Old 02-01-2010, 04:14 PM   #1
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
This is my fuel line set up. I decided to go with a single line filter regulator. I used Jegs braided 6 AN female 2ft. ready made hose. 3/8 and 5/16 tubing with Swagelock compression fittings 2- 3/8 to 6AN males and 2- 5/16 to 6 AN males. At the regulator I used 1- 3/8 and 1- 5/16 Swagelock compresion to compresion fittings and a GM O-ring X 6AN.
smokedat is offline   Reply With Quote
Old 02-15-2010, 02:13 PM   #2
smokedat
smokedat's Avatar
No progress on my truck since I been busy finishing off my uncles truck. Cab fire wall and chassi have been painted. We used PPG Atomic Orange (code 83), and PPG 2021 clear. A high gloss on the chassi. We were goin to drop in an LS1 this Sunday but the paint was still sticky, will try again this week end.
Old 02-15-2010, 02:15 PM   #3
smokedat
smokedat's Avatar
few more
Old 02-15-2010, 02:22 PM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking good. That color looks cool.
--Josh
Old 02-15-2010, 02:51 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I love that color! This is what I was going to paint my 68. I even had a little design figured out that I was going to have airbrushed on a lower corner of the tailgate...... an orange that was split open at the top, with a mushroom cloud coming out of it.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 02-16-2010, 01:46 PM   #6
smokedat
smokedat's Avatar
so wut color did you end up painting youre 68? I like that blown up orange idea
Old 02-15-2010, 04:57 PM   #7
3r!c84
Badass
3r!c84's Avatar
what paint did you use on the frame?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-16-2010, 04:28 PM   #8
bigarmzz
bigarmzz's Avatar
wow
i just now came across this thread.....wow
1986 K10 swb 6" lift 37" tires
bigarmzz is offline   Reply With Quote
Old 02-16-2010, 06:07 PM   #9
smokedat
smokedat's Avatar
Its Ellis Hy-Lux one stage,with wet look hardner added. It sprays really thick eaven when reduced a bit extra, so it will go along ways ended up using about 1/3 of 1 gallon. Sorry for the low- res picture it was taken with my phone.
Old 07-28-2010, 07:01 PM   #10
BlueMagicSS
Nice build!!! I can't wait to get the LS1 into my K5. The Jetstream blue is an Awesome color and will look great on your Cheyenne!!! I'm kinda partial to that color since my Camaro SS is close to the same color
BlueMagicSS is offline   Reply With Quote
Old 07-28-2010, 11:29 PM   #11
mcbassin
Still Learning
mcbassin's Avatar
Nice score on the buckets! I would love to find a set like that.
mcbassin is offline   Reply With Quote
Old 02-17-2010, 05:25 PM   #12
silvereagle07
silvereagle07's Avatar
smokedat, the engine looks awesome but the cab and frame are even better. NICCCCCE!
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-17-2010, 06:03 PM   #13
smokedat
smokedat's Avatar
Thanks for the compliments, will also color match the rally wheels.
Old 02-17-2010, 06:05 PM   #14
smokedat
smokedat's Avatar
Check out my new avatar
Old 03-09-2010, 11:03 PM   #15
smokedat
smokedat's Avatar
Update, I started to gather some of the paint supplys I got the clear 2 gallons of Dupont Imron, yes the stuff that got outlawed in Cali. Game plan I will start by removing the front clip to get to the old 350 pulling it out, strip interior, remove cab and bed, clean the frame, paint the frame, then work on the exterior body bringing it down to bare metal, tubbing the rear drop in a Ford 9", install 4 link, paint exterior, then finally drop the LS, wire the new set up, run new wet lines, list goes on and on...This swap has been past due as I was suppose to move on Feb, but escrow got delayed, so i will start the swap after i move hopefully by the end of this month.
Old 03-10-2010, 02:17 PM   #16
justpball
justpball's Avatar
I had a supra back in the day that i painted that color...very nice color!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-21-2010, 08:36 PM   #17
smokedat
smokedat's Avatar
This is my body and paint material,
Old 03-21-2010, 08:37 PM   #18
smokedat
smokedat's Avatar
Dupont Imron 500S Clear
Old 03-21-2010, 08:39 PM   #19
smokedat
smokedat's Avatar
Old 03-21-2010, 08:41 PM   #20
smokedat
smokedat's Avatar
Old 03-21-2010, 08:42 PM   #21
smokedat
smokedat's Avatar
Old 03-21-2010, 08:45 PM   #22
smokedat
smokedat's Avatar
I will be fabricating custom aluminum accesories for interior
Old 03-21-2010, 08:46 PM   #23
smokedat
smokedat's Avatar
sterring wheel and honker
Old 03-21-2010, 08:48 PM   #24
smokedat
smokedat's Avatar
Will fabricate a dash panel for my gauges and the trim piece for the dash
Old 03-21-2010, 08:50 PM   #25
smokedat
smokedat's Avatar
Pedals that I fabricated still need to be cut drilled and pilished
73c10, c10, cheyenne, ls1, swap
