Old 03-11-2010, 11:51 PM   #176
menace121978
menace121978's Avatar
Re: The 6.0 Silverado Build
its about $360. they use the donor motors harness. for what its worth... i'm going to give Nelson Performance a call. i've talked to Hannah @ wait4me once and she was supposed to get back to me on my extra connectors for the 4l80e and shipping instructions and she never did. ive tried calling at least 5 times and left 3 messages. says mailbox full or something like that. i guess i'll take my business else where...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 03-12-2010, 10:15 AM   #177
JohnC
JohnC's Avatar
Originally Posted by mcbassin View Post
How much are you guys spending at Wait 4 me for the harness? Do they actually use the orignal wires or add all new ones? I would think it would cost more to run wires long enough to go inside the cab. What is the "F" body harness you are laking about? thanks
The "F-Body" is the Camaro, Firebird, and Trans-Am platform.
JohnC is offline   Reply With Quote
Old 03-12-2010, 12:00 PM   #178
fpjr0
fpjr0's Avatar
Originally Posted by menace121978 View Post
its about $360. they use the donor motors harness. for what its worth... i'm going to give Nelson Performance a call....
from what I heard, nelson perf.. are good just a little pricey, but good shop...
ONCE YOU GO LS, YOU NEVER WANT LESS!!
fpjr0 is offline   Reply With Quote
Old 03-14-2010, 09:31 PM   #179
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
OK, progress at last. I finally found time to get my but in the garage and get some work done. Having a friend come over to help was a big determining factor too. We took the harness apart as much as possible and removed all the wires that were just cut back and taped up. It really helped to thin out the harness. I was able to mack up and manipulate the harness enough that it runs from the firewall behind the intake and down both sides with barely being seen. I was also able to mount the ECU behind the dash on the passengers side just above the A/C box so it's totally out of the elements as well. I still need to wrap the harness with wire loom and heat shielding in some spots and then I can mount it permanantly at last. I can almost hear it running now...
--Josh
Old 03-14-2010, 09:41 PM   #180
VA72C10
VA72C10
VA72C10's Avatar
cool man! Looks good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-14-2010, 10:27 PM   #181
menace121978
damn! nice job Josh! sending p.m.
"Dennis the Menace"
Old 03-14-2010, 10:44 PM   #182
STOCKISH
STOCKISH's Avatar
Returned buddy! Thanks for the compliments.
--Josh
Old 03-15-2010, 11:33 AM   #183
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Looking man. How is the quality of the workmanship with Wait4Me? Would you use them again?
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 03-15-2010, 02:36 PM   #184
STOCKISH
STOCKISH's Avatar
Maybe my standards are too high, but I think it sucks and would never use them again. I opened the harness and found that they didnt remove the wires to make it stand alone but just cut them and taped them in the harness. Therefore, the harness was just as thick when I got it back as it was when I sent it. They also used hot glue to hold the bundles of wire together. Not sure why they did that? but it is stiff as a board now. I got it all mounted but am not totally happy with the look of everything so I may still just take it off and chuck it in the dumpster. We'll see.
--Josh
Old 03-15-2010, 03:17 PM   #185
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Hot glue? Sounds like he has his wife making them. LOL!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-16-2010, 01:04 PM   #186
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
She does.
If you are going to toss it, send it to me! Mine was exactly as I expected... a $285 rework of a factory harness to make it a stand-alone operation. Just remember, Jesse's rework is just like any other at a base price.... to remove the unneeded connectors, tie all the power and grounds together, but not to thin it out or make it a custom fit jobber.
But seriously, if you are going to get rid of it..... I will have another swap coming up.
*** Oops, forgot to add.... there is no hot glue in mine. That's kinda weird.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 03-16-2010, 02:13 PM   #187
STOCKISH
STOCKISH's Avatar
It's currently on the engine I'm just lenghtening wires for the ECT sensor so I can make it fit like I want it to. If I had known going in it wasn't going to be thinner( he said it would) I would be OK with the whole thing. Either way, they did a good job for a good price so as long as it runs I'm OK. Maybe just a misunderstanding on my behalf? Who knows, but I was able to move things around enough and hide stuff enough to make me so In the end everyone is happy. Glad to see you around here again Bob. Work been crazy again?
--Josh
Old 03-16-2010, 08:12 PM   #188
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Hey Josh I just noticed you live in Wake Forest. My son lives and works in Winston-Salem and goes to Wake Forest at night to get his MBA. But anyway I was going to use W4M to do my harness and re-flash the ecm, not really looking to clean up the engine bay just want it to look like it came with this engine. Looking good though.
1995 Mustang GT 347
Old 03-16-2010, 08:36 PM   #189
STOCKISH
STOCKISH's Avatar
If you are not wanting a custom looking harness, Wait4me is the way to go. Economical and pretty fast.
--Josh
Old 03-18-2010, 11:48 AM   #190
SatisTraction
i just read this whole topic and wanted to say nice build!!
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 03-18-2010, 12:02 PM   #191
Jonboy
Slots go on anything!
Looks like you are making great progress. How far off is it from firing up?
1974 Jimmy- 5.3/4L80e/NP241
Old 03-18-2010, 05:56 PM   #192
STOCKISH
STOCKISH's Avatar
HArd to say at this point. I work on cars for a living and it's been so busy lately I have a hard time finding time to get back to it. Hopefully before summer so I can cruise the wheels off this thing.
--Josh
Old 03-19-2010, 12:31 AM   #193
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Josh, been a little while since I checked in with everyone else's builds. Looking good as usual. Keep at it man, every little bit gets you closer to running.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-20-2010, 11:44 PM   #194
STOCKISH
STOCKISH's Avatar
OK fellas, getting close now! I managed to find some time tonight after the little one went down and Nicole was doing report cards for her class so I fell into the garage to have some fun. I managed to get the core support, grill, lights, radiator, fan, fan shroud, battery and tray and inner fenders all re-mounted. Also ran the battery cables and a couple other things so I was at least able to hear her turn over whith a twist of the switch. Just need to wrap my harness once my wire wrap shows up and wire in a couple things and she'll be ready to go. Holy cow I cant wait now. Will still need to get the driveshaft fixed but I'll just be glad to hear it run. Heck yeah!!!
--Josh
Old 03-21-2010, 12:15 AM   #195
VA72C10
VA72C10
VA72C10's Avatar
Very cool! Looking forward to a video
Old 03-21-2010, 07:55 AM   #196
menace121978
wow! Nice job Josh! i bet its nice to see her all back together
"Dennis the Menace"
Old 03-21-2010, 12:05 PM   #197
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Great progress. I love the stance of this truck. I want to keep my truck stock looking until I see a truck like yours. I'm sooo confused! Can't wait to see a first start video! Great work man
1995 Mustang GT 347
Old 03-21-2010, 12:15 PM   #198
jason65
Registerd User
jason65's Avatar
That thing looks awsome!
jason65 is offline   Reply With Quote
Old 03-21-2010, 09:21 PM   #199
STOCKISH
STOCKISH's Avatar
Thanks guys. I was hoping for some progress tonight too but I ran into a couple issues. My manifolds just arent going to work at all so it looks like I just hit an expensive hurdle. Anybody have some S&P headers for a LS that they accidentally ordered and need to sell cheap? Was also going to try to get my power steering lines hooked up but couldnt find my 1" wrench anywhere. Well, maybe tomorrow.
--Josh
Old 03-21-2010, 09:43 PM   #200
bigdnew
Never Satisfied
bigdnew's Avatar
I am doing the same swap, what is wrong with your exhaust manifolds.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
