05-03-2010, 07:25 PM | #176 |
Junior Member
Re: Show your motor...
This is the only clean one I own.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
07-02-2010, 12:00 AM | #177 |
MY NEWEST.
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS Last edited by po_bird; 07-02-2010 at 12:01 AM. |
07-02-2010, 12:23 AM | #178 |
Grandpa in the rustmobile...
how do you guys mask off everything so nice?!?!?
And whats the process for painting after you get it back from the machine shop? primer? if yes what kind?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-02-2010, 01:52 AM | #179 |
Chevy Lover Till The End.
I just did a cam swap and dressed my lil rat up a bit
Now
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 Last edited by Camaro_nut2001; 07-02-2010 at 01:59 AM. Reason: Pictures didnt post |
07-02-2010, 01:58 AM | #180 |
Before
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 Last edited by Camaro_nut2001; 07-02-2010 at 02:01 AM. Reason: Misspelled badly |
07-02-2010, 02:57 AM | #181 |
350 Original
07-02-2010, 06:17 AM | #182 |
before pics, 67/327 and 72/402. at my speed these may be the after pics too
lots of inspiring pics on here though, thanks for sharing. kent
eat,work,spend,sleep,repeat. Last edited by prairewolf; 07-02-2010 at 06:18 AM. Reason: spelling |
07-02-2010, 08:23 AM | #183 |
Redefining LowBudget
The monster of stock BB's..410 hp and 435 torque....I'm planning On shootiing it with another 100 so its waiting on the floor for some ching to buy a DS and exhaust...I added a set of yellow 8mm wires..the pic doesn't do it justice...wrinkle black and silver wheel paint...I was going for the harley engine look
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
07-02-2010, 08:49 AM | #184 |
My 68 C20 with 5.3, just ran 1st time last night.
07-02-2010, 02:37 PM | #185 |
Jason
Here's mine.
07-03-2010, 12:08 PM | #186 |
Here's mine freshly painted,
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
07-03-2010, 05:32 PM | #187 |
406 Powered
Got my 406 running sweet figured i would post a pic. Still have to go down a size on the carb spacer and put my taller air cleaner back on. Still got alot of goodies to put on. Just glad shes done....
70 GMC 68 c10 2002 silverado 72 4x4 |
07-03-2010, 05:46 PM | #188 |
Just working out the last few bugs. Runs good though, finally.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-03-2010, 05:53 PM | #189 |
before & after:
07-03-2010, 06:25 PM | #190 |
Chevy 350!!!!!!!!!
07-03-2010, 07:57 PM | #191 |
I use duplicolor engine paint from kragens. I spray 2 coats primer, 2 coats color, and 2 coats clear.
07-03-2010, 08:12 PM | #192 |
Sofa King Crazy!!
Update. 66 Vette block 327, 70 LT1 Bowtie/Snowflake high rise intake, Edel 600 carb, HEI, still needs a few things but she lives!!!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
07-03-2010, 08:12 PM | #193 |
thanks newtz! I used reg. primer (non high temp) and ended up wiping rubbing scraping it off with brake cleaner lauqer thinner.
Then sprayed a few coats (mayve been thick i suck at painting anything). Its dried a day or so now. I can kidna scape at it and it comes off!? Thanks Oh here it is
07-03-2010, 09:53 PM | #194 |
one more
07-03-2010, 11:00 PM | #195 |
My little 350 I just finished up.
07-04-2010, 02:36 AM | #196 |
Location: Aurora,Il ..born,raised and still live in the same house
thanks booya!
I think most of us would be satisfied with a nice/solid/dependable small block like that,i know i would. I'm doing my first small block rebuild this summer. Those 406's and 572s are nice but i wouldn't have the slightest idea were to start. LOL Lot's of serious engine builders on this thread/site!
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
07-04-2010, 08:49 AM | #197 |
The Alien, you got an air cleaner hooked up yet. Been thinking about using the stock intake tubing myself. I can't get the engine driven fan on with the rad hose where its at, and can't use the stock 5.3 upper rad hose with the intake tube i have on now. Also, how'd you go to the larger hose end on the upper radiator on drivers side. You'll really like how the truck runs with the Vortec in it. I know I do.
07-04-2010, 09:56 AM | #198 |
The little 350 in my Blazer.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
07-04-2010, 10:50 AM | #199 | |
I had a local radiator shop change the inlet and outlet to the correct size and added a steam port so I could use the factory radiator hoses. My clutch fan hits the shroud if I put even the slightest pressure on it. I may have a solution but don't want to say anything until I try it out. I had a troublesome lean bank 1 code that nobody could diagnose. Most thought intake leak so we smoked the motor. Even with about 10 lbs there was no leak. Another tuner suggested an O2 sensor and there were some eratic O2 readings so I replaced it and still lean bank 1 **&^^%$$##%^&!! The local tuner said cylinders 1 & 3 were not firing. We were getting spark and an injector pulse. He was thinking an obstruction in the intake (maybe a rag or tape left on?). I replaced 2 of the injectors at the 1 & 3 location and this is what they looked like They are pretty nasty inside also. I am going to replace the other 6 with the rest of the ones I got on ebay that look new and only have about 100 miles on them. Even with the two bad cylinders (and the other 6 can't be at 100%) it ran better than it ever has. Yesterday I drove it for about 50-60 miles after replacing those 2 injectors and it does drive nice. Plenty of power, sounds good, cruises at 80 at about 2500 RPMs. If you have any other questions might want to PM after posting as I don't always go back to some threads and might miss it.
07-05-2010, 09:28 PM | #200 |
Check out my Photos http://67-72chevytrucks.com/gallery/...ry.php?cat=769 L.L. N.M. 63 chevy c-10 67 chevy c-10 71 chevy Blazer 4x4 |
