Old 10-29-2011, 09:52 PM   #176
Kim57
Kim57's Avatar
Re: Project 59 Apache "1st Build"
Fat Mike
The bar that holds my drive shaft loop connects the outside of the left and right frame rails to each other, does that make sense to you?. You may be able to make one for your frame to add some strength.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-29-2011, 10:12 PM   #177
Fat Mike
Fat Mike's Avatar
Definetly makes sense. I am going to run a piece of round tube through both pieces of frame that will be part of the frame cage that i am going to build. It will be very similiar to the one that cajundragger built on his 56.
Fat Mike is offline   Reply With Quote
Old 11-03-2011, 07:12 PM   #178
Fat Mike
Fat Mike's Avatar
Started working on meshing the two frames together. Decided I would cut the inside frame at an angle so the they would tie in better.
Old 11-03-2011, 07:28 PM   #179
Fat Mike
Fat Mike's Avatar
Here is the way it is going to look. Still need to finish boxing the frame to the end and match the outside angle to the inside of the frame.
Also I will be getting the frame completely level before welding everything up and making sure it is completely square. Still have alot of work to do before that happens thou.
Old 11-03-2011, 07:44 PM   #180
ratty 46
Gett'n there ....
R46
ratty 46 is offline   Reply With Quote
Old 11-03-2011, 07:54 PM   #181
OrrieG
OrrieG's Avatar
I would have kept more of the original frame so there was more overlap. I assume you are going to add an angled piece on the outside angled back from the original to the new? That point is right at the cab/bed line and center of the frame front to back where the maximum lateral and horizontal stress will be.
OrrieG is offline   Reply With Quote
Old 11-03-2011, 10:14 PM   #182
Fat Mike
Fat Mike's Avatar
There will be gussets holding everything together and a very complex frame cage that will add alot of strength. There will be an angled piece on the outside that will mimic the inside. One of the points where the cage will tie into the frame will also be in that area.
Old 11-04-2011, 12:08 AM   #183
Kim57
Kim57's Avatar
looking good Mike.
Kim
My build thread
Old 11-04-2011, 09:47 AM   #184
jjjmm56
jjjmm56's Avatar
Looks good mike, if you want to make it stronger could you sleeve it. Run a length of frame tubing inside your stock frame and alongside your new frame and weld it, then plate it top and bottom.
jjjmm56 is offline   Reply With Quote
Old 11-04-2011, 10:11 AM   #185
Fat Mike
Fat Mike's Avatar
I plan on sleeving the inside of the existing frame and will definetly plate both top and bottom. Thanks for the advice.
Old 11-04-2011, 02:44 PM   #186
OrrieG
OrrieG's Avatar
I should have held off on my comment for a while. You have done a good job of thinking it out.
Old 11-04-2011, 04:14 PM   #187
Fat Mike
Fat Mike's Avatar
Thank you, that means alot because you really have a great build.
Old 01-12-2012, 03:15 PM   #188
Fat Mike
Fat Mike's Avatar
Haven't really had any time to work on my truck. Go to work when its dark, come home when its dark. Anyway got my shop all cleaned up so I can do alittle body work in my shop at night now.
Old 01-12-2012, 03:36 PM   #189
Fat Mike
Fat Mike's Avatar
Starting to shave the drip rail again on the new cab. Made sure to clean the weld better than before, and took my time ALOT more! Welded a few spots, then knocked the down with a grinder wheel. Finally sanded with a flap wheel. Right when I was getting very comfortable I ran out of gas.
Old 01-12-2012, 03:50 PM   #190
Kim57
Kim57's Avatar
Nice job Mike. I like the shaved drip rails.
Kim
My build thread
Old 01-20-2012, 01:22 PM   #191
Fat Mike
Fat Mike's Avatar
Got alittle work done on the truck last night. Finished shaving the drip rails around the doors and started the rear portion. The rear portion has alittle bit of rust so I am going to cut out three sections. Otherwise came out descent.
Old 01-20-2012, 05:51 PM   #192
Kim57
Kim57's Avatar
looking good Mike.
Kim
My build thread
Old 01-20-2012, 06:02 PM   #193
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Good job Mike. You doing something I don't want to think about doing.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-23-2012, 12:59 PM   #194
Fat Mike
Fat Mike's Avatar
Thanks guys!! Cut three patch panels and finally got them welded in.
Old 01-25-2012, 12:42 PM   #195
Fat Mike
Fat Mike's Avatar
Redid one of the patch panels that I had done. Also found a little of rust in the panel that I had repaired so I will repair that next.
Old 01-25-2012, 12:51 PM   #196
Fat Mike
Fat Mike's Avatar
Got tired of looking at the dash I had picked up awhile back and felt it was finally time to try to install it. I cut the old dash out leaving the bracket with the windshield wipers, defroster, and removed the bracket that holds the steering column. Next trimmed the old dash and installed the new dash just under it for a stencil. Well it went well until I got to the part where the bumps in the dash were because I did not save enough of the new dash to fully extend to the old.
I fill really stupid for making this mistake because I usually ask 50,000 questions and still messed up!!
Old 01-25-2012, 01:03 PM   #197
yukon ratrod
yukon ratrod's Avatar
Attachment 861796
Attachment 861797
Attachment 861798
Attachment 861799
Attachment 861800
Mike! how goes the projects? i havent been on here much, working to much, but see your making headway. looks good bud. glad to see your still moving forward. sold my 57 and havent had time to play with the 72 and dont see it happening for awhile.
yukon ratrod is offline   Reply With Quote
Old 01-25-2012, 01:55 PM   #198
_Ogre
_Ogre's Avatar
looks real nice fatmike, minimal trimming to get that dash in there.
is this a back to the future build?
all pics are dated 2071...
shop air compressor timer
Old 01-25-2012, 02:48 PM   #199
Fat Mike
Fat Mike's Avatar
I don't know why it does that? I wish it was a back to the future build because I would fix all the dumba$$ things that I have done and you guys wouldn't know about them.
Old 01-25-2012, 03:32 PM   #200
99 to Life
99 to Life's Avatar
dash looks great.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
