Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-07-2012, 03:17 AM   #176
BigDan3131
BigDan3131's Avatar
Re: My build thread.. 63 LS powered C10
No they never are and when you have more than one it takes even longer. I wont be racing my 64 but it will be fast enough to beat the other guy across an intersection. I did the street racing thing and people "knew that guy in the El Camino" I kind of grew out of it. I read your build carefully, to find the pitfalls you uncovered which weren't many if any. I do love my carbs and a high winding motor so you never know I may end up at the track again.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-25-2012, 02:55 AM   #177
BigDan3131
BigDan3131's Avatar
Any news? I haven't seen any updates in a while, in another thread you mentioned valvetrain issues. What happened?
Old 09-25-2012, 04:16 PM   #178
Super73
Super73's Avatar
Dan,
Yes, I do have a small problem I am trying to resolve. I am seeing some valve float around 6,700-6,800 rpm. I think the springs are not keeping up. I just received my new springs and shims so will put it all back together in the next couple weeks. My next track deal is scheduled for 10/21 which is an all truck event in sacramento.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-28-2012, 01:57 AM   #179
BigDan3131
BigDan3131's Avatar
Are you using Titanium retainers? When you built the motor did you buy those new style lifters that are better suited to high rpm or did you just use the stock ones? It could be either of those and I thought I heard you can get a rev kit for hyd roller cams.
I wish you good luck at both hoping the springs fix it and at the track.
Old 09-28-2012, 07:22 PM   #180
Super73
Super73's Avatar
I have ti retainers. The lifters are the CTSV lifters and some shops have used them in some abnormally high spinning motors (for hyd anyway upwards of 8,500rpm). I have talked to a few people that think the lifter plunger is shimmed to reduce plunger travel limiting it to like twentyfive-thou, then preload is set very low like ten-thou. This allows the lifter to act like a hyd at low rpm, then at high rpm, if the lifter bleeds down it doesn't loose much lift, or if it pumps up and hold the valve open, it isn't open much at all.
Not sure that I will do that, but who know. Would probably go solid instead.
Personally I don't think it is the lifters. These came out of my 347 that went to 7,400-7,600 with out issues.
Old 10-08-2012, 07:19 PM   #181
Marv D
Registered Truck Offender
Marv D's Avatar
Shaun any difference in valve diameter / length between these heads and the ones on the 347? Just wondering if weight in the valve train is higher and maybe limiting RPM more than in the last motor?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-08-2012, 11:52 PM   #182
Super73
Super73's Avatar
All three heads were/are at 1.80" install height. Both aftermarket heads retain factory geometry all the way around even with the 3/4" head deck vs the stock ported ones on the 347 at 1/2".
Trying to decide if the new springs are going in at 1.77 or 1.755.. 1.755 puts me at .055 before bind on my closest spring (.065 on most). I'd prefer the 185ish lbs on the seat the 1.755 gives, but feel more comfy at .070 clearance which is 175lbs. Still 30lbs added to the seat. Can't judge open since I only tested the old springs after being run.
Old 10-09-2012, 01:51 PM   #183
Marv D
Marv D's Avatar
I've been running 0.050" off coil bind on solid rollers for a long time,, always used it as a sort-of stop gap for valve float / lifter bounce. 10 psi is 10 psi..... The considerations your fighting to keep the hydraulic roller ,, you sure get my respect. I'd have thrown a set of solids and buttloads of spring on it long ago just to see what happens. LOL
on another note,, my LS1 stroker sandrail motor mounting up on the dyno late today...first tunning in the morning.. hope ot make a few pulls by mid day. Just to tune the new computer,, it's a real mild motor with just the stock 853 heads, mild cam, 4" stroke, bla bla bla.... nutin very special. But I just know this is going to have be dumping everything Gen 1 small block I own and becoming a LSx addict.
Old 10-09-2012, 03:39 PM   #184
Super73
Super73's Avatar
Marv,
I am not apposed to going SR and I will at some point. $200 for springs and shims is a lot less than the $2,400+ to go SR. I am fairly confident that if the springs don't fix it, than the push rod change will (which will happen after I confrim the springs did/didn't fix it).
The new goal is to go 9's NA with the hyd set up. I got my work cut out for me
LS motors require the heads to come off to change the lifters. Sooo...
$1200 in rockers arms
$600 in lifters
$175 for push rods
$100 in head gaskets
$400 for cam
Old 11-08-2012, 03:06 AM   #185
Super73
Super73's Avatar
Change is a coming again..
Swapping out the intake valves, and having powdered metal guides installed. Going from 115 grams per intake to about 87-88 grams. Hoping this cures my valve float issue. But just in case...
I have a new set of stiffer valve springs. This will cause me to do a push rod upgrade. New ones will be 5/16 .120 wall vs the 5/16 .080 wall I have now. Trust me, I'd prefer to go 3/8 or even 11/16 but the heads would need to be clearanced and there is concern that when doing so, the push rod area might put a hole in the intake port.
Since the heads will be off, thinner gasket moving me from 12.9cr to 13.5cr.
Putting a 4 vane vacuum pump set up on it. Currently have a breather, not even to the headers.
