Old 09-09-2009, 07:58 AM   #176
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 1970 VA Longbed Project
Looks great. Makes me miss mine already. Keep up the good work.
--Josh
Old 09-09-2009, 09:47 AM   #177
brian69longbed
brian69longbed's Avatar
you should put rags under your jack stands to save your nice new paint!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 09-09-2009, 10:18 AM   #178
70k52wd
Blaze-Air
70k52wd's Avatar
70k52wd is offline   Reply With Quote
Old 09-09-2009, 10:29 AM   #179
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by my67chevytruck View Post
looking good... have you posted pics of your Z28? I'm partial to blue myself...... keep up the great work...
I'll have to find and scan an old picture or two...That was 12 years ago....sold it about 8 years ago.
Thanks for the encouragement. Sorry you had to sell yours...
Originally Posted by 70k52wd View Post
I will. I thought of that after looking at the pictures the first day but forgot about it when I got back over and started working on it again.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-09-2009, 10:39 AM   #180
VA72C10
VA72C10
VA72C10's Avatar
Well regrettfully, progress is going to slow as I have to do some work I will be out of town on business for a few days each of the coming weeks and have a lot of family plans as well.
The next order of business for me is cleaning the rear, changing the fluid and gasket on that and painting it. The drums were almost new when I bought it and there's been about 10 miles put on it since then so I think they'll be fine as long as they haven't locked up too bad from sitting. Just going to clean them up and paint them with caliper paint.
Then I will be taking apart the front end, cleaning it, painting it, and putting it all back together with new components. That will include drop spindles, disc brakes, and bags
Sometime between all this we will be flipping the cab on its' back for me to clean up the underside. Then Jason will finalize the welding on the patch panels and cab supports and I will paint the underside with rust stop and then undercoating.
At that point the cab should be able to go back on the frame and we'll be starting final body work and paint!!!
I'm gonna miss all of the fall shows and cruise-ins, but should have it finished in a few months and be able to do the wiring and interior over the winter to have it ready for the spring!!! That's the plan at least...
Old 09-09-2009, 12:12 PM   #181
gcburdic
Restoration Virgin!
gcburdic's Avatar
Jonathan,
On the rear end...you might want to go ahead and change out the oil seals and axle bearings while you have the fluid and diff cover off....after 40+ years they'll leak on you once you get it back together and you'll wish you did it now!!! JMHO
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-09-2009, 12:14 PM   #182
VA72C10
VA72C10
VA72C10's Avatar
Here you go...put together a small collage of the Z28 and my friend Tim's 49GMC...the truck that got me interested in old trucks...I will do an older GMC like this some day.....but SLAMMED
The pictures are so small because I was really bad at photography back then w/ a 35mm....I had the car or truck with a TON of blank space around it in the pictures...didn't frame my subject well at all The car is like a dot on the 4X6 picture...
Old 09-09-2009, 12:15 PM   #183
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by gcburdic View Post
Jonathan,
That's good advice....I've never attempted that but I'm always up for something new....
Old 09-09-2009, 12:34 PM   #184
gcburdic
Restoration Virgin!
gcburdic's Avatar
Here's a write up I'll probably follow when I do it!!!
http://67-72chevytrucks.com/vboard/s...ight=star+vary
If you get'er done soon...post up more pics and let us know how that write up worked for you!!!
EDIT: and here's a little write up for the evaluation of parts used too....http://67-72chevytrucks.com/vboard/s...d.php?t=358795
Geoff with a G
Old 09-09-2009, 12:55 PM   #185
VA72C10
VA72C10
VA72C10's Avatar
Thanks Geoff, that will come in handy!!!
Old 09-09-2009, 01:19 PM   #186
nuke1
nuke1's Avatar
just stopped by to check out how it is going and WOW, that looks killa, you sure made some progress, looking great, and hopefully it will be on its wheels in no time!
I agree alos on the axle seal and wheel bearings, go through it, do the pinion seal also, it is just cheap insurance for all the hard work you are doin.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 09-09-2009, 02:16 PM   #187
VA72C10
VA72C10
VA72C10's Avatar
Thanks! Your truck has come out awesome so far and will be even better once you tear back into it!
