Old 10-22-2009, 09:20 PM   #176
tomlamb
Re: 66 frame off resto-mod
Here is the dash pics as promised...
tomlamb is offline   Reply With Quote
Old 10-22-2009, 09:39 PM   #177
markeb01
Senior Enthusiast
markeb01's Avatar
Nice job. That looks great. What brand gauges did you use?
Old 10-22-2009, 09:57 PM   #178
northern 85
northern 85's Avatar
Wow that looks nice! Is that a chrome bezel?If so where did you get it?
northern 85 is offline   Reply With Quote
Old 10-23-2009, 08:25 AM   #179
OLDIRON69
Originally Posted by joe231 View Post
if you don't mind a couple questions....where did you get it and what exactly is it called?
nice progress Tom!!
Home Depot had it on an isle display. If I get a chance today I will go to Lowes and look to see if they sell it. It reflected heat like you wouldn't believe. Sound was reduced a good 30-40%. I plan to put it in everything I restore from now on.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 10-23-2009, 09:08 AM   #180
joe231
joe231's Avatar
CHEVY ONLY
Old 10-23-2009, 01:35 PM   #181
OLDIRON69
http://www.homedepot.com/Building-Ma...atalogId=10053
Link to Home Depot, I paid $25.00 per roll when I bought it 2 yrs. ago.. This may be a different brand but same stuff. I used liquid nails to put it down since it was just an old work truck. I'm sure you could use headliner adhesive.
05 2500HD 6.0 excab
Old 10-24-2009, 08:18 AM   #182
tomlamb
They are speedhut brand http://www.speedhut.com/.
Old 10-24-2009, 08:21 AM   #183
tomlamb
It is the stock bezel, RRC made a plate out of aluminum for the gauges to mount to.
Old 10-25-2009, 12:55 AM   #184
TimE
Hey Y'all!!
TimE's Avatar
Wow! You've come a long way Tom. Lookin' good!!!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 11-01-2009, 11:32 AM   #185
tomlamb
Thanks, unfortunately we have run into some stalls. The blaster is overbooked so getting stuff out of them has been painful. My bed still hasn't been blasted and the scheduling wows have now spread to the painter. I hope to get the doors next week but the hood and cowl are still waiting their turn to go under the block.
Anyone know of a good blaster in the so-call area?
Old 11-02-2009, 11:37 AM   #186
Scot_Douglas
Scot_Douglas's Avatar
Not sure how that would work as a dynamat replacement. I have both in my garage - dynamat is heavy, foil-backed on one side, adhesive-backed on the other. I used it for sound deadening and improved bass response in my wife's car.
Reflectix is essentially bubble wrap that is foil-backed on both sides and is 5/16" thick - I've used it for wall insulation and winter window covering - but I"m not sure how durable it would be for a floor application. If it does work - it would be beneficial because it is considerably lighter (and cheaper! ) than dynamat.
Just my $0.02
Beautiful truck.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 11-21-2009, 08:54 PM   #187
tomlamb
Well some bad stuff happened once the bed got into the blast booth
Here is a chunk of the bondo that was covering it all up, almost an inch thick
Anyone know a place I can get a repair panel?
Old 11-21-2009, 09:57 PM   #188
LILRED66
LILRED66's Avatar
www.lmctruck.com
www.oldchevytrucks.com
www.bowtiebits.com
www.classicparts.com
www.truckandcarshop.com
LILRED66 is offline   Reply With Quote
Old 11-21-2009, 10:09 PM   #189
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Also Mar-K All they sell is bed stuff, and they have really good stuff. Just ask Alan.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-21-2009, 10:16 PM   #190
tomlamb
it looks like the panels they sell only go about a foot up and the crunch is all the way to the belt line. Has anyone seen one of the patch panels, is there one that goes all the way up to the belt line?
Old 11-21-2009, 10:17 PM   #191
tomlamb
On another note, we tried to fire up the engine today with no luck, fuel pump didn't kick on and it wouldn't fire. I'll be calling Current Performance on Monday to see what may be happening...
Old 11-21-2009, 11:11 PM   #192
tomlamb
It looks like Jim carter may have the full quarter panel. Thanks Tony!
Old 11-25-2009, 08:50 AM   #193
tomlamb
While we are waiting for the repair panel, we got the sound proofing done.
The stuff from Lowes
Old 11-25-2009, 09:36 AM   #194
61TWUK
61TWUK's Avatar
Man great progress!!!
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 11-25-2009, 11:38 AM   #195
glendale
glendale's Avatar
Attachment 507047
Attachment 507048
so you just had the stock surround chromed?
glendale is offline   Reply With Quote
Old 11-25-2009, 01:03 PM   #196
Dan in Pasadena
Dan in Pasadena's Avatar
Tom,
Looking good. WHat's the black stuff prior to the silver stuff? I'm familiar with the silver stuff. I assume you put it on with spray adhesive? But is the black stuff self adhesive or what?
Dan in Pasadena is offline   Reply With Quote
Old 11-25-2009, 10:42 PM   #197
TimE
Hey Y'all!!
TimE's Avatar
Looks good Tom.
Btw, save the receipts for the sound deadener(sp?) and you might be able to claim it on your taxes(if you are a homeowner--that stuff is considered insulation)...I know it's not real expensive but every little bit helps, right?
Old 11-27-2009, 11:18 AM   #198
tomlamb
That is how mine came, we just made a panel that bolted to the back...
Old 11-27-2009, 11:20 AM   #199
tomlamb
Originally Posted by Dan in Pasadena View Post
Tom,
It's the Lowes peal and seal recommended by so many here. Like dynomat but not $$$. It had a sticky side that I put down before the silver stuff.
Old 11-27-2009, 12:02 PM   #200
ol Curt
Junior Member
ol Curt's Avatar
here ya go....
http://67-72chevytrucks.com/vboard/s...9&postcount=27
it is Peel-N-Seal from Lowes
I have never been able to find Peel n Seal. My
lowes say they no longer carry it.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
