Old 05-25-2010, 10:29 AM   #176
kustombrad
kustombrad's Avatar
Re: Project "49 No Buck$"
The gauges are from a 37 lasalle! I've already started restoring them and they're going to to look awesome. Hard to believe how nice they are being that old.
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 05-25-2010, 05:31 PM   #177
T Hilde
They look cool. I'd probably F up the clock trying to turn it into a tachometer. Good luck on the resto.
T Hilde is offline   Reply With Quote
Old 05-27-2010, 11:01 PM   #178
kustombrad
kustombrad's Avatar
More stuff on the never-ending, cheap-ass, hot rod truck! Last week after discussing it over with my friend Alex, We decided it still needed more striping under the hood to tie in with the orange on the motor Looking better, still may add more!
Old 05-27-2010, 11:16 PM   #179
daverod
SSN 706
daverod's Avatar
Nice build. Liking the piston cap.
daverod is offline   Reply With Quote
Old 05-27-2010, 11:36 PM   #180
kustombrad
kustombrad's Avatar
Now on to what I think is the cool stuff. Everyone knows I always try to do things cheap, or shall I say inexpensively. It doesn't always work out that way, but I try my best. After aquiring these gauges, I sat down and did a little thinking. How much do I feel like spending on gauges that are part of a low budget, do-it-yourself build? Very little! So here we go. First thing I did was take the gauges apart. Pretty simple, just take your time, take pictures and put EVERYTHING in ziplock bags! Took the face plates off and cleaned them up with some warm water and detergent. Other than some 70+ year old stains, they look like new! I looked into the 12 volt quartz clock adapters (starting at around $85 just for the clock) and decided I could do better. I went down to our local Michaels Art & Crafts store and bought a A battery quartz clock kit for $8 bucks! If those can keep time for a couple years on a little battery, then who am I to argue?! Took the factory clock back and marked where I'd have to cut it to fit the box. Here are the original needles on the left and new ones on the right So I cut the original ones to where they widen out and cut the new ones to about 1/2" from the base. I mixed up some 4 minute epoxy and glued the old on top of the new I then carefully ground down the backside of the machined top and glued the serrated nut to screw down the new/old clock hands Now I just need to clean up the glue, mix up some maroon/red and they'll look like new!
Old 05-28-2010, 10:02 AM   #181
kustombrad
kustombrad's Avatar
After blasting all the rust off both speedo and clock backing plates (and finishing up all the rough edges on my cuts) I sprayed them both in aluminum Rustoleum. I set the cardboard insert back in place and set it aside. I took the original clock took apart the guts and with my diegrinder, cut everything off flush. Now all that remained was the flat piece and the stands that the face screws onto. I drilled a bigger hole into the center of the plate and slid in on the clock, which was then tightened down. I screwed the faceplate onto the clock with the little factory screws put the clock arms on on set it back in the base! I already found and ordered 2 pieces of convex glass on Ebay for $20 for the pair. I need to go to Radio Shack and find an AA battery holder with some wires and solder those to the clock, to make it easier to change out. Need 2 5" square edge O-rings to put between the tapered piece on the glass that rests on the gauge face itself. When finished, I'll have about $25 and a few hours time for a perfectly running clock. I rebuilt the speedo guts myself and everything purrs smoothly and a total of about $15 into it. I'll put pics up shortly once they are back together completely.
Old 05-28-2010, 11:50 AM   #182
chevyrestoguy
chevyrestoguy's Avatar
Looks Great!
You need to tell your "buddy" Alex to quit making comments like:
"That firewall would look nicer if you welded up all 75 holes, did the bodywork, sprayed it chassis black and pinstriped the heck out of it"
"I'd repaint the dash if it were me......."
"These gauges would look GREAT in your truck"
What kind of a friend is that? Sounds like he's costing you alot of money and time.
signed,
Alex
By the way, if you thought that those gauges were out of a '37 LaSalle, you're wrong. They are actually the gauges out of Howard Hughes's 1928 Duesenberg Boat-tail Speedster Convertible (the only one ever made). You could have gotten $25,000 for the pair. Now, the Pebble Beach Concours Society is coordinating with the U.S. Air Force to have the B-2 Bomber do a precision bomb drop on your house.
