Old 05-01-2014, 10:48 AM   #176
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: Structures 65 Chevy C10
Nice work! Engine looks huge! LOL!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-01-2014, 10:31 PM   #177
Bomp
Bomp's Avatar
Really dig the motor you chose. Wish I could of gone that route for my build.
Sat and read from start to this point.
Great build!
Sub'd
Bomp is offline   Reply With Quote
Old 05-05-2014, 10:43 AM   #178
structures
structures's Avatar
Originally Posted by mcbassin View Post
Really making some good progress Robert. I learned it's best to do a full mock up of all your panels even if you're using GM metal. They vary so much it's crazy. I guess the gaps back in the day were a lot more loose than today's cars.
Thanks Mike! Plan on working the doors next.
Definitely larger than the straight 6! but still have lots of room.
Great build!
Sub'd
Appreciate it, still a lot of work to go.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 08-26-2014, 09:40 AM   #179
structures
structures's Avatar
Re: Griffin Radiator
Small update. A giant box showed up on my door last week.
I picked up a griffin radiator. I upgraded the fans because I believe I have the extra clearance. I'm thinking about painting it black with the eastwood radiator paint.
This radiator is a little bit wider than the mount brackets for the 283 v8 radiator.
Robert
1965 Chevy C10
Old 08-26-2014, 10:39 AM   #180
Strodder
Daring to be Different
Strodder's Avatar
NICE
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-26-2014, 10:51 AM   #181
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
NICE
Old 08-26-2014, 11:18 AM   #182
mcbassin
Still Learning
mcbassin's Avatar
that is one Sweet looking radiator and fan setup!
mcbassin is offline   Reply With Quote
Old 08-29-2014, 10:45 AM   #183
structures
structures's Avatar
Thanks guys!
Have a little work ahead of me. Comparing the two radiators.
The 283 radiator is:
22.5 tall x 25.5 wide x 2.75 thick
The griffin radiator is:
22 tall x 25.5 wide x 3.125 thick
With the fans the overall is 6.25 thick (to center of fans)
Robert
1965 Chevy C10
Old 09-15-2014, 05:05 PM   #184
structures
structures's Avatar
Re: Radiator Brackets
Working on radiator brackets.
Robert
1965 Chevy C10
Old 09-15-2014, 05:09 PM   #185
structures
structures's Avatar
More pics of the brackets. I powder coated the frame with semi gloss black years ago, but it seems like I have a lot of gloss black paint to use. Oh well. By the time she's on the road it'll probably all look the same dirty black...
Robert
1965 Chevy C10
Old 09-18-2014, 09:58 AM   #186
Strodder
Strodder's Avatar
Thanks for all the detailed information.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-18-2014, 11:26 AM   #187
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the radiator brackets.
Old 11-15-2014, 02:26 PM   #188
dracko
dracko's Avatar
Just came across this thread and I'm glad I did. Incredible work on the patch panels and braces. I'm patching up my fenders right now and about to start on the cab this winter. Your pics are gonna be a big help. Thanks and keep it up!
dracko is offline   Reply With Quote
Old 11-16-2014, 01:42 PM   #189
structures
structures's Avatar
thanks!
Robert
1965 Chevy C10
Old 11-17-2014, 09:32 PM   #190
flips72
flips72's Avatar
very nice
flips72 is offline   Reply With Quote
Old 12-01-2014, 12:45 AM   #191
structures
structures's Avatar
Originally Posted by flips72 View Post
very nice
thanks!
Took a minute to work in the garage over thanksgiving break. Finished up a patch panel on the inner rocker, cleaned up the gas tank mounts and put some por15 on the underside. Coated the underside of the upper roof panel with por15. Also spent some time sanding filler.
Robert
1965 Chevy C10
Old 05-03-2016, 01:04 PM   #192
zghorner
long time since you updated, have you been able to do any work since? I am curious what you decided to do with the gauges, I'm doing a turbo LS swap soon and looking for some ideas.
thanks.
zghorner is offline   Reply With Quote
Old 05-03-2016, 03:13 PM   #193
structures
structures's Avatar
Ohhh busted... well... Actually i've just been collecting parts... Other projects keep putting the poor girl on the back burner.
I want this truck to look all original on the outside. So the original gauge cluster is going to stay.
For the speedo I'm wanting to do the tail housing swap (like $500...) http://www.shiftworks.com/tailhousing.htm. You get a VSS and mechanical cable out that way. That seems to be the biggest hurdle. Temp and oil shouldn't be too difficult. I've seen some post on here where guys have tapped near the oil filter for the oil pressure line and I'm not real sure on the water temp gauge.
Robert
1965 Chevy C10
Old 05-03-2016, 06:32 PM   #194
jweb
jweb's Avatar
You can use the Dakota Digital ECD-100 and keep your stock speedo. That's what I did on my '51 and it works great. Cheaper than the tail housing swap and no more speedo cable through the firewall.
http://www.summitracing.com/parts/dak-ecd-100-1
You can use this for oil pressure
http://www.summitracing.com/parts/sum-g6326
For coolant temp I removed a plug from the rear of the passengers side head and tapped the hole for my stock temp sender
I will do my 64 Suburban the same way if I can ever get started on it.
jweb is offline   Reply With Quote
