#176 |
Re: Be Gentle. . . I'm an Amateur.
Dude, leave the vent! It's great cruising around with it! Move the drain through the inside and out so it doesn't show and keep the vent!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#177 |
good thread Im going wit the el camino chassis its the closest I feel that will work keep up the good work..
#178 |
Be sure and start a build with lots of pics. Others will definitely want to see it.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
#179 |
#180 |
Hood is Back!
I got my hood back a couple days ago. The seam is invisible.
![]() I'm going to test fit the bed then drop if off for paint later this week.
#181 |
![]() Join Date: Mar 2011
Looks slick, is that a dark forest green.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#182 |
Looks great Groyd! Keep at it, you"ll be smiling ear to ear when you take her out for the first drive.
I Saw Elvis at 1000 Feet - John Force |
#183 |
Dark green with a gold/silver flake in it.
#184 |
It looks great.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#185 | |
![]() i used trex plastic deck from home depot, should last a while ![]() it's only available in 5.25'' width so plan accoringly. i had to add 1 strip and ''board'', it cuts easy too ![]() ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#186 |
I've seen that at Lowe's and wondered if anyone had tried that. Looks great. I may just get a piece of diamond plate steel for the bed floor.
#187 |
Thanks. I'm glad to see you're tearing back into yours. The winter took it out of me. I'd like to be done by the end of the summer. Ha, we'll see.
#188 |
Me too, it is hard to stay motivated. I may have an update on a complete drivetrain in the next month or so. I am just waiting on decisions to be made. I am not sure when mine will be driveable.
#189 |
Still Learning
Your paint looks great!
Posted via Mobile Device |
#190 |
I love that color,
cannot wait to see the whole truck in that color!!! keep up the good work Brian
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
#191 | |
I welded in the cap covers that Mar-K gave me with the bed sides. I also welded in the side rails to bolt the floor to. ![]() ![]()
#192 | |
Re: Amateur Build in Progress.
#193 |
[QUOTE=Groyd;4149785]I finally got around to mounting up the Sanderson Headers that my cousin had originally bought for the engine. Funny thing, they don't need gaskets. I had already bought some and had to take them back and get some Permatex silcone gasket sealant.
[IMG] ![]() It took me forever to hillbilly the transmission bellhousing up to the engine. I ended up having to call a friend over. [IMG] ![]() It also took about two hours to mount the engine. It seems like nothing I do is very fast. [IMG] ![]() I'm not real wild about using a big washer/spacer between my motor mounts. I think my dad is going to come over and try to help me think of a better option.[/ One more Q.. what headers are those? |
#194 |
One more Q.. what headers are those?[/QUOTE]
Sanderson Headers
#195 |
The mounts from the motor are LS plates to SBC mounts (I believe they were Trans Dapt brand). Then, like you mentioned, the S10 Frame to SBC mounts from EZ.
#196 |
Thank you very much for the reply. Guess they are a set from jegs probable. Found them there huggers hooker, ls1 headers. Hope they work dont really want to run the v8 5.3 s-10 headers.
#197 | |
Here is a link to the headers. http://www.sandersonheaders.com/Chev...ersion-headers
#198 |
Found the motor mounts at napa. Cross referenced the part number with Oriellys and got them half price like6$ each. Then ordered the adapter plates from jegs for 39.99 shipped.. So all in all not to bad. The reason the kit is made that way is so that you can have more adjustment with the motor as needed and just shim the bolt accordingly to were your need the motor to set...
Thank you very much for the info. I found these headers at jegs today. Think i will order them. They should work. http://www.jegs.com/i/Hooker-Headers...oductId=759625 |
#199 |
I don't want to use the original space for the radio. Should I weld it in or get a delete plate?
I saw someone who had hinges on their delete plate with their air ride gauges behind it. It was somewhere on this site, but I can't seem to find it. Any other good ideas?
#200 |
I hinged my speaker grill and hid everything behind it. The AC control knobs are going where the ashtray opening is. Its on my build thread how i did it, check it out.