Having my electric water pump rebuilt. Last outing I was on a manual pump.
Going to have the converter restalled. Gonna add roughly 700 rpm to it.
Most likey will have the intake ported before it goes back together as well.
Expected completion, feb/mar time frame. What will all this do for me? I hope to go faster...
Old 11-08-2012, 08:50 AM   #186
Marv D
Marv D's Avatar
Someone has a serious case of the Faster faster faster addiction don't he.
LOL Now fess up Shaun,,,,,, inquiring minds want to know ..WHY all these changes.
(insider info can be fun sometimes LOL)
Old 11-08-2012, 12:19 PM   #187
Super73
Super73's Avatar
Because it will hopefully go faster?
For the valve train changes, because putting the heavier spring on the compensate for the currently heavy valve would only promote issue with push rod deflection with the current set up. It is a lot easier to control the lighter valve.
Guides because a run a stock rocker with trunion upgrade since they are lighter than any other rocker. Not going to a roller rocker due to the added weight it places over the valve. This also pretains to the above valve spring/push rod issue. Being non roller they put a side load on the valve and wear valve guides faster. The powdered metal guides are supposed to cure that premature wear issue.
Head gaskets well, because heads are off, need new gaskets (even though cometic claims they are reusable), and thinner could = more power.
Vacume pump for multiple reasons. Condensation I see in the oil due to the ethanol, better ring seal, currently have decent crank case pressure. Only good can come from this.
Converter loosened up a little as it is 1100 rpm too tight for motor. Upping it 700 rpm should still make it user friendly for the n20.
Porting intake, well, just for a little more power.
I know, I answered the question you had Marv, but I know what your real agenda was
Goal, 9.xx na pump gas hyd on a drag radial.
Old 11-08-2012, 12:38 PM   #188
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Ya buddy go get some! Put that new chassis set up to work.
Glad I'm not the only one changing things up in the off season. Best of luck Shaun. Take a look at smith brothers for your push sticks. They will custom build them and not charge a arm and leg.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-10-2012, 04:01 AM   #189
BigDan3131
BigDan3131's Avatar
Just wondering...Do they make titanium valves for LS based motors?
Old 12-10-2012, 05:49 AM   #190
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: My build thread.. 63 LS powered C10
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-11-2012, 12:56 AM   #191
Super73
Super73's Avatar
Yes, but they weigh with in 2 grams of a turned down hollow stem l92 valve, but are 6-7x the price.
Old 12-11-2012, 07:40 AM   #192
hotrod 80
mini truck racer
hotrod 80's Avatar
Assuming the hollow stems are liquid or sodium filled and splash cool ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-11-2012, 12:19 PM   #193
Super73
Super73's Avatar
Yes.
Old 12-27-2012, 01:28 PM   #194
Super73
Super73's Avatar
Yeasterday i shipped my electric water pump to Mezeire to be repaired. It will be nice to have it back on the truck for the next track outing.
Ordered up all my -12 fittings for the vacuum pump install.
Dennis, (guitar player in one of the bands I play in) called to tell me the crank pulley adapter is made. This will hold a 2.5" v grove pulley to the LS crank pulley to spin the vacuum pump. Just need to get it from him and have it balanced.
Motor comes out today, heads come off and get shipped to Total Engine Airflow for the new guides, valves.
Once heads are back, the intake and heads go to a local head porter to have him work the core shift out of it and massage the intake ports on both intake and heads to match.
Old 12-28-2012, 12:38 AM   #195
shortbed70
shortbed70's Avatar
Ka-Ching!!! Nice man can't wait to hear and see this thing go again. I'm with Marv to I'm so ready to jump on the ls wagon... Call me whatever you want them dang motors just respond too well to upgrades...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-29-2012, 03:27 PM   #196
Super73
Super73's Avatar
Well, looks like I might be adding 1.8 roller rockers on top of everything else (just got a great deal on a set) That wil bring my total lift from .631 intake to .668 intake. Hopefully the added weight over the valve doesn't come back to bite me. I have to run my new springs since the old ones won't have enough available compression. I will be buying different push rods too before it goes back together simply due to the added spring pressure.
Old 01-03-2013, 03:27 AM   #197
Super73
Super73's Avatar
Got my adapter for my vacuum pump drive pulley today. Dennis (Guitar player in one of my bands) is a machinist and made it for me. Now I just need to put counter sunk allen bolts in it and have it balanced.
Old 01-04-2013, 01:01 AM   #198
chevytruck1970
chevytruck1970's Avatar
Pulley looks good. What brand is your vacuum pump and how much vacuum do you plan to run?
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 01-04-2013, 01:16 AM   #199
Super73
Super73's Avatar
Moroso 4 vane and 14" or so.
Old 01-04-2013, 11:40 AM   #200
Marv D
Marv D's Avatar
I'm sure you are already aware Shaun,, But the guys over on the bullet were talking about pin gauling at high vacuum, I brought it up with my machinist and he said it's not as big of a deal with the LS motors for some reason <shrugs> . One thing for sure, you won't have to worry about collapsing a oil pan up against the oil pickup with that LS pan will ya (LOL)