You know, if it was MY truck, I would paint the inner fenders and the underside of the hood and go nuts on the pinstriping...................buddy.
chevyrestoguy is offline   Reply With Quote
Old 05-28-2010, 12:22 PM   #183
bjcaldwe
bjcaldwe's Avatar
Very nice work as usual.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 05-28-2010, 12:41 PM   #184
OrrieG
OrrieG's Avatar
That is really nice. I use those same clock works on some of my wife's custom clocks but we only get a couple of months out of rechargeable batteries.
OrrieG is offline   Reply With Quote
Old 05-28-2010, 01:01 PM   #185
kustombrad
kustombrad's Avatar
Use the bunny batteries, they work the best...
Old 05-28-2010, 07:26 PM   #186
solidaxel
solidaxel's Avatar
Did you ever finish your windshield wiper project??
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-28-2010, 10:38 PM   #187
Daniel U
Daniel U's Avatar
Very cool stuff man!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 05-28-2010, 11:49 PM   #188
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Man, you guys are amazing! I read and see all the stuff that you do to you truck and say to myself, if I could only do half the mods to my truck I would be happy.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 05-28-2010, 11:52 PM   #189
Fat Mike
Fat Mike's Avatar
Tri5
Man you have alot of talent! Your build is just as good as everyone else and I am sure everyone always waits to see what next for you.
Fat Mike is offline   Reply With Quote
Old 05-29-2010, 12:33 AM   #190
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Beautiful work.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 05-29-2010, 09:48 AM   #191
54 jimmy
54 jimmy's Avatar
yea what happened with the wipersdid you get that working. i will beready to do mine soon and would like to do it on the cheap.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 05-29-2010, 10:50 AM   #192
kustombrad
kustombrad's Avatar
Wiper deal is still going to happen, but I need to refigure the right side wiper rod. With the way the motor is mounted it causes flex on that side! Im almost there!
Old 05-30-2010, 07:56 PM   #193
solidaxel
solidaxel's Avatar
.............So the WW motor is in the final position?
The only thing you have left is to re do the wiper arm, why not use the stock one?
LS 3 4L70E
Old 06-02-2010, 09:48 AM   #194
kustombrad
kustombrad's Avatar
I had put a bend in the stock passenger side rod and now it flexes. I need to fix the prob and wrap that up before the gauges are installed. I finally got my heads back so I need to get the engine together and get this thing done!
Old 06-02-2010, 10:14 AM   #195
solidaxel
solidaxel's Avatar
Thanks for the update.
I am still trying to make a bracket and get the angle correct, your right that, must be complete before wiring and gauges go in. Thanks for your posts.
LS 3 4L70E
Old 06-05-2010, 12:56 AM   #196
solidaxel
solidaxel's Avatar
Per our conversation on hoses.
The check is in the mail, said to look for it around the 10th June
LS 3 4L70E
Old 06-09-2010, 11:02 AM   #197
kustombrad
kustombrad's Avatar
Needed to get the gauges mocked up into place before I put them together. Since the two gauges (factory and LaSalle) have differently clocked mounting brackets, I needed to figure this out. Instead of making some round steel brackets, I thought about what would be out there that I could already use. I ran over and saw my friend Larry at the local transmission shop and told him what I needed and he told me to look in the back room. I grabbed a couple of old, wore out steels that are part of the clutch from an automatic. Perfect! I then chopped them up with my angle grinder and and bolted them to the original location in the dash. I then set the new gauges up there, marked the holes and drilled them to line up with the old gauges Here they are ready to be finished and bolted in for good!
Old 06-09-2010, 11:16 AM   #198
Daniel U
Daniel U's Avatar
Very Cool!
Old 06-09-2010, 09:17 PM   #199
T Hilde
Man you must be living right. Nicely done.
Old 06-10-2010, 12:15 AM   #200
nickp51chevy
Looks great!
Had;
