Old 01-04-2010, 10:56 PM   #176
onlyifihadachevy
Re: Got a new truck
We got some progress done, but still waiting for the shocks. Got the a new seat mount but its a little too low but will work.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 01-04-2010, 11:39 PM   #177
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
any close ups of the tranny and tcase?
was wondering what that plate is coming off the side
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 01-05-2010, 01:19 AM   #178
onlyifihadachevy
Re: Got a new truck
i just got some pics of the drivers side of them and the plate I think your speaking of. I think it's for checking the gears and such. From what I know i belive it to be a sm465 with a np205. I didn't really looks on the t-case but i alost sure it is.
the pics sory for the quility.
My 72 thread
Old 01-05-2010, 12:19 PM   #179
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
the tranny looks like a sm465 but the tcase looks like a Rockwell tcase. t221 is what i think the name is?
my jimmy build
Old 01-05-2010, 12:33 PM   #180
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Got a new truck
Yep, that's a T221.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-05-2010, 07:24 PM   #181
onlyifihadachevy
Re: Got a new truck
I didn't really look so if they are they are. And from what i just looked at they have the same low ratio. And now as i look at the pic. It doesn't have the flange behind the front output like the np205 or 203.
Yukon what is the reason for you swapping out the t221? I think i remember seeing it in one of your threads if i remember correctly.
Hopefully today i will have pics with the doors on.
My 72 thread
Old 01-06-2010, 12:23 AM   #182
onlyifihadachevy
Re: Got a new truck
Well we put the doors on and we are now trying to weld the top back on but it might not work. I will get pics tomorrow.
My 72 thread
Old 01-06-2010, 02:08 AM   #183
onlyifihadachevy
Re: Got a new truck
I figured I would put the up dates up tonght. My dad got the top tacked on and is pretty close to stock and how it should end up. We have to make seat mounts still. But the pics.
My 72 thread
Old 01-06-2010, 10:34 AM   #184
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Got a new truck
I screwed up and let my T221 get low on gear oil and took out some bearings - I had a spare NP205 so seemed like a good opportunity to upgrade. T221's are strong but they are harder to get parts for and a bit louder than an NP205.
Old 01-07-2010, 12:48 AM   #185
onlyifihadachevy
Re: Got a new truck
Well if it breaks we will swap it for a 205. well we are out of gas for the welder so hopefully tomorrow.
Well today i think we are picking up a surburban.
My 72 thread
Old 01-09-2010, 01:08 AM   #186
onlyifihadachevy
Re: Got a new truck
Well we got the suburban yesterday and went to work on this today but one of the lights were not working so we went and bought a light for the garage and some wire and switches for the truck. By the time we were done it was dark so we are putting working till tomorrow.
The plans are to put the motor mounts in my black truck and welding in a rough crossmember so we can go wheeling sunday. After we are going to wire the spot light for the back and weld the rest of the cab on.
My 72 thread
Old 01-10-2010, 03:33 AM   #187
onlyifihadachevy
Re: Got a new truck
Well we finished just now at 11:30 not really that late but seems to be because we were working halfway in the street. We made a crossmember for the black truck and got it on, had to grind a little so we grinded then stopped. We still have to pick up the trailor and weld tomorrow before we head out to go offroading.
Well what really killed us in time was we forgot a extension last week at a friends house. And we went to pick it up today and his sewage drain pipe broke and the city said that he couldn't stay at the house unless he fixed it. they were searching for the pipe and finally found it then my dad fixed it, we got there at 4 and left at 9-9:30. Got home and started working.
Hpefully pics of wheeling tomorrow, not of this truck but the other one, the one which led us too start this one.
My 72 thread
Old 01-10-2010, 10:32 PM   #188
onlyifihadachevy
Re: Got a new truck
well did really get any pics but went thru the bog 3 times and then bakced halfway into it and it died. Will crank but not spark so the trip was cut short.
My 72 thread
Old 01-14-2010, 12:08 PM   #189
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
does your truck sit low in the front or is it just the angle?
my jimmy build
Old 01-14-2010, 07:30 PM   #190
onlyifihadachevy
Re: Got a new truck
Its about an inch higher in the front. And the one of the back tires is on the curb, with the angle of the camera makes it look higher in the back. The angle in this pic makes the front look a lot higher in the front , but its only an inch maybe 2.
My 72 thread
Old 01-14-2010, 08:36 PM   #191
Wildstreak
"something witty here"
Wildstreak's Avatar
Re: Got a new truck
is the rear end off center or?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-14-2010, 09:26 PM   #192
onlyifihadachevy
Re: Got a new truck
Yea it is pushed up a little. I dont know why it maybe be the blocks?
My 72 thread
Old 01-14-2010, 09:30 PM   #193
onlyifihadachevy
Re: Got a new truck
But it looks like most are that way, some more noticable.
Well I thought since I found out when my shocks should come in I would post it. They should come on the 21st. Which If we get everything done we maybe able to wheel it on the 23rd. If not we will take the black truck and then the next weekend will we take it.
My 72 thread
Old 01-15-2010, 01:43 PM   #194
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
i had the same situation on my jimmy when i put the lift on. one side was to far forward for my liking so i just rotated the spring and it was good to go. seems like they'd rub more when there forward than reversed.
my jimmy build
Old 01-15-2010, 01:51 PM   #195
onlyifihadachevy
Re: Got a new truck
When they compress the way they are supposed to be the rear end gets pushed back it seems and at droop goes forward when I lifted it on a lift.
My 72 thread
Old 01-18-2010, 04:15 PM   #196
onlyifihadachevy
Re: Got a new truck
Well we got the steering box off yesterday, and we're going to put the other one today, and should have a seat mounted today.
My 72 thread
Old 01-20-2010, 02:38 AM   #197
onlyifihadachevy
Re: Got a new truck
Well we got the taillights done, the power steering done, seat mount halfway done, ordered winch line done today. It has been raining this week so the progress is a little slower than should be, but still looks like we are planned to go saturday.
My 72 thread
Old 01-21-2010, 03:08 AM   #198
onlyifihadachevy
Re: Got a new truck
Well doesn't look like we're taking this this weekend. We are just going to take the black truck; because it has better tires, and its been raining all week; and not supposed to stop till this weekend. Hopefully next weekend.
My 72 thread
Old 01-23-2010, 12:02 AM   #199
onlyifihadachevy
Re: Got a new truck
Just got this winch line for my othere truck and will have too get some for the winch on this, the hook is heavier than the rope.
My 72 thread
Old 01-28-2010, 07:21 PM   #200
onlyifihadachevy
Re: Got a new truck
Got my shocks finally they're filled to 300psi, and should get put on today, if the tabs get finshed. Cut them out yesterday but didn't fit right.
My 72 thread
