Old 07-29-2009, 08:59 AM   #176
menace121978
menace121978's Avatar
Re: Glock's new project: "Fred"
thanks guys much apprieciated!
after i found out how much a stock tach. cluster goes for i'm thinking to just use aftermarket gauges in the stock bezel. i really like the look of joe's and what others have done to the stock cluster w/ tach.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-29-2009, 10:57 AM   #177
menace121978
Bob, going through some of my book marks from last year and stumbled onto this... http://home.comcast.net/~airdeano/1965/index.htm lots of good info and tons of wiring diagrams since your thinking about doing your own harness. its a dbw also
"Dennis the Menace"
Old 07-29-2009, 11:09 AM   #178
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Oh SWEET!!! I've found a lot of wiring diagrams, but these are by far the cleanest I've seen! The ones I have look like a scan of a scan of a photograph.
Thanks man! Now I'm not-so-patiently waiting for my engine/trans to get here.......
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-29-2009, 11:15 AM   #179
menace121978
ANYTHING for you buddy!
i think thats about all the info, links, and bookmarks i have. everything else has already been posted or is common knowledge! spent most of yesterday reading and following links
"Dennis the Menace"
Old 07-29-2009, 11:53 AM   #180
glock35ipsc
I made PDF's out of the wire diagrams on that site:
File Type: pdf Engine Controls Connector End Views 1.pdf (172.6 KB, 455 views)
File Type: pdf Engine Controls Connector End Views 2.pdf (73.0 KB, 241 views)
File Type: pdf Engine Controls Connector End Views 3.pdf (149.9 KB, 244 views)
Bob
Old 07-29-2009, 05:47 PM   #181
glock35ipsc
I picked up an LS1 intake today. I know they don't make as much bottom end power as the stock truck intake, but man they sure do look better!
This will probably just go on the shelf for now. Later on down the road, I plan on swapping heads, a Vinci cam, and a Yank stall converter.
Bob
Old 07-29-2009, 05:53 PM   #182
menace121978
right on Bob! little by little!!
what year motor/trans did you end up getting?
"Dennis the Menace"
Old 07-29-2009, 06:58 PM   #183
glock35ipsc
Yep! I want to get it running and driving so I can work all the bugs out, then maybe when I go to paint it I'll swap all the go fast stuff on then.
The combo I got is out of a 2006 Silverado reg cab 2wd.
Bob
Old 07-29-2009, 07:11 PM   #184
menace121978
gotcha, does that mean you can just swap the dbw t/b onto the ls1 intake and visa versa?
"Dennis the Menace"
Old 07-29-2009, 07:47 PM   #185
glock35ipsc
For the most part. I may need to change the water pump and move the tensioner pulley since the TB will sit lower, but it's a pretty straight forward swap.
Bob
Old 07-29-2009, 11:13 PM   #186
glock35ipsc
Well, nothing that's really picture worthy , but I got the new power steering gear put on tonight. Got it bled, then set the tires on the ground. Nice and smooth, no noise either. The original one was leaking, and in the last week started to leak REAL bad.
So hopefully this will tighten up the steering too, and make it feel like I'm driving Fred, not the other way around!
Bob
Old 07-30-2009, 12:35 AM   #187
hessian18
Gen III Power
hessian18's Avatar
Wow this thread is full of info !!
Nice truck and great progress so far.
The more I read about these swaps the more I cant wait to start mine.
I need to start gathering my fuel system parts and look for a 12 bolt rear axle while im at it.
I will be watching this thread for sure
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 07-30-2009, 07:53 AM   #188
JohnC
JohnC's Avatar
Yeah Bob your thread and Dennis's may become sticky threads for LSX swaps!
JohnC is offline   Reply With Quote
Old 07-30-2009, 08:22 AM   #189
glock35ipsc
Thanks guys! The more info that gets out the better!
Bob
Old 07-30-2009, 02:14 PM   #190
glock35ipsc
UPS brought the filter/regulator and related fittings today. And just before I left for lunch, I got an email from Rancho Recyclers that the engine and transmission are shipping tomorrow.
Bob
Old 07-30-2009, 04:08 PM   #191
JohnC
JohnC's Avatar
WooHoo!!
