View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 03-04-2013, 03:59 AM   #176
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Originally Posted by Bomp View Post
Lookin good.
I've got to get my rockers on so I guess you've passed me.
Barrel blaster lookin' good too. What are your plans for the arm holes?
Passed you? Your so far ahead you're about to lap me. Of course if you continue to do all that crazy fabrication I might move up a little.
Arm holes!!! I thought I could just get a couple of pvc flanges and bolt them up until I saw prices. OMG!! Time to rethink this! 6" pipe....I got no stinkin' pipe!!!
I'm probably going to end up bending and welding again if I can't find someway easier soon. I've got one more long weekend to work on it and then I'm off to Mexico for a week or so. I'd like to get it done before that.
pdxhall is offline   Reply With Quote
Old 03-04-2013, 03:38 PM   #177
Bomp
Bomp's Avatar
Re: pdx-sanity66
Mine are 7" and your welcome to come get some if you like. Can cut out an inch and squeeze it back together, weld it up. pm me if you wanna set up a time.
Bomp is offline   Reply With Quote
Old 04-09-2013, 03:00 AM   #178
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Well, vacation is over and I got stuff caught up around the house so I finally got back out and worked on my Sanity for a couple of days. I've got the floors done. I finished a little touch up on the rockers and then realized I still had a place to patch on the passenger side at the corner of the trans hump and floor. I fabbed up a couple of patches and welded them in and then decided I needed to patch a little more so I cut one more patch and got that welded in. I think it turned out pretty good. I'm ready to get this cab flipped on its back and start the clean up. I've also been working on my blast cabinet. I'll show some pics of it soon.
Old 04-09-2013, 05:53 AM   #179
mark 66
Re: pdx-sanity66
man that looks good. like it never even happened
mark 66 is offline   Reply With Quote
Old 04-09-2013, 09:24 AM   #180
Corts60
Just here to tinker
Corts60's Avatar
Re: pdx-sanity66
Your work is fabulous! Well done.
Old 04-09-2013, 09:28 AM   #181
1963c-10
1963c-10's Avatar
Re: pdx-sanity66
Great job on the floor fix.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-09-2013, 10:15 AM   #182
markeb01
Senior Enthusiast
markeb01's Avatar
Re: pdx-sanity66
Wow that's just artwork. I really admire those skills.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-09-2013, 10:50 AM   #183
Bomp
Bomp's Avatar
Re: pdx-sanity66
Awesome work man!
Old 04-09-2013, 07:51 PM   #184
chad64chevy
chad64chevy's Avatar
Re: pdx-sanity66
pdxhall, like everyone else has said that floor looks great, a lot better then mine! your doing really good work, keep it up man! you'll be done in no time!!!
chad64chevy is offline   Reply With Quote
Old 04-09-2013, 08:25 PM   #185
Jmorales3181
Jmorales3181's Avatar
Re: pdx-sanity66
X2
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 04-13-2013, 06:43 PM   #186
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks alot you guys. I really appreciated the compliments. I sit and stare at this stuff for so long I don't know if it's okay or not. I have a hard time knowing when to stop fussing and go on.
As soon as the weather improves a little I'll get some epoxy sprayed on. I've got to get my son over here with some of his friends to tip the cab on its back. Nothing like some 20 something muscle for that sort of thing since I haven't broke down and got a cherry picker yet. I'm going to do some more on the frame next. I've got to finish up the brakes and run some brake lines and ebrake cables next and pick up a power steering conversion kit from the Capt. and get my steering gear installed. With the warm weather, I hope to get the bottom of the cab cleaned up and coated and the firewall work finished. Then I can set the cab back on the frame.
Old 04-17-2013, 02:39 AM   #187
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Didn't get much done on Sanity but I bought something today. A completed SBC serpentine belt set up with all the brackets, pulleys, alternator, water pump, power steering pump, clutch fan, AC compressor, and all the nuts and bolts for $100.
Old 04-17-2013, 09:01 AM   #188
Ta2Don
Ta2Don's Avatar
Re: pdx-sanity66
Nice Score, I also scored the same setup for a C note...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 04-17-2013, 11:16 AM   #189
Bomp
Bomp's Avatar
Re: pdx-sanity66
$100
Old 04-20-2013, 05:04 PM   #190
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: pdx-sanity66
Yes I have. I had to weld a patch right there so I welded up what was left while I was at it. I could tell it had been leaking through.
