Old 05-31-2011, 08:12 PM   #176
oldman3
oldman3's Avatar
Re: Jimbo's 67 Long bed step side build
That's todays post.
oldman3 is offline   Reply With Quote
Old 06-01-2011, 06:53 PM   #177
oldman3
oldman3's Avatar
Will start todays post working on the doors.
Pic 1 Added metal at top for better gap, before removing door.
Pic 2 Pass. door working on body work.
Pic 3 Both doors in epoxy primer.
Pic 4 Both doors in regular primer.
Pic 5 Back side of doors.
Old 06-01-2011, 06:56 PM   #178
oldman3
oldman3's Avatar
Pic 1 Here I've gone back to finish welding on top of cab.
Pic 2 Starting to do some final sanding work on the top.
Pic 3 More of the same.
Old 06-01-2011, 06:59 PM   #179
oldman3
oldman3's Avatar
Pic 1 Working on running boards, filling spots, etc.
Pic 2 I had welded in studs, to replace holes for carriage bolts. Adding filler to smooth off, etc.
Old 06-01-2011, 07:00 PM   #180
oldman3
oldman3's Avatar
Here I've filled in the holes for Bow Tie on the grill.
Old 06-01-2011, 07:03 PM   #181
oldman3
oldman3's Avatar
Pic 1 Cab up on firewall to work on bottom of cab.
Pic 2 Another view, have to get this tar off and rust.
Pic 3 All coated with encapsulator paint.
Old 06-01-2011, 07:05 PM   #182
oldman3
oldman3's Avatar
Pic 1 Running boards in epoxy primer.
Pic 2 Cowl and grill in epoxy primer.
Old 06-01-2011, 07:07 PM   #183
oldman3
oldman3's Avatar
Pic 1 Car upright and removing old paint from firewall.
Pic 2 Another view.
Old 06-01-2011, 07:08 PM   #184
oldman3
oldman3's Avatar
That's your fix for today, catch you tomorrow......Jim
Old 06-01-2011, 07:18 PM   #185
Shaky
Six in a row makes it go...
Shaky's Avatar
Man - you guys work fast!
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 06-01-2011, 11:00 PM   #186
bollybib
bollybib's Avatar
Originally Posted by oldman3 View Post
So I replaced it with a Miller matic 140, man what a difference, this thing welds so nice (new technology sure makes a difference).
Thanks. I know what you mean about new tech, old stuff that has worked for you a long time and gave you good service was your friend, but wow, this new stuff really rocks. I'll check out the Miller and keep following this nice Jim thread.
That number 965 in the recessed area of Post #183 looks factory to me. I've been finding numbers like that on my frame (95 in my case). Assembly related I would think.
I wish I had more feedback to give but your work goes far beyond anything I've ever been personally associated with.
Jim
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 06-01-2011, 11:02 PM   #187
oldman3
oldman3's Avatar
Not really, trucks been done for awhile, just posting pics fast. Thanks for checking it out and posting.......Jim
Old 06-01-2011, 11:06 PM   #188
oldman3
oldman3's Avatar
Jim
Thanks, appreciate it......Jim
Old 06-02-2011, 03:44 PM   #189
Shaky
Shaky's Avatar
Phew! I was starting to feel bad!
Old 06-02-2011, 10:54 PM   #190
oldman3
oldman3's Avatar
Posting late today, helping friend with his pickup.
Pic 1 Getting top in better shape.
Pic 2 Overall view, can also see how the "A" pillar is filled in.
Pic 3 Rust hole in lower windshield area will need to be repaired.
Old 06-02-2011, 10:57 PM   #191
oldman3
oldman3's Avatar
Pic 1 Grinding on firewall.
Pic 2 New panel installed on pass. side.
Pic 3 Larger holes filled in.
Old 06-02-2011, 10:59 PM   #192
oldman3
oldman3's Avatar
Pic 1 Running boards and grill in regular primer.
Pic 2 Cowl cover also in primer.
Old 06-02-2011, 11:02 PM   #193
oldman3
oldman3's Avatar
Pic 1 Hole filled where heater was.
Pic 2 New panel made to match drivers side, with lip added.
Pic 3 Front view.
Old 06-02-2011, 11:05 PM   #194
oldman3
oldman3's Avatar
Pic 1 Making templetes for filling in firewall "wire" ledge.
Pic 2 Here a piece has been tacked in place on pass. side.
Old 06-02-2011, 11:08 PM   #195
oldman3
oldman3's Avatar
Pic 1 Here small pieces tacked to firewall, and the top pieces placed for welding. This was all on a 30 degree angle, not flat.
Pic 2 After welding, you can see the angle.
Pic 3 Working on pass. side.
Old 06-02-2011, 11:11 PM   #196
oldman3
oldman3's Avatar
Pic 1 Ready to prime new inner fender panel.
Pic 2 In epoxy primer.
Pic 3 Next day in regular primer.
Old 06-02-2011, 11:13 PM   #197
oldman3
oldman3's Avatar
Pic1 Ready to prime new radiator support.
Pic 3 Next day in regular primer, with the other stuff.
Old 06-02-2011, 11:14 PM   #198
oldman3
oldman3's Avatar
That's it for tonight, see you tomorrow......Jim
Old 06-02-2011, 11:42 PM   #199
67chevy1series
67chevy1series's Avatar
looks great jim keep at it always such nice progress so frequent!
67chevy1series is offline   Reply With Quote
Old 06-03-2011, 10:16 AM   #200
oldman3
oldman3's Avatar
Thanks, appreciate the compliments, since the truck is done, posting pics makes it look like I'm super fast, but I'm not......Jim