Old 07-30-2009, 06:40 PM   #192
nlped
nlped's Avatar
Cool Taters!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-30-2009, 07:04 PM   #193
menace121978
sweet!! very excited for you Bob!
"Dennis the Menace"
Old 07-31-2009, 04:06 PM   #194
glock35ipsc
OK, I think I'm gonna slightly change the fuel system, nothing major. I am going to add a second filter/regulator to the system. So now, I will have a filter/regulator between each tank and the switching valve. Then from the switching valve, it will run straight to the motor.
I need to think this through first, but if this will work, I can return the 6-port valve that arrived today and exchange it for a 3-port valve. Since all the returned fuel will be returned before it ever reaches the valve, there is no need for return lines on the valve.
My reason for this change: The valve is rated at 65psi max. The working psi of the Vortec system is 58-60, but the EP381 pumps are rated up to 80 psi. So the potential to over pressurize the valve exists simply by turning on the ignition. So by having the filters before the valve, I think the valve life will be extended. I won't know for sure until I crawl under Fred, but I think this might be a little easier to plumb too.
Please take a look at these and let me know your thoughts:
Original/OEM way:
The new Fred way:
Bob
Old 07-31-2009, 07:18 PM   #195
nlped
nlped's Avatar
That appears as though that would be much easier to hook up and seems to make perfect sense. Your DBW motor is a returnless system anyway, correct?
Cheers,
Ed
Carter
Old 07-31-2009, 08:10 PM   #196
glock35ipsc
Cheers,
Ed
Thanks Ed, I was hoping someone would chime in and say that.... or say "nah, that'll never work!!"
Yeah, it is returnless. That and the DBW were the main reasons I looked for 2004 and newer.
Bob
Old 07-31-2009, 08:41 PM   #197
glock35ipsc
Here is this weekends project. I've had the Punch amp and Punch component speakers for probably 4 years now, maybe 5. I bought them, along with the Alpine I installed in Fred, and a 12" Punch sub in a sealed down-firing box for my old 2003 extended cab. This system sounded absolutely amazing in that truck. So I can't wait to hear it in Fred.
The only difference will be the sub. The 12" is waaaay too deep to fit behind the seat. So I found a nice 10" Kicker shallow mount in a sealed box today. I hope to have that by the end of next week when I take a road trip to Steamboat Springs. If not, I'll set the Punch sub in the passenger floor board for the trip.
BTW, the sub and box are for sale! http://67-72chevytrucks.com/vboard/c...ct=3475&cat=18
Bob
Old 07-31-2009, 09:59 PM   #198
glock35ipsc
The new sub that is one the way:
Bob
Old 07-31-2009, 10:19 PM   #199
menace121978
Original/OEM way:
The new Fred way:
Bob, i think this is a good idea... it would have much better filtering and it would be ALOT easier on that valve not having 80psi forced into it and then having to turn around and return the extra fuel back to the tank. at 80 psi the regulators/filters can do all the work maintaining 58psi and returning the extra. BUT.... i was just out looking at my lines from the sending units and theirs not a place to mount the extra filter on the driverside. from the sending unit on the d/s it routes straight across the cross member to the pass. side. you would have to either route the lines and filter towards the rear on the frame rail and then COME BACK the other way towards the front and go across the cross member. and visa-versa if you started towards the front. either way you'll have to back track the lines to hit the cross member to get to the other side. i took alot of time doing my fuel line the cleanest way possible and discarded the idea of running 1 inline filter per tank. the tanks are just in a bad position in relation to the cross member to do anything but run straight across. take a look under there and let me know if your seeing something different.
"Dennis the Menace"
Old 07-31-2009, 10:53 PM   #200
menace121978
just went out there again... anything IS possible Bob, but the cab mounts arent helping things out much either. can you measure the filter w/ the fittings attached for me? and i can place the measurement on the frame rail to see how far back you would have to go.
take a look at my frame pics and you can see how the sending unit lines point straight across to the hard line that runs to the other side. that might give you a better idea than having to crawl under FRED w/ the cab and bed on.
BTW, the system and new box looks sick!!
"Dennis the Menace"
