Old 11-16-2010, 10:05 AM   #176
watahyahknow
watahyahknow's Avatar
Re: late build thread...LOL
he made the holes in the sheetmetal kikke , you probably can drill them in the mdf and then put them against the door and drill trough
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-16-2010, 10:12 AM   #177
kikkegek
kikkegek's Avatar
oke, but still I dont understand. If you want to mount something like this. You's expect mounting holes to be visible from the front. Otherwise he must have used a different mounting syste. If so, I would like to know what. Because it loks great without the mounting holes.
Hope this make my question clear.
kikkegek is offline   Reply With Quote
Old 11-16-2010, 02:35 PM   #178
justpball
justpball's Avatar
Drill holes in the door and reach in put nuts on the back side
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 11-16-2010, 02:52 PM   #179
kikkegek
kikkegek's Avatar
owwwwwwwwwwwwww..................ok. thanks man!
Old 11-17-2010, 04:33 AM   #180
kikkegek
kikkegek's Avatar
he man! I really love your midconsole and the way it curves.
Does your 91 model also have the floor heater in the middle under the dash? if so, what did you do to it when placing/building the mid console?
Old 11-17-2010, 06:45 AM   #181
justpball
justpball's Avatar
yea it does, if you look close right below the steering wheel in the pic you can see a little notch that lets the heat out...it is about 6in long and 3/4 in high
87 Crew SWB
Build for the crew
90 burb 2wd
Old 11-17-2010, 07:44 AM   #182
kikkegek
kikkegek's Avatar
alright! thanks man!
That was what I was planning on doing myself, if I start in this idea.
I would really like very much to build something like this, but I have the 4WD-selector in the way. But since I almost never operate this handle, I am considering building a mid-console over it, with a hatch that moves the display away, so the handle can be accessed.
Old 12-08-2010, 12:47 AM   #183
Devillusion
Devillusion's Avatar
Loving what your doing with it, giving me some crazy ideas for the crew cab/short box project. Keep up the great work. Can't believe I missed this till now...
Any idea what your WMS to WMS is front and rear on this thing? I want to compare with my 1 ton single wheel measurements to see if I can manage a 20x12 in the rear. And skinnys up front.
thanks!!!
Devillusion is offline   Reply With Quote
Old 12-09-2010, 05:07 PM   #184
LivNLo94
LivNLo94's Avatar
thanks for all the info on your crewcab. i really like the stance so i ordered a djm 5/7 lowering kit, eagle alloy 225's in 20x8.5 255/35r20 and 20x10 295/30r20,
my wheels should arrive today at discount tire. what size rear tire are you runnng on your suburban?
LivNLo94 is offline   Reply With Quote
Old 12-10-2010, 09:43 PM   #185
justpball
justpball's Avatar
Devillusion what is WMS? Burb has 285/30/20 all the way around...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 12-10-2010, 09:44 PM   #186
justpball
justpball's Avatar
that sounds cool, be sure and let us know and take lots of pics!!!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 12-10-2010, 09:57 PM   #187
Devillusion
Sorry, Wheel Mating Surface to Wheel Mating surface. This is the flat surface that the back of your wheel mates to (surface of drum or rotor).
I know the two versions of the 14 bolt full floaters (3/4 and 1 tons) were either one of two options...67.5 on normal dually and single wheel versions, and 63 on the cab and chassis duallys. Just not sure what the half tons measure.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Old 12-10-2010, 10:00 PM   #188
justpball
justpball's Avatar
i can check for ya bro!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 12-10-2010, 11:28 PM   #189
Devillusion
Thank you very much.....I appreciate it ALOT!
I know this will cause you some work, so I truly do appreciate it. Unless someone out there has some information to save him some labour?
Again...TY!!!
1970 Chevelle
Old 12-10-2010, 11:39 PM   #190
watahyahknow
theres a little more to that theres allso a van axle and a chassis cab axle that are slightly different if i remember correctly
the two sizes on the axelhousings themselves and two types of hubs the combinations give the 4 trackwiths
you do need to change the mounting for the backingplates of the brakes if you mix and match them
http://www.pirate4x4.com/tech/billav...ble/index.html has a LOT of info on the subject
Old 12-11-2010, 12:45 AM   #191
Devillusion
I thought that too, but I had a few people "set me straight" that there was only the two, I always thought there were three as well. I thought there was one that the front tire of the dually lined up with the outer rear, one that lined up with the center of the rear duallys (mine), and one that the front lined up with the inner (typical dually with box/fenders).
Guess I should be starting a new thread...this one is starting to hijack a little to much....sorry.
Either way I would appreciate the half ton measurements...
1970 Chevelle
Old 12-11-2010, 12:46 AM   #192
qu1cks1lver56
qu1cks1lver56's Avatar
Think I passed this beast on the I-10 in Pensacola a little while ago, more like a month or so ago now, I was going west you were going east. Was it you? lol
qu1cks1lver56 is offline   Reply With Quote
Old 12-11-2010, 09:05 AM   #193
justpball
justpball's Avatar
Yea i was headed to panama city for a car show, I live just across the line in bama.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 12-13-2010, 12:42 PM   #194
kev2809
low n' slo
kev2809's Avatar
man how did i miss this one! sick burban man..do you have a pn for that knuckle in your steering shaft? i have an extra crossmember that im thinking of getting chopped but i was wondering how much the knuckle was too. thanks!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-17-2010, 07:50 AM   #195
justpball
justpball's Avatar
I got it out of a van in the junk yard, most vans have them, and a lot of the newer trucks do to
87 Crew SWB
Build for the crew
90 burb 2wd
Old 12-17-2010, 11:50 AM   #196
qu1cks1lver56
Cool man, I'll have to catch you next time you're out this way to check this thing out
Old 12-19-2010, 02:48 PM   #197
cable666guy
cable666guy's Avatar
Cool burb, man!! The attn to detail is first rate...the lace on the side stripe is really cool, I've seen that before and I know it's not easy...Keep it up!!
cable666guy is offline   Reply With Quote
Old 12-31-2010, 09:23 AM   #198
justpball
justpball's Avatar
The lace is skulls...LOL
here are my new shoes!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 12-31-2010, 10:12 AM   #199
texasfunk
texasfunk's Avatar
Lookin good!! Love the 225's!!!! 20x10 on all four?
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 12-31-2010, 11:55 AM   #200
lolife99
67-72 parts collector,…
lolife99's Avatar
Wheels look great!
What size tires?
Keith
Convert to disc brakes.
