Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 05-14-2015, 11:09 AM   #176
05snopro440
05snopro440's Avatar
Re: 1940 "project moonshine"
Love the truck! I always get the "When are you going to paint it?" or "Are you really finished with it?!?" Questions.
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
05snopro440 is offline   Reply With Quote
Old 05-17-2015, 12:33 PM   #177
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Some people understand leaving the mother nature paint. Some don't.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 05-17-2015, 05:27 PM   #178
05snopro440
Yeah, more and more seem to get it.
Old 05-17-2015, 07:35 PM   #179
biscuit
Haven't even got mine out and i can't count how many times i've heard " when ya gonna paint it" . I tell them it's candy apple rust
Your truck was part of my inspiration for my project =Thanks
biscuit is offline   Reply With Quote
Old 05-17-2015, 10:40 PM   #180
CHIZZLER
CHIZZLER's Avatar
Thanks guys. 05snopro440 really diggin your truck. Hey biscuit you got a build thread?
61-crew cab D-max
Old 05-17-2015, 11:11 PM   #181
solidaxel
solidaxel's Avatar
^^^^ What he said !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-31-2015, 03:32 PM   #182
joliver33
Your 40 looks fantastic just they way it is... I think if someone needs to paint something it would be the frame showing on your dually...
http://67-72chevytrucks.com/vboard/a...1&d=1381275120
joliver33 is offline   Reply With Quote
Old 08-03-2015, 07:11 PM   #183
solidaxel
solidaxel's Avatar
Chizzler or anybody using Scotts IFS with coil over Alden shocks. can you tell me what weight coil springs you ended up using?
LS 3 4L70E
Old 08-04-2015, 12:38 AM   #184
CHIZZLER
CHIZZLER's Avatar
I did not use coil over's. Check out simple 49 build. He may be able to help you with the info.
61-crew cab D-max
Old 08-04-2015, 12:22 PM   #185
solidaxel
solidaxel's Avatar
Thanks I forgot you are on air
is it simple49 ?
LS 3 4L70E
Old 08-04-2015, 09:51 PM   #186
CHIZZLER
CHIZZLER's Avatar
Yes. Simple49. He is running a scott's coil over IFS.
61-crew cab D-max
Old 11-02-2015, 10:00 PM   #187
tleeGMC
Chizzler,
Is there anyway you could post pictures of the hood latches that are attached to the fire wall. My truck does not have any and I am wondering if there is a way to fabricate one or if you know of a place that sales them aftermarket? Thank you for your help.
tleeGMC
tleeGMC is offline   Reply With Quote
Old 11-02-2015, 10:13 PM   #188
CHIZZLER
CHIZZLER's Avatar
I will snap some photos in the next day or so.
61-crew cab D-max
Old 11-02-2015, 10:42 PM   #189
tleeGMC
Here is a pic of my 40. Almost finished.
Thanks for your help!
Old 11-03-2015, 12:58 AM   #190
CHIZZLER
CHIZZLER's Avatar
Nice looking truck. This might help for now.
http://www.2040-parts.com/1939-1940-...ckup-i1040034/
61-crew cab D-max
Old 11-03-2015, 11:14 AM   #191
05snopro440
Does Jim Carter have those parts reproduced?
Old 12-26-2015, 04:28 PM   #192
84blaze
What fuel tank are you using?
84blaze is offline   Reply With Quote
Old 08-27-2017, 10:55 AM   #193
dillonv2008
Wow !! I'm currently welding up my 46 ifs bag system. You said you raised the fenders 3 1/2 inches how did you do that and keep running boards all aligned and stuff? Not sure what size tires I'll be running I believe they are are 26" tall
dillonv2008 is offline   Reply With Quote
Old 01-21-2018, 04:29 PM   #194
dillonv2008
how did you go about keeping your stock steering column. what did you do to convert it so you can run the mustang 2 front end
Old 01-21-2018, 06:50 PM   #195
docrock
docrock's Avatar
@biscuit, what rims, tires and caps are you using? looks great
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 01-23-2018, 12:52 AM   #196
CHIZZLER
CHIZZLER's Avatar
Im pretty sue we used a steel steering joint that converted it from round bar to 3/4 DD and welded it on the column.
61-crew cab D-max
Old 04-24-2019, 12:02 PM   #197
dillonv2008
few update pics.got the rear bumper fit.looks to be a 50s front bumper with splash pan.fits pretty good.didn't like the way the 40s bumper fit the back.got this one with the truck.got the motor mounts set with the stroker and 700r4.we were able to set it really low to keep the tranny tunnel to a minimum.chizzler
So your front and rear bumpers are from a 50s truck did you use the 40s brackets or 50s brackets to mount it. The 50s are defiantly cheaper then the 40s bumper so looking to do that Haha
