Old 04-26-2013, 02:08 AM   #176
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Re: Build: I've never done bodywork...but I can change if I have to! (bagged '67 SWB
Originally Posted by aedcustoms View Post
Great idea on the tub, looking good
thanks, it's quite simple really.
Originally Posted by vegadesign View Post
Very good idea with the tub, now you will be able to do the step notch and still not even know it was there lol
haha! thats so true! i had the exact same idea, later raise the floor with the tub, notch the cab, and throw in the step to give me another 4 inch down in the rear, it could use it!
Originally Posted by builtbyKane View Post
Your like the macgyver of wheel tubs now make one out of a paper clip.
I think I made a really easy job seem complicated!?
Originally Posted by 67cheby View Post
great looking progress
thanks
What did you use to get that bend, looks perfect all the way across
you mean the one I did with my homemade brake? i just slowly tapped it with a hammer and block of wood 6 inch wide, just keep moving accross back and fourth not bending too much.
Originally Posted by PHAT TONY View Post
Was your seat guys name Arlo?(!$#%*&)
no, just an old local small town feller. did awesome work at an extremely reasonable rate, but he got old and started forgeting where he put his shoes, yet alone my seat.
Originally Posted by chevy88 View Post
Nice job on the wheel tubs.
thanks!
Originally Posted by BLUIDVL View Post
x2!
thanks, i like the work getting done on your truck!
smoknbarrels is offline   Reply With Quote
Old 04-26-2013, 02:21 AM   #177
smoknbarrels
Registered Mail
well had another long day, got some stuff done, but always seems like its never enough.
wired in the dome light, painted a bunch of black things, like heater box, rad support (which i had to fix for 2 hours before paint), hood hinges, filler panel below rad support.
also wet sanded my driver door again (didn't do good enough the first time), well I wet sanded it twice, first with 1200, then with 2000, then compound buff, then polish, so really I have visited these panels quite often... I think we are on first name basis already!
I hesitated putting on the passenger door as I don't wanna have troubles putting the seat in, so for now it will have to do looking like a UPS truck.
had some progress with the bed, put all the wood on, drilled all the holes and fit it all, then went in and hacked it all up so the tubs and tires would fit and cut a hole for the pumpkin to peek through.
Size:  50.3 KBName:  PICT0104.jpg
Old 04-30-2013, 09:41 PM   #178
smoknbarrels
Registered Mail
well had some reasonable progress this last few days..
stained and urathaned the oak floor to a nice cherrywood colour, the texture looks a bit rough here, thats because I took the photo before the final sanding and then coated it again twice for a nice smooth finish.
here I am working on the wheel tubs/compartment for battery and accuair.
here is where I was explaining how I bend the sheets to the right fit, I simply tack it all up and just roll it and tack it slowly as I roll it, then weld in supports after I have the shape.
Old 04-30-2013, 09:51 PM   #179
smoknbarrels
Registered Mail
and here it is all finished! (and functioning) just doing up some filler on the welds for a nice finish. the lid does close flush, I just dont have the fastening bolts installed inthe photo to pull it snug.
I was gonna put gas struts on it, but decided not to, as I don't think this thing is really gonna be open that often, it's plenty strong without any supports, I'll just put a towel down when I do have it open so the lid doesn't get scratched by the floor when it is all the way open, as it can swing wide open.
and here are the bed sides...finally painted up!
Old 04-30-2013, 10:20 PM   #180
VA72C10
VA72C10
VA72C10's Avatar
Nice work! Looking good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-30-2013, 10:49 PM   #181
sduckworth13
sduckworth13's Avatar
Nice work, amazing actually. I was wondering how the tub would turn out and that is way above what I thought it was going to look like.
Scott
sduckworth13 is offline   Reply With Quote
Old 05-02-2013, 11:34 AM   #182
smoknbarrels
Registered Mail
Thanks!
thanks, it appears to work well.
i am just finishing up the paint on it today, so either late today or tomorrow I will be putting the box together!! Gonna start looking like a truck soon.