Looks like you're making some nice progress.
Mine has been just sitting.
First on my list is to get that same area fixed.
Was it difficult to get things lined back up?
66 C20 Service Truck:
Old 05-06-2013, 03:52 PM   #191
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Sorry I haven't updated lately, I've had a lot going on at work. The donor air box on mine lined right up with no problems. I got it to where it looked right and put down a couple of spot welds. I checked the alignment with the fender extension and it aligned right up so I finished tacking it in.
Even though I haven't posted in a while, I have been getting some things done. After all the floor patching I decided I needed to step away from the metal work for a bit and do something mechanical. I decided to get the brakes finished up and get my brake lines ran and some other misc. stuff.
I realized after I had my new 5 lug axles made up that I had had them made with the center hub the same as the 6 lug axles instead of the smaller diameter of the 5 lug axles. Rookie mistake: dohh: So I took them back out and had the machine shop turn them down. The next thing is to get the brake lines ordered and installed and get the front calipers, etc. installed. And also finish up the emergency cables as far as I can with the body off. Luckily, the cables are all in excellent condition so I'm bead blasting them and WD40ing them to freshen them up. I just slipped the drums on to check them out. I still need to clean the packing stuff off of them and then paint them.
I also got my bead blast cabinet finished and I've been blasting the crap out of a lot of small parts laying around and also the emergency brake hardware to do my brakes.
Here are a few pics of what I've accomplished lately:
Old 05-07-2013, 10:56 AM   #192
Jmorales3181
Re: pdx-sanity66
Nice progress! Need me one of those cabinets came out nice!
Old 05-07-2013, 12:47 PM   #193
CRGRS 66
CRGRS 66's Avatar
Re: pdx-sanity66
looking good!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-07-2013, 08:46 PM   #194
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks man. This cabinet has become my favorite toy. It's going to save a ton of time cleaning up small parts for resto.
Originally Posted by CRGRS 66 View Post
looking good!
Thanks Craiger
Old 05-07-2013, 09:01 PM   #195
Bomp
Bomp's Avatar
Re: pdx-sanity66
You have been busy. Looking really good. Have to get up there again soon and have another peek.
Old 05-17-2013, 04:27 PM   #196
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
You're welcome anytime. I'd like to make it down your way one of these days and check out Bompenstein.
The front brakes are on and Spike gives his approval. I took the rotors back off and painted them and the calipers with Duplicolor caliper paint and then installed it all. I also got my brake lines ordered from Fine-Lines.
Old 05-24-2013, 10:46 PM   #197
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I've been thinking about getting a cherry picker from Harbor Freight for some time but I was waiting for one of their killer coupons and I just wasn't to the point of needing one yet. Well, things have changed. I picked up the coupon for the one ton model for $99 the other day and the next thing I knew I was standing in the garage assembling it. So once it was assembled I needed to lift something, Right?
So I decided I give a try at getting my cab onto it's back. It took me a while to get it done but here it is. The most pleasant surprise is the condition of the cab bottom. No undercoating! None! The pics are of the cab bottom before and after less than an hour with a scotch brite and my shop vac cleaning the dirt off. This is going to be much easier than I had ever imagined to get cleaned up and coated. That original primer on the bottom is some tough stuff!
Old 05-25-2013, 10:28 AM   #198
CRGRS 66
CRGRS 66's Avatar
Re: pdx-sanity66
Nice, as soon as I get my frame cleaned up and painted (close), then my cab goes on it's back for the same treatment!
Craigerrr
Old 05-25-2013, 11:32 AM   #199
Bomp
Bomp's Avatar
Re: pdx-sanity66
Impressive.
Are you going to apply an epoxy sealer before the under coating goes on?
Old 05-25-2013, 06:38 PM   #200
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Yeah, that's been my plan. I'll get the bottom all sealed up then I can get the cab mounted and start fitting and aligning the rest of the body parts. While I've got it on its back I'll probably prep the ceiling of the cab also to save myself awkward working positions as much as possible.
Impressive.
Yes. I will shoot some epoxy primer first. I'm still deciding whether to go with Rhino liner or Eastwood has a new product that sounds good too.
