at this point. The guy that quoted me $8k said he might be able to do that if it was stripped and primered. So I started stripping the truck. I took the cab to the media blaster. It came out pretty good. I have a little more rust repair work that the blasting uncovered, but no biggie. I also started stripping off the paint on one of the bed sides. Other than that and a few other minor things I haven't done much. It's been real cold here and all of the other stuff that gets in the way. I hope to get back on it next week. |
#182 |
If you weren't on the otherside of the world I could save you some money. I know some reasonable guys here.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#183 |
Nice, looked at the tread one time before when you first broke the truck down keep it coming
#184 |
The LuvShack Garage
Just read it all from start to finish, very nice work, subscribed.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#185 |
Trucks N Tranzams
Looks awesome!!!!!!
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
#186 |
Mr. Thread Killer
That's weird. Last comment was on the 3rd but I'm just now getting the email notice today. Hmmmm.
#187 | |
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 02-19-2009 at 04:32 PM. |
#188 |
Finally, another update!
Life has been pretty busy around here getting ready for the baby....I guess that isn't going to slow down. The little guy is due March 13, but I guess he could show up any time now. As far as progress on the truck goes, I did some minor welding on the floor. There were a few little pin holes that I welded up. I'm going to probably do a little more welding/grinding from the bottom side then both sides of the floor will be ready for POR 15. I guess the big news is that I got in contact with a guy I may have do the paint (Thanks Frizzle Fry!). I told him that I wanted to be under $6k, and he said that gives him a lot to work with, so that sounded good to me. He's down south of Portland, so I sent him a bunch of pictures and he's going to work up a quote for me. He's also going to supply me with some references. Hopefully it will work out well. Assuming everything checks out and we get all the details ironed out, I'm hoping to have it down to him in a few weeks. In prepping for that, I took off the 20s and put the 15" rallies back on (minus the front calipers ![]() Here are some pics of the cab.....sitting in the garage it has developed some surface rust just from the humidity in the air. ![]() ![]() ![]() ![]() ![]() And one of the bedside that I stripped ![]() |
#189 |
There is a inner piece in the grill. The lower one has some "notches" cut out for the turn signals, and the upper one doesn't. So you get an extra upper one and put it in place of the lower one. They're just riveted to the grill.
#190 |
nice start you have on your truck there, i am also going for the pro-touring taste for my 68, nothing better than carving up the corners.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#191 |
What kind of bed cover are you looking at and how much cash is it?
#192 | |
If I remember right, they're about $750 with shipping |
#193 |
we ordered my buddies Gem top from these guys and its awesome!
http://www.conwaysales.com/gemtop/tops/gt_Classic.html His was 9 something painted and delivered! This is by far the nicest flush cover I have ever seen. Its made of metal so no waves and such. I'm not positive that they offer it for our trucks but you might want to check. They will paint it any color that comes on an OEM car at no extra charge. ![]()
#194 |
No baby yet, so I got a little work done on the truck.
I did a little welding on the cab floor and then started painting it with POR 15. I used foam brushes for the first application......what a pain in the butt. I think the next coat I'll spray. That will probably take about 1/3 of the time and cover better. Oh, I also sold my corvette last Monday, so now I officially have the $$$ to get the truck painted!!! ![]() ![]()
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 03-08-2009 at 09:20 PM. |
#195 |
LAIDOUT
Looking great Ack!
I just now read the entire thread. Funny thing I swear I could almost smell the sand blasting when I looked at those photos from when I did mine. I used a lot of sand too, and resorted to filtering it for reuse, which was fine until the sand just got too wet. Anyway, keep up the hard work and good luck with the new baby when he/she arrives! |
#196 |
![]() Join Date: Aug 2005
Looking good man! Can't wait to see some color!
#197 | |
Never Ending Projects
Good luck.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#198 | |
#199 |
just got finished with the second (and last) coat of POR15 to the floor. Now I need buddies to come back over to help me turn the cab back upright. Then I can POR15 the inside of the cab floor and up the fire wall and put it back on the frame (again)
I ordered my toneau cover yesterday. I'm getting a flush mount one from checkmate. It supposed to be here some time next week. I think the total damage on the cover is like $710ish (I guess shipping can change day by day a few dollars) I'll keep working on it some more if I can get a buddy over to fiip the cab and the baby doesn't show up.....got to do something to occupy my time rather than just sitting around waiting. |
#200 |
I am running a checkmate cover and really like it. Nice progress on your cab. I can't wait to finish my frame and get started on my cab.
1972 Blazer body...need to get a thread started for the rest of the story |
