Old 06-16-2009, 03:06 PM   #176
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project Slo-Go 67
Originally Posted by XCSP15 View Post
where did you buy that rear sway bar?
I bought it used from a board member, but the sway bar was originally purchased from Classic performance products. part # CP7401
http://www.classicperform.com/Store/...uck/CP7401.htm
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-29-2009, 11:19 AM   #177
Slick67
Sofa King Crazy!!
Slick67's Avatar
Updates?!?!?!? We want some pics! Slacker...
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 06-29-2009, 11:27 AM   #178
my67chevytruck
Under Construction
I bought some '67 plates for my son at a swap meet..... Trying to get the cab and doors to my buddy's shop this week to start some bodywork.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-29-2009, 11:45 AM   #179
Slick67
Sofa King Crazy!!
Slick67's Avatar
If you don't mind....how much did you give for the tags?
Old 06-29-2009, 11:54 AM   #180
my67chevytruck
Under Construction
He was asking $75 which was cheap compared to most wanting $110.00 I stopped by a couple of times and was reluctant, it was hot as heck and he was ready to leave. Snagged em for $40..
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-29-2009, 11:57 AM   #181
Slick67
Sofa King Crazy!!
Slick67's Avatar
That should be posted in the SCORED area!! Found some new ones for $175, sounded a little pricey but they are unused in new condition.
Old 06-29-2009, 12:22 PM   #182
my67chevytruck
Under Construction
These are unused as well. black and are TX Truck tags, they start with 5W as did the more expensive ones did. I should have looked and bought some for the '56 but I was in a hurry to leave.......
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-27-2009, 09:30 AM   #183
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Heath....any updates??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-27-2009, 09:45 AM   #184
my67chevytruck
Under Construction
Geoff,
Not much progress, we have been stripping another '72 lwb parts truck as it will donate its suspension to my inlaw's '65.
We did get the intake painted, and bolted onto the '67. I need to get a couple of fitting, and then i can install the edel fuel pump, then i need to get some steel or aluminum fuel line and run it. I am still trying to get the cab and doors to my buddy's body shop.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-28-2009, 12:52 PM   #185
my67chevytruck
Under Construction
I picked up a couple of fittings, so i will try to get this mounted today , or tomorrow.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-28-2009, 01:19 PM   #186
Slick67
Sofa King Crazy!!
Slick67's Avatar
Nice. We got some pics! Glad to see things heading in the right direction for ya. Keep it going, cause I think you are passing me by on your project!!
Old 08-01-2009, 06:29 PM   #187
my67chevytruck
Under Construction
ok, we worked on the truck some before the bad weather sat in. We reclocked the fuel pump, and mounted it, we also installed the edelbrock VC's using permadry gaskets, and old spreaders (will replace these later with aluminum ones im guessing) then we cleaned the garage some, looks alot better but still need to find some of my tools that are MIA!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-01-2009, 08:40 PM   #188
mcbassin
Still Learning
mcbassin's Avatar
Cool project! Love all the progress...my son and I just started on his. We will be going through all the same things you guys have already done. Keep the pics coming.
mcbassin is offline   Reply With Quote
Old 08-01-2009, 09:28 PM   #189
my67chevytruck
Under Construction
Thanks. It's been alot of fun! Good luck on your build!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-02-2009, 09:54 AM   #190
gcburdic
Restoration Virgin!
gcburdic's Avatar
VC look good Heath....I like that oil cap too!!!...where'd you get that??
Geoff with a G
Old 08-02-2009, 11:35 AM   #191
my67chevytruck
Under Construction
Geoff,
The oil cap came with the vc's and intake when i bought em. I believe i have seen some like it at O'reilly's. Thanks for the comments , helps to keep us motivated to move forward.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-02-2009, 01:40 PM   #192
gcburdic
Restoration Virgin!
gcburdic's Avatar
cool...thanks...OH...I have some extra hex nuts for the VC's....you need some??
Geoff with a G
Old 08-03-2009, 07:10 AM   #193
my67chevytruck
Under Construction
Did you end up buying a pack?, or are you running without them? Now i have to look at your build again! I'll need some for sure , cant recall how many are used but only think we had four or five.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-03-2009, 08:49 AM   #194
gcburdic
Restoration Virgin!
gcburdic's Avatar
Yep....I only needed like 4, so I think I got like 6 left....10 come in a pack and it's $3.25/ pack through Summit....i think you'll need 14 per VC.....
Geoff with a G
Old 08-03-2009, 10:23 AM   #195
my67chevytruck
Under Construction
Cool, thanks for the info. Ill add to my list .
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-03-2009, 10:34 AM   #196
Slick67
Sofa King Crazy!!
Slick67's Avatar
I like that "710" also, looks clean. Glad to see your progress report this morning! I'm the slacker this morning, have not posted my weekend progress, but I am doing it now. BTW, the VCs are cool!
Old 08-03-2009, 01:35 PM   #197
my67chevytruck
Under Construction
Thanks for the Kudo's. going to check out your progress now.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-03-2009, 02:08 PM   #198
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome progress Heath! That thing is coming right along.
What tires are on the new wheels?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-03-2009, 04:19 PM   #199
my67chevytruck
Under Construction
Nate,
Thanks for the comment!
The tires are Kumho Proxes. we had the rims/tires mounted for a bit, but took them back off and have them stored in the corner for now.
BTW, Blank Slate is a Bad MoFo!!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-14-2009, 07:12 AM   #200
my67chevytruck
Under Construction
Lil Progress,
The bed is ready for primer...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
