11-18-2012, 10:24 PM | #176 |
Re: Slowly I build a truck
Hood's on:
11-18-2012, 10:29 PM | #177 |
She's home from the paint shop:
11-18-2012, 10:38 PM | #178 |
VA72C10
Looks great!
Looking for a 67-72 swb or blazer project in or around VA. |
11-19-2012, 12:28 AM | #179 |
Nice....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-19-2012, 08:38 AM | #180 |
PROJECT 7DEUCE
Looking good..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-24-2012, 05:02 PM | #181 |
Thanks guys!
Door handle installed on Drivers side: I broke the bolt trying to put the passenger side door handle on so I'll have to drill that out and find a new bolt. Don't try the 'just one more turn' method on these! Last edited by FLcustom10; 11-24-2012 at 05:16 PM. |
11-24-2012, 05:08 PM | #182 |
67cheby
beautiful
11-24-2012, 05:14 PM | #183 |
Installed the charcoal canister. I think most people just ditch it, but I decided to keep it for old times sake. I found the filter at NAPA. Wix part number 42998, NAPA part number 2998. Left hand hose goes to carb, middle to PCV valve, right to fuel tank.
11-24-2012, 05:21 PM | #184 |
Windshield washer tank:
11-24-2012, 05:30 PM | #185 |
New Fuel Tank grommet from Wes at Classic Heartbeat.
I put it in a pot of boiling water and wiped the area down with dawn dishwashing soap and slid it on. I pushed it down too far and tried using wooden popcycle sticks to get it back over the lip. They break too easy. I wound up using a screw driver wrapped in electric tape. I had a few panicky moments thinking I wasn't going to get it, but it finally popped into place after about 15 minutes. I wound up using a little bit of white lithium grease on the grommet on the inside of the cab to get that last little bit over the lip. |
11-24-2012, 05:34 PM | #186 |
New horn button in blue instead of yellow:
11-24-2012, 05:40 PM | #187 |
Running wires for lights:
Side Marker, low beam, high beam, parking, and turn signal |
11-24-2012, 05:51 PM | #188 |
New Grille coming soon. It looks like it's going to be an adventure getting these pieces to fit together. I've learned not to expect them to fit.
11-24-2012, 08:38 PM | #189 |
Cluster King
Really nice Jim. Did you find a good place for speakers or speakers that work well and sound good? I was also wondering if you found the bag for the Jack tools and where? It is good to see you are not cutting holes in the doors for speakers.
11-24-2012, 09:33 PM | #190 |
Thanks guys. I haven't gotten to the rear speakers yet. I haven't found a bag for the jack tools yet either. I did order a Houndstooth seat cover
at the Moultrie swap meet last week so hopefully the seat will be going in soon. |
11-25-2012, 08:43 PM | #191 |
Parts are down from the attic and ready for some fun!
11-25-2012, 08:45 PM | #192 |
Headlights going in:
11-25-2012, 08:46 PM | #193 |
Side Markers:
11-25-2012, 08:46 PM | #194 |
She lives!
11-26-2012, 01:04 AM | #195 |
Allright....Jim
12-02-2012, 10:31 PM | #196 |
Mounted the Painless Wiring Maxi-fuse to the charcoal canister. I'm wondering if I could have hidden it inside the old voltage regulator housing, but at this point the wires are already on this side of the truck.
12-02-2012, 10:34 PM | #197 |
Painting more parts:
12-02-2012, 10:39 PM | #198 |
Pre-fitting the grille brace and riveting the grille.
12-03-2012, 01:56 AM | #199 |
Wow. Lots of good looking hard work you have done. Great color too. :-)
1971 Cheyenne, The Blue Jay. The Blue Jay build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=516989 |
12-03-2012, 05:04 PM | #200 |
Looking good keep up the hard work.
