12-07-2011, 10:17 AM | #176 |
Re: Project "Poison Ivy" 54 GMC
How did you get the whele tubs rusty already?
12-07-2011, 10:21 AM | #177 |
I used pieces from the original bed sides where I cut out for tire clearance.. Where I welded and ground the edges I sprayed it with salt water I mixed up to get it to rust.. I am going to do the same to the piece I made around the gas filler..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
12-07-2011, 01:33 PM | #178 |
Looking good. I'm not even a Ford guy but the truck on the hoist looks sweet...
Nice work Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
12-07-2011, 08:43 PM | #179 |
Man that thing is sooooooooooooooooooooo sweet.
wonder what the mpg will be
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-08-2011, 10:51 AM | #180 |
License plate dilemma solved! I took the radius of the bumper ends and and used them in the center... The opening is a little tight to be able to completely view the plate but I will let it rock until the Law has in issue... I am not crazy about it but its pretty clean looking and the best I could really come up with.. next I am going to build a filler panel to go under the plate to the bumper and carry from the back side of the bed to the to inside of the bumper, very similar to how the front bumper is...
12-08-2011, 11:11 AM | #181 |
Looks good to me...Good solution.
Marc
12-08-2011, 05:03 PM | #182 |
that'll work...up here they piss and moan over front plate too, funny how something that is mandatory for a vehicle doesn't look good on them. Must have been hard putting that first cut in.
12-08-2011, 05:38 PM | #183 |
It was hard putting all the cuts in... From what I learned it is made of spring steel... It wiped the teeth right off of the air saw blade first pass... All cutting wheel there!
12-08-2011, 05:43 PM | #184 |
lookin; good
12-09-2011, 10:58 AM | #185 |
I really like this truck. I like how even the new mods were aged. If I can find a 47-59 Burb that is in similar shape I would build it in a similar fashion.
Posted via Mobile Device |
12-12-2011, 09:22 AM | #186 |
I fabbed this together on Saturday... 10 points if you can guess what its for... Yes it is for the truck..
12-12-2011, 09:27 AM | #187 |
Exhaust hanger?
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban |
12-12-2011, 10:03 AM | #188 |
Large drink and a phone.
12-12-2011, 10:09 AM | #189 |
At first I was thinking it would go around your gas filler, but that already has a bead on it so probably not that.
Leg restraint for passengers when hauling @$$? |
12-12-2011, 10:41 AM | #190 |
Center consol?
12-12-2011, 10:42 AM | #191 |
heat shield for a airbag?
12-12-2011, 11:14 AM | #192 |
SSN 706
bumper push bar thingie.
12-12-2011, 01:22 PM | #193 |
hmmmmmmm - driveshaft protector ?
12-12-2011, 05:45 PM | #194 |
I'm a little stumped, but I think I can rule a few things out. You have a bench seat, so I don't see it being an armrest. By the fab work, it is probably something that is going to be seen. So I'm assuming inside the cab or outside. Not under the truck. It looks like one edge has a 90 on it and the other has a rolled edge, so I think it is going to flat up against something.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
12-13-2011, 09:26 AM | #195 |
Lots of good guesses!!! Actually you guys gave me some other ideas! We were talking at the shop one night and since the truck lived its life on a nursery it needed a few props to keep that theme rolling.. Here is what I came up with.. Stay tuned for more cool ideas coming your way...
12-13-2011, 01:06 PM | #196 |
Tot Roddin'
Love the new bracket!
If I may... how did you weather it?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-13-2011, 01:24 PM | #197 |
Thanks... I used four different spray bombs, Black, brown, tan and a red oxide primer... a little 320 sandpaper and a scuff pad... I didn't spray this one with sal****er to get it to rust yet.. I might let nature run its course..
12-13-2011, 01:51 PM | #198 |
very cool
12-13-2011, 03:24 PM | #199 |
This is a great theme build....very creative. Maybe some burlap bags of grass seed in the bed would be a nice touch.
Marc
12-13-2011, 08:10 PM | #200 |
Nice bracket, looks perfect. Would make great cup holders, that hole dimpler makers everything look cool.
