Old 09-05-2013, 11:03 AM   #176
snoopy0775
snoopy0775's Avatar
Re: My 1954 Chevy PickUp-truck
Hi,
iīm going frustrated with assembling the bed...it looks like the bed sits to high because now i have a gap between the running board filler piece and the bed itself. I will send detailed photos on suterday.
Does anyone have informations how tall the original cross sills are on a 54 build Chevy Truck? Next question: Is my Assembling correct (sketched below)?
Thanks, Robin
snoopy0775 is offline   Reply With Quote
Old 09-05-2013, 04:23 PM   #177
nvrdone
Robin: I've got a '49 3100 and your bed set up looks the same as mine so I think it's correct. I have about 3/8" ( 8mm? ) between the top of the filler panel and the bottom of the bed side. How big is your gap?
I'm sure someone with a '54 will chime in and give you some good info.
nvrdone is offline   Reply With Quote
Old 09-05-2013, 05:59 PM   #178
brikar
brikar's Avatar
Hi Robin the drawing is correct and as far as I know the cross sills are all the same with the exception of the different hole patterns for the different years of wood,and for the gap there is one mine is about 1/2 inch between the box and filler plate
brikar is offline   Reply With Quote
Old 09-06-2013, 12:57 AM   #179
snoopy0775
snoopy0775's Avatar
Hi, the gap is about 3/4" to 1" ...the filler panel canīt be screwed to the fender hole. I will send Pictures on Saturday...
Thanks, Robin.
Old 09-06-2013, 12:15 PM   #180
snoopy0775
snoopy0775's Avatar
Hi,
iīve been in the Garage already today...here are the pics i made (donīt know what is wrong):
Badly i havenīt take pictures in the past when i disassembled the truck :-(
Old 09-06-2013, 12:16 PM   #181
snoopy0775
snoopy0775's Avatar
Old 09-06-2013, 12:20 PM   #182
snoopy0775
snoopy0775's Avatar
and some pictures of my placed inline-bulkhead :
Old 09-06-2013, 01:22 PM   #183
watahyahknow
watahyahknow's Avatar
its allmost like the floor needs to lay on top of the L profile either that or the profile is mounted to low on the bed
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-06-2013, 01:54 PM   #184
nvrdone
Hey Robin - from the pictures it looks like the running board isn't fastened to the fear fender. If you fasten them together does that move the filler panel up and close the gap ? Do you have an after market frame or the stock one ? Are the running board brackets mounted correctly? Could you shim between the running board bracket and the bottom of the running board to close that gap ?
Maybe someone should hop a flight and come over and help you out. Anyone willing ?
Old 09-06-2013, 04:17 PM   #185
_Ogre
_Ogre's Avatar
looks like your bed is the correct height, the step matches your fender.
if you close the gap with a shorter bed sill your fender will be under the step.
you filler piece looks new, maybe that is for a different year.
shop air compressor timer
Old 09-06-2013, 05:37 PM   #186
brikar
brikar's Avatar
Starting from the front of the box you should have a rubber block 1/4 inch and the small plate under your cross bar the second cross has nothing ,the third and fourth has the same as the first ,and the first,third and fourth is what the box bolts run threw to bolt down the box to frame,on the one picture with the 2 arrows you point out gaps there should not be any,the other thing i noticed is it looks like your frame has bean cut off at the end where your bolts hold the box down,it almost looks like your jacks are holding up the box to high in the rear but its hard to tell from the picture
Old 09-06-2013, 08:32 PM   #187
1956cameo
1956cameo's Avatar
I don't think I will be of any help, but I do know that I used to have a 1954 chevy truck that had a ruined frame because of a bad clip job. We had a rusted out 1951 truck that had a good frame and combined the1954 sheet metal with the 1951 frame. Due to differences in the changes made over the years the bed sat about two inches too high. Possibly you have an older frame with the 54 sheet metal. However that is just a slight possibility since it doesn't seem to sit as high as my bed did; and I assume it fit properly when you took the truck apart.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 09-08-2013, 06:44 PM   #188
nvrdone
More thoughts on your bed problem. Is it possible that you have a 54 bed on a pre 53 frame? If I remember right the 54 frame has a shorter kick up over the axle so the bed sits lower. Was your bed installed on this frame or is it an aftermarket bed that you are trying to install?
Old 09-09-2013, 07:33 AM   #189
Niteshade
I also have a 1954 and I am currently taking the bed off. If I can help by doing some measurements let me know.
Are the bed rails that came with your kit al the same height? I am looking at my frame and see no differences with yours, but if the rails are in the wrong places then I think that would cause your problem.
Niteshade is offline   Reply With Quote
Old 09-09-2013, 03:48 PM   #190
PurdueSD
PurdueSD's Avatar
Ya, if your frame is not 54/55, then your 54 bed wont sit down far enough.
Another thing to consider is the 54/55 splash aprons are different than the 47-53.
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 09-09-2013, 11:58 PM   #191
Jimmy51
Good evening Gents:
This will be my first post. Been reviewing all the posts for gaining some knowledge before I begin my 1951 GMC build. I wanted to say thank you for all the great insight and start some dialogue with anyone with experience with what I am about to attempt.
For starters, I replaced the rusted and tattered 1951 chassis for a 2000 S-10 chassis and purchased a motor mount kit and the S-10 chassis swap kit from Advanced Design Engineering (ADE). It only made since because Robert Hertz, owner of ADE had already did all the figuring/measurements and fabricated all the body mount brackets, bed sill cross members and the like for the S-10 Chassis swap. Plus I am a neophyte (as green or as wet behind the ears as it gets) at this venture. So green I am still learning the nomenclature of frame and body parts.
Here's my question, does anyone know if there are any good resources (books, periodicals, drawings, or assembly notes) out there to help a first timer with the proper steps to take starting with step one through step one thousand? With a ton of helpful hints / lessons learned to avoid making the big mistakes and blunders? I know I am going to make some anyway but always like not repeating the same ones someone else did and is willing to share!
Thank you in advance,
Jimmy51 is offline   Reply With Quote
Old 09-10-2013, 12:17 AM   #192
Jimmy51
Some Frame pictures
Unfortunately, can only upload one picture per session. File size is only 51.7 kb so not totally sure that is the limitation or not.
