Old 04-28-2016, 08:35 PM   #176
JointTech
JointTech's Avatar
Re: N00b with a 72 c20
Reran my plug wires under the headers. Had to make a few brackets. Came out pretty good. It also took 2 sets of custom plug wires. I dont see why those cheap bastards dont just give you 8 long cords since you are cutting them to fit anyway.
#3 and #5 are a real pain with these headers. took 2 brackets. one on the oil pan and another against the block. No wires touching headers though!!
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 04-28-2016, 08:38 PM   #177
JointTech
JointTech's Avatar
Started on making my stainless braided tranny cooler lines.
Only stabbed my self in the finger once when putting the fittings on the hose.
72 C20 Long Bed
Old 04-28-2016, 08:49 PM   #178
JointTech
JointTech's Avatar
Heres what Im working with.
Drivers floor
Drivers front cab support
Current parts, more on order..
Drivers kick panel
Passenger Rocker
Passenger cab corner
Drivers driprail, not horrible.
Passenger driprail, pretty horrible, new one on order.
Passenger floor
I guess theres no time like the present to start cutting metal!
72 C20 Long Bed
Old 04-29-2016, 09:16 PM   #179
zellway
zellway's Avatar
looking good. Really clean. Looks like you get to have some cab patch work to play with. I'm looking at about the same level of rust in my old step side. Keep up the good work and pic's
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 04-29-2016, 11:04 PM   #180
JointTech
JointTech's Avatar
belts and hoses all on and tight. Filled it with oil.
Going to put some water in it tonight.
Going to try to fire it up this weekend for some motivation on the metal work.
72 C20 Long Bed
Old 05-05-2016, 04:55 PM   #181
JointTech
JointTech's Avatar
Tried to start it this weekend. First tip is dont try to start it in Drive... Second tip is before filling with water make sure ALL your sensors are screwed in or plugs are in the holes...
I primed the oil pump up to 65psi ish for a 30 seconds to a minute. Drill was smoking!!
couldnt get any spark.
tested the ignition module and it tested good. I then tested the distributor pickup and it seems to be putting out way less than 1VAC. Hard to find a new pickup and the ones I saw were $50. Plus you have to remove the pin and gear from the distrib to replace it.
Bought a skipwhite distrib for $39 which includes cap, rotor, ignition module, coil, distributor. cant beat that with a stick. Should be here friday so I can try again to start this beast.
72 C20 Long Bed
Old 09-19-2016, 04:10 AM   #182
JointTech
JointTech's Avatar
cut out the drivers rocker and found a little more rust than I was expecting. Got some more patch panels on the way.
72 C20 Long Bed
Old 09-19-2016, 06:18 PM   #183
Aus69c20
Aus69c20's Avatar
I've enjoyed reading through this thread. I'm onboard.
Good job so far.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 09-19-2016, 06:52 PM   #184
demian5
demian5's Avatar
I live in Lake Forest and just picked up my first 1970 C15 GMC. It would be *****en to connect and talk trucks.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 09-20-2016, 02:30 AM   #185
JointTech
JointTech's Avatar
sounds good. my shop is on lake forest drive up near dimension. shoot me a PM sometime and we can meet up.
72 C20 Long Bed
Old 12-13-2016, 01:49 AM   #186
mattfranklin
mattfranklin's Avatar
I've been enjoying reading through your build. Solving problems as you run across them. Just like all will have to do when we get that far along. Thanks for showing us the way through them.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 09-25-2017, 04:17 PM   #187
DJ_Baar
Enjoyed the read. NICE Shop! I'm building my '67 Chevy C20 long bed Camper Special now. Found a few similar issues been dealing with. Looks good.
DJ_Baar is offline   Reply With Quote