Yeah, I will go through the axle and make it up to snuff with the rest of the truck...you guys are gonna nickel and dime me to death
Old 09-09-2009, 02:18 PM   #188
67cheby
67cheby
67cheby's Avatar
are the front inners for sale
67cheby is offline   Reply With Quote
Old 09-09-2009, 02:18 PM   #189
67cheby
67cheby
67cheby's Avatar
sorry that posted in the wrong spot
Old 09-09-2009, 02:23 PM   #190
VA72C10
VA72C10
VA72C10's Avatar
No problem...
Old 09-10-2009, 09:43 PM   #191
VA72C10
VA72C10
VA72C10's Avatar
Out of town right now. But I'm still working on the truck by research and credit card
Actually, I am paying all of this up front and not charging anything. (Which makes it hard) But I did order several parts today, looked for the best deal and will call those parts orders in tomorrow...
Old 09-11-2009, 12:31 PM   #192
nuke1
nuke1's Avatar
Nice, glad to hear you are still shopping, and as my wife saiud to me, " is it ever gonna be done" well we all know the answer to that one, just a big grin and say yes dear.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 09-11-2009, 06:42 PM   #193
VA72C10
VA72C10
VA72C10's Avatar
Got bag plates in the mail today and have a lot of the engine parts to finish it up on the way.
Old 09-12-2009, 05:29 PM   #194
VA72C10
VA72C10
VA72C10's Avatar
Got some more parts in today for the engine. It's gonna be purdy when it's done
Worked on tearing down the rest of the components off the engine to prep for paint. Gotta read up on the best ways to prep it since I'm putting BC/CC on it.
Worked on tearing apart the front suspension until I got a call and had to run to the house to meet a guy to sell some parts. It's good and bad...didn't get what I wanted to done, but traded for a van tilt and still ended up with 150 cash to go towards the truck. I'll be needing it too with all the front end stuff I need to replace. Idler arm has way too much play, Tie rods are of course shot, the adjustment sleeves look bag, U-bolts look good , but with what I've read recently I'm going to get newer/larger U-bolts for safety.
What do you guys think about the upper and lower control arms...do I need to change the cross shafts and/or the control arm bushings? THey seem tight and the expenses are really adding up right now...
Old 09-12-2009, 05:30 PM   #195
VA72C10
VA72C10
VA72C10's Avatar
I will get some pictures posted up this evening....getting ready to take the family to the park right now...
Old 09-12-2009, 07:38 PM   #196
70k52wd
Blaze-Air
70k52wd's Avatar
Do the bushings, you have it apart and doing all else.
Or get some of those new Porterbuilt units. You only live once.
You may want to check out POL for brand new control arms, by the time you clean and replace all the bushings, for a few bucks more you can have those. They also have some decent looking tubular stuff, inexpensive too. It's only money, you'll get more. j/k, I feel your $$$ pain.
Old 09-12-2009, 08:38 PM   #197
VA72C10
VA72C10
VA72C10's Avatar
If you'd like to contribute some arms to my build I'll put whatever type/brand you want...
Old 09-13-2009, 12:17 AM   #198
70k52wd
Blaze-Air
70k52wd's Avatar
Your stockers are all that's needed. But I think you should do the bushings while your in there.
The bigger u-bolts you mentioned earlier. Are you talking about the saddle bolts that hold the ca's on to the cross member? If so, you can get new 9/16 style which is the bigger u-bolts, get them from the HELP parts section at your local parts store. They even come with nice top lock type nuts. Cheap also.
It took me a while to figure out the base coat clear coat.
Who makes high temp bc/cc engine paint? I've never looked into it.
Old 09-13-2009, 10:13 AM   #199
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the info on the saddle bolts...I'll check out a HELP section today....was about to pay CPP 35 shipped for them in 1/2"...
The BC/CC will be the same thing on the exterior. I have been told that you can run the standard stuff as long as you prep and prime the engine very well. It will most likely burn a little right by the headers but I have seen several jobs in person that have been run for a while and they look very good so I'm going to try it...
Old 09-13-2009, 10:39 AM   #200
70k52wd
Blaze-Air
70k52wd's Avatar
Kak...I don't remember what I paid, but I'm sure it wasn't that much.
You may have to order them, but even my po dunk parts store had one set, I had to order the other set.
They are real nice, and very heavy duty.
I forgot to do this, but when you get them, post a pic so that other folks can be aware that not everything has to come from a suspension supplier.
The BC/CC will be the same thing on the exterior.quote.
I learn something everyday on here.