Old 05-02-2013, 12:22 PM   #183
vegadesign
vegadesign's Avatar
the rear tub hatch looks badass, gunna make things even easier.
great idea keeping everything accessable and bolt on.
keeping alot of stock components with a twist
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 05-05-2013, 11:33 PM   #184
HSRACER
HSRACER's Avatar
Subscribed. Lookin great
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 05-06-2013, 10:23 AM   #185
builtbyKane
builtbyKane's Avatar
You could always do a selt belt style material strap that won't let it rest all the way down when you need in there. That way you don't have to worry about putting a towel down.
builtbyKane is offline   Reply With Quote
Old 05-08-2013, 12:33 AM   #186
smoknbarrels
Registered Mail
yea, thanks, it has just the right amount of stock for me, turning out as I imagined it!
thanks, hope you enjoy viewing.
yea that would be a good idea, that way it wouldn't rattle or make noise while driving, if I get anoyed with the putting towels down I will do that! I don't see myself opening it up too much though. thanks for the idea.
well had been working on it hard the last little bit, got the box all together and put on
installed the instrument cluster (temporarily), did the wiring in the engine area, added some fuel and... hit a major milestone at about 11:59 the other night, I got to hear it run for the first time! wowzers!! she is loud without mufflers on, just coming off the headers, and boy is that engine lumpy, shakes the whole truck at idle like a top fuel car (mind you the no exhaust adds more emphasis)
was so nervous about putting that tub in, just being on piece, it had such little margin for error on the width, but it just fit right on the money. was so nice to hear it actually run!
Old 05-08-2013, 01:30 AM   #187
vegadesign
vegadesign's Avatar
That sits pritty low, looks good.
It's a good feeling hearing it fire up for the first time at which seems forever
Old 05-08-2013, 08:24 AM   #188
Bennett68C10
Bennett68C10's Avatar
Truck looks great, nice job on the rear tub
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-08-2013, 09:37 AM   #189
HSRACER
HSRACER's Avatar
Looks great. I am impressed that you never had done any body work before yet your results are amazing. Also, congratulations to getting her running! that is so much fun after a rebuild and wiring to hear them fire up.
HSRACER
Slammed 53 5 window
Old 05-08-2013, 10:04 AM   #190
sduckworth13
Nice job, the truck is looking great.
Scott
Old 05-08-2013, 11:45 AM   #191
BossHogg69
motor exploder
BossHogg69's Avatar
Congrats on firing that beast up - your build is coming along nicely. Thanks for all the pics and inspiration!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-08-2013, 12:36 PM   #192
BLUIDVL
BLUIDVL's Avatar
Real nice job, your C10 is coming along nicely. Looking forward to more pics.
BLUIDVL is offline   Reply With Quote
Old 05-08-2013, 09:08 PM   #193
chevy88
chevy88's Avatar
I hope it's too wet to seed so we can see the finished product, man you are getting so close.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 06-04-2013, 02:07 PM   #194
69short
69short's Avatar
Any updates on this build?? You did an amazing job, I would have never guessed youve never done any body work..
69short is offline   Reply With Quote
Old 08-21-2013, 10:05 PM   #195
smoknbarrels
Registered Mail
Thanks! Was great hearing that idle!
thanks, it was a tight fit.
thanks, it was quite the learning process.
thanks, its slowly coming along.
Thanks, it is coming along when i actually working on it.
haha! I know, i could have had it done for the summer, but then summer got busy.
Thanks, well, i am thinking of doing some work on it in the next few days, hopefully i can get motivated to get something done!!
Old 08-21-2013, 10:08 PM   #196
vegadesign
vegadesign's Avatar
I was just wondering if this thread was still alive lol
Anything new?
Old 11-22-2013, 08:10 AM   #197
chevy88
chevy88's Avatar
You back on your truck yet?
Kerry
My build thread.
Old 06-03-2016, 09:18 PM   #198
Woodyboat
Woodyboat's Avatar
so, what has happened lately with this truck?
Have you finished it? ... still in progress?
Woodyboat is offline   Reply With Quote
Old 06-05-2016, 10:40 PM   #199
weedoublewide
yea man I'm on the same page as WoodyBoat....whenever you get some time bring us up to date on what you've done...if anything in the past three years bud....we will be patiently waiting for the post =D
weedoublewide is offline   Reply With Quote
Old 01-08-2018, 11:09 PM   #200
smoknbarrels
Registered Mail
well I ended up selling the truck, one day I was frustrated that it was in my way in the shop, and put it up for sale, it ended up selling the next day.. sold it for about .35 cents on the dollar - just in new parts alone. zero for my labour.
obviously I regretted it later, especially since I was so close to getting it finished.
but currently I am working on a 66 mustang and a 67 nova, so hopefully I don't get annoyed with those ones as they are a long way away from completion (just picked them up!)
I will try calling the young guy I sold it to, he must have finished it as he said it was going straight to a custom shop to get it finished off.. mind you that was a few years ago now..
